how can I uncover Axis system
I have Product with Parts and I want to select Part to uncover the Axis system. Unfortunately it does not work.
Sub CATMain()
Dim oSel As Selection
Set oSel = CATIA.ActiveDocument.Selection
oSel.Search "type:Axis System"
oSel.VisProperties.SetShow 0
oSel.Clear
End Sub
Best Regards
Santa
RE: how can I uncover Axis system
Try this:
CODE --> CATVBA
Sub CATMain()
oSel.Clear
oSel.Search ("'Part Design'.'Axis System'.Visibility=Visible, all")
Dim visprop As VisPropertySet
Set visprop = oSel.VisProperties
visprop.SetShow catVisPropertyNoShowAttr
oSel.Clear
End Sub
Eric N.
Unfortunately It does not work on R21.
sorry I am still on R20.
What is the error message?
This script will actually hide all visible axis.
to do the opposite you will have to modify the .search .setshow lines
Eric N.
There is no error massage sad
run it step by step (F8) and check if it is the selection of axis or the noshow that does not work.
try with a new product with one or more catpart with axis in show
Eric N.
I ran this macro step by step, and on the line 3 when I select part nothing is happening.
CODE --> CATVBS
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
product1.ApplyWorkMode DEFAULT_MODE
Set selection1 = productDocument1.Selection
selection1.Search "Name=*Axis System,all"
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetShow catVisPropertyShowAttr
selection1.Clear
Set V3D = Catia.ActiveDocument.Cameras.item(1).Viewpoint3D
Catia.ActiveWindow.ActiveViewer.Viewpoint3D = V3D
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
line 3 set oSel does not select anything... it just define oSel as the curent selection
Line 4 unselect all
line 6 oSel.search should select all visible axis
line 11 .setshow put selection in noshow
Let us know what does not work as expected
Eric N.
Thanks a lot for reply, probably I wasn't clear enough.
I have an opened Product with a lot of Parts. From the level of Product I need to select (in main window, not tree) any Part to uncover the Axis system.
well, from the scripts you were given, it should not be too difficult to modify them to get the result you need.
You should enjoy the opportunity to learn a bit of VBA with your request.
keep us posted of your progress, we'll help you.
tips: from my script you need to avoid clearing the selection at the beginning and you need to tell the .search to look only in preselected element. The online doc should help you with that.
you can do it
Eric N.
