PDF folder in Teamcenter 8.0
Hello Guys,
Recently i joined this forum...its was nice experience..
oke i have one problem,
We are working with Nx 7.5 integrated with teamcenter 8
Our PLM team made one "PDF folder" in teamcenter,when we export drawing to pdf..we expect PDF file should go to PDF folder only ,but it not,so every times we have to cut n paste that pdf to PDF folder...so this is a time consuming process..
so any one have better solution for this
Nitin
STAY HUNGRY ALWAYS
UG NX 7.5
Teamcenter 8
Nitin
STAY HUNGRY ALWAYS
UG NX 7.5
Teamcenter 8
RE: PDF folder in Teamcenter 8.0
and they should make sure that pdf's go there ?
( Where does this folder exist ? Under each Item revision ?
- Why the folder ? - in our Teamcenter, the pdf's are placed under each Item revision.)
Tomas
Thanks Tomas,
Actually in every item revision PDF folder is available in our case
and they expect every one should place PDF in PDF folder only,,
so when i contact with him regards this issue..i am getting any positive reply n said its not possible
so every time we have to cut N paste PDF in that folder
so i expect something will be solution for this...so that i can tell him
Nitin
Nx -7.5
Teamcenter-8.0
iHungry Always
