Material Properties not showing up
We switched to UG NX 8.0 a week ago and I notice that when I check properties on a solid body it doesn't show the material property even though it is assigned. Do I have to create a new attribute or do I not have something turned on? When I go into the "assign material" function it shows that all bodies have a material assigned. It just won't show up on the properties.
RE: Material Properties not showing up
Is this what you are looking for ?
If you have the material assigned, it should also report if you do Information - Object ( without the attribute )
Tomas
