Valves: Differential Pressure Torque Test / Gear Ratio Question
Hello All,
I have a 12" 900# Slab Gate Valve that I intend to perform a differential pressure torque test on. During the torque test, the valve will be equipped with a gear operator and pressurized on one side to the Maximum Operating Pressure (2160 psig). I have rigged up a fitting to be able to mate a digital torque wrench to the stem of the gear operator. However, I need to know the torque required to open the valve under pressure at the stem of the valve (without the gear operator). How could I determine the gear ratio of the gear operator since I will need that value to calculate the breakaway torque at the stem? Would the number of gear operator handwheel revolutions required to bring the valve from a fully closed to fully open position be my gear ratio? Sorry if this is a rather elementary question. Any help is appreciated. Thanks in advanced.
RE: Valves: Differential Pressure Torque Test / Gear Ratio Question
Its Valve Engineering question not a Boiler/Pressure Vessel question.
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
A few minutes after posting here he found the valve forum where he's getting answers: See thread408-347045: Torque Testing / Gear Operator Ratio Question. It would be best to post over to that thread.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
