VBJournal question - selection etc.
In my journal, first I make a search for a body, what I store in a variable (as Body) named aBody.
When the parent assembly created and the component (ie. Component1) is repositioned, I would like to measure it with some code from the Rohteil.vb of Stefan Pendl.
How can I add Component1\aBody to the variable 'bod'?
Thanks in advance..
CODE
dist(iCount) = ses.Measurement.GetMinimumDistance(bod,_ NXObjectManager.Get(tPlane), selpnt(0), selpnt(1), accu)
kukelyk
RE: VBJournal question - selection etc.
This version of GetMinimumDistance takes 5 parameters: 2 objects, 2 points, and a double. The 2 objects are inputs, the objects you want to measure the distance between; the 2 points and accuracy values are outputs, values returned from the function that tell you about the minimum distance calculated.
www.nxjournaling.com
I have the body at the component part, but when I am in an assembly (after create parent), where I have the component by its name, I cannot pass the body of the component to the GetMinimumDistance function..
Or can I?
I would like to avoid to search the body again.
The Journal recording use Findobject(). But I read that it is preferably not to use at programming.
CODE --> vb
Dim component1 As Assemblies.Component = CType(workPart.ComponentAssembly.RootComponent.FindObject("COMPONENT model13 1"), Assemblies.Component) Dim body1 As Body = CType(component1.FindObject("PROTO#.Bodies|BLOCK(1)"), Body)----
kukelyk
kukelyk
It is a Diameter 20 cylinder substracted from the bottom of the electrode, sample attached.
If there are more bodies, the user picks the desired body.
Then determine the base CSYS, and reorient the body in a parent file, where it imports a CAM setup.
The CAM setup programs has an UDE with two points, for the BLK FORM.
So where I stuck: measure the body in the reoriented position.
The points (named MIN and MAX) are linked to the UDE, and has PMI dimensions associated. So if I have the measurements, I can easily reposition them.
My comments are hungarian mainly, so I added some english comment
CODE --> vb
Option Strict Off Imports System Imports NXOpen Imports System.IO Imports System.Math Imports NXOpen.UF Imports NXOpen.ASSEMBLIES Imports NXOpen.Utilities Imports System.Windows.Forms Imports System.Runtime.InteropServices '- - - - - - - - - - - - - - - - - - - - - - Module NXJournal Public Ses As Session = Session.GetSession() Public UISes As UI = UI.GetUI() Public UFSes As UFSession = UFSession.GetUFSession() Public workPart As NXOpen.Part = Ses.Parts.Work Public dp As Part = Ses.Parts.Display Public msg As NXMessageBox = UI.GetUI().NXMessageBox Public Class JournalDialog Inherits System.Windows.Forms.Form Dim UFSes As UFSession = UFSession.GetUFSession() Public Sub New() MyBase.New() ' The Me.InitializeComponent call is required for Windows Forms designer support. Me.InitializeComponent() ' ' TODO : Add constructor code after InitializeComponents ' Dim xPos, yPos As Short UFSes.Ui.GetDa1Coords(xPos, yPos) NXOpenUI.FormUtilities.ReparentForm(Me) NXOpenUI.FormUtilities.SetApplicationIcon(Me) Me.Location = New System.Drawing.Point(CType(xPos, Integer), CType(yPos, Integer)) End Sub ''' <summary> ''' Designer variable used to keep track of non-visual components. ''' </summary> Private components As System.ComponentModel.IContainer ''' <summary> ''' Disposes resources used by the form. ''' </summary> ''' <param name="disposing">true if managed resources should be disposed; otherwise, false.</param> Protected Overrides Sub Dispose(ByVal disposing As Boolean) If disposing Then If Not (components Is Nothing) Then components.Dispose() End If End If MyBase.Dispose(disposing) End Sub ''' <summary> ''' This method is required for Windows Forms designer support. ''' Do not change the method contents inside the source code editor. The Forms designer might ''' not be able to load this method if it was changed manually. ''' </summary> Private Sub InitializeComponent() Me.label1 = New System.Windows.Forms.Label Me.label2 = New System.Windows.Forms.Label Me.Felfogas = New System.Windows.Forms.TextBox Me.Szikrakoz = New System.Windows.Forms.TextBox Me.buttonCancel = New System.Windows.Forms.Button Me.buttonOK = New System.Windows.Forms.Button Me.SuspendLayout ' 'label1 ' Me.label1.FlatStyle = System.Windows.Forms.FlatStyle.System Me.label1.Location = New System.Drawing.Point(21, 19) Me.label1.Name = "label1" Me.label1.Size = New System.Drawing.Size(147, 24) Me.label1.TabIndex = 0 Me.label1.Text = "Felfogas szama" ' 'label2 ' Me.label2.FlatStyle = System.Windows.Forms.FlatStyle.System Me.label2.Location = New System.Drawing.Point(21, 49) Me.label2.Name = "label2" Me.label2.Size = New System.Drawing.Size(147, 24) Me.label2.TabIndex = 1 Me.label2.Text = "Szikrakoz" ' ' 'Felfogas ' Me.Felfogas.Location = New System.Drawing.Point(174, 16) Me.Felfogas.Name = "setup" Me.Felfogas.Size = New System.Drawing.Size(100, 20) Me.Felfogas.TabIndex = 4 Me.Felfogas.Text = "1" Me.Felfogas.TextAlign = System.Windows.Forms.HorizontalAlignment.Right ' 'Szikrakoz ' Me.Szikrakoz.Location = New System.Drawing.Point(174, 46) Me.Szikrakoz.Name = "Spark" Me.Szikrakoz.Size = New System.Drawing.Size(100, 20) Me.Szikrakoz.TabIndex = 5 Me.Szikrakoz.Text = "0.2" Me.Szikrakoz.TextAlign = System.Windows.Forms.HorizontalAlignment.Right ' 'buttonCancel ' Me.buttonCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel Me.buttonCancel.FlatStyle = System.Windows.Forms.FlatStyle.System Me.buttonCancel.Location = New System.Drawing.Point(49, 77) Me.buttonCancel.Name = "buttonCancel" Me.buttonCancel.Size = New System.Drawing.Size(75, 23) Me.buttonCancel.TabIndex = 8 Me.buttonCancel.Text = "Cancel" ' 'buttonOK ' Me.buttonOK.DialogResult = System.Windows.Forms.DialogResult.OK Me.buttonOK.FlatStyle = System.Windows.Forms.FlatStyle.System Me.buttonOK.Location = New System.Drawing.Point(174, 77) Me.buttonOK.Name = "buttonOK" Me.buttonOK.Size = New System.Drawing.Size(75, 23) Me.buttonOK.TabIndex = 9 Me.buttonOK.Text = "OK" ' 'JournalDialog ' Me.AcceptButton = Me.buttonOK Me.CancelButton = Me.buttonCancel Me.ClientSize = New System.Drawing.Size(301, 107) Me.Controls.Add(Me.buttonOK) Me.Controls.Add(Me.buttonCancel) Me.Controls.Add(Me.Szikrakoz) Me.Controls.Add(Me.Felfogas) Me.Controls.Add(Me.label2) Me.Controls.Add(Me.label1) Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog Me.MaximizeBox = false Me.MinimizeBox = false Me.Name = "JournalDialog" Me.Text = "Rohteil" Me.TopMost = true Me.ResumeLayout(false) Me.PerformLayout End Sub Private buttonOK As System.Windows.Forms.Button Private buttonCancel As System.Windows.Forms.Button Private Szikrakoz As System.Windows.Forms.TextBox Private Felfogas As System.Windows.Forms.TextBox Private label2 As System.Windows.Forms.Label Private label1 As System.Windows.Forms.Label Public Function GetFelfogasSzama() As Double Dim Value As String = Me.Felfogas.Text If String.IsNullOrEmpty(Value) Then Value = "0.0" Return CDbl(Value) End Function Public Function GetSzikrakozErtek() As Double Dim Value As String = Me.Szikrakoz.Text If String.IsNullOrEmpty(Value) Then Value = "0.0" Return CDbl(Value) End Function Public Function GetSzikrakozString() As String Dim SzkString As String = Me.Szikrakoz.Text If String.IsNullOrEmpty(SzkString) Then SzkString = "0.0" Return SzkString End Function End Class '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# Sub Main() Ses.ListingWindow.Open Ses.ListingWindow.WriteLine("________ujra_______" ) Dim WpSolidsNo as integer = 0 Dim WpVisibleSolidsNo as integer = 0 Dim currprt as String = Ses.Parts.Work.FullPath Dim currprt_FullPathWoutExt as string = Left$(currprt, InStrRev(currprt, ".") -1 ) 'find last dot, and trim Dim E_file_name as string = Right$(currprt_FullPathWoutExt, ( Len(currprt_FullPathWoutExt) - InStrRev(currprt_FullPathWoutExt, "\")) ) Dim MarkId As Session.UndoMarkId Dim Neighbourfacetype As Integer = Nothing Dim facetype As Integer = Nothing Dim kerulet as Double Dim Xdirection , Zdirection as Direction Dim Oldalelhossz as Double = 0 Dim Vizsgalt_elhossz as Double = 0 Dim pointPos as Integer 'pont ellenorzesehez, hogy kivul van-e a testen Dim XVector(2), ZVector(2), YVector(2), BasePoint(2), ZplusdirPoint(2), CenterPoint(2) As Double Dim E_solidbody As Body Dim pnt As Point3d 'defaults XVector(0) = 1.0 XVector(1) = 0.0 XVector(2) = 0.0 YVector(0) = 0.0 YVector(1) = 1.0 YVector(2) = 0.0 ZVector(0) = 0.0 ZVector(1) = 0.0 ZVector(2) = 1.0 BasePoint(0) = 0.0 BasePoint(1) = 0.0 BasePoint(2) = 0.0 ZplusdirPoint (0) = 0.0 ZplusdirPoint (1) = 0.0 ZplusdirPoint (2) = 1.0 If (dp Is Nothing) Then msg.Show("", NXOpen.NXMessageBox.DialogType.Error, "No Display Part !") Return End If 'szamlaljuk meg a testeket For Each aBody As Body In workPart.Bodies If aBody.IsSolidBody = True Then WpSolidsNo +=1 If NOT aBody.IsBlanked Then 'if visible solidbody WpVisibleSolidsNo +=1 End If End If Next 'Ses.ListingWindow.WriteLine("solids: " & WpSolidsNo & ", visible of them: " & WpVisibleSolidsNo) If WpSolidsNo = 0 Then MsgBox( "no Solids in part" ) Return Else If WpSolidsNo >1 Then If WpVisibleSolidsNo > 1 'ha tobb lathato solid van... UISes.SelectionManager.SelectObject("i have found more solids", "select electrode", Selection.SelectionScope.WorkPart, False, False, E_solidbody, pnt) Else For Each bBody As Body In workPart.Bodies If bBody.IsBlanked = False Then E_solidbody =bBody End If Next End If Else If WpSolidsNo = 1 Then For Each cBody As Body In workPart.Bodies If cBody.IsBlanked = True Then cBody.Unblank End If E_solidbody = cBody Next End If 'Ses.ListingWindow.WriteLine(E_solidbody.Name ) For Each aFace As Face In E_solidbody.GetFaces UFSes.Modl.AskFaceType(aFace.Tag, facetype) If facetype = 16 Then 'if cylindrical face For Each aEdge As Edge In aFace.GetEdges kerulet = Math.Round((aEdge.GetLength()),6) If kerulet = Math.Round((UFConstants.PI * 20),6) Then 'and the edge length = 20pi then For Each NeighbourFace as face In aEdge.GetFaces 'get edge parents UFSes.Modl.AskFaceType(NeighbourFace.Tag, Neighbourfacetype) Dim NeighbourFaceEdges() As Edge = NeighbourFace.GetEdges() 'get parents' edges 'If (Neighbourfacetype = 22) & (NeighbourFaceEdges.GetUpperBound(0) > 2) Then If (Neighbourfacetype = 22) Then 'if the face next to the cylinder is planar If NeighbourFaceEdges.GetUpperBound(0) > 2 Then 'and has more than 3 boundary edges BasePoint = get_edge_center(aEdge) XVector = get_longest_edge_vec(NeighbourFaceEdges) Else ZplusdirPoint = get_edge_center(aEdge) End if End if Next End If Next End If Next UFSes.Vec3.Sub(ZplusdirPoint, BasePoint, ZVector ) YVector(0) = (ZVector(1) * XVector(2) - ZVector(2) * XVector(1)) YVector(1) = (ZVector(2) * XVector(0) - ZVector(0) * XVector(2)) YVector(2) = (ZVector(0) * XVector(1) - ZVector(1) * XVector(0)) Dim mtx As NXOpen.Tag = NXOpen.Tag.Null Dim new_csys As NXOpen.Tag = NXOpen.Tag.Null Dim mtx_vals(8) As Double ufses.Mtx3.Initialize(XVector, YVector, mtx_vals) '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'MEASURE Electrode height ' Darab magassaganak meghatarozasa: ' eltolt sik letrehozasa mereshez ' meres '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim tPlane as tag tPlane = tag.Null Dim dPoint(2), dDirection(2) As Double Dim szorzo as Double = 1000 dpoint(0) = Basepoint(0) + szorzo * Zvector(0) dpoint(1) = Basepoint(1) + szorzo * Zvector(1) dpoint(2) = Basepoint(2) + szorzo * Zvector(2) Dim Zvectorlength as Double = Sqrt(Zvector(0)*Zvector(0)+Zvector(1)*Zvector(1)+Zvector(2)*Zvector(2) ) dDirection(0)= Zvector(0)/ Zvectorlength dDirection(1)= Zvector(1)/ Zvectorlength dDirection(2)= Zvector(2)/ Zvectorlength MarkID = ses.SetUndoMark(Session.MarkVisibility.Invisible, "Datum Plane") ufses.Modl.CreateFixedDplane(dPoint, dDirection, tPlane) Dim selpnt(1) As Point3d Dim dist, accu, magassag As Double dist = ses.Measurement.GetMinimumDistance(E_solidbody, NXObjectManager.Get(tPlane), selpnt(0), selpnt(1), accu) Ses.UpdateManager.AddToDeleteList( NXObjectManager.Get(tPlane) ) Ses.UpdateManager.DoUpdate(MarkID) Ses.DeleteUndoMark(MarkID, "Datum Plane") magassag = szorzo-dist '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim MachiningZero(2) As Double MachiningZero(0)= Basepoint(0)+ magassag * dDirection(0) MachiningZero(1)= Basepoint(1)+ magassag * dDirection(1) MachiningZero(2)= Basepoint(2)+ magassag * dDirection(2) ufses.Csys.CreateMatrix(mtx_vals, mtx) ufses.Csys.CreateCsys(MachiningZero, mtx, new_csys) 'Tudjuk: 'elektroda file: E_file_name 'solidbody: E_solidbody 'eltolas: MachiningZero 'Orientacio: mtx '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'parent prt letrehozasa marashoz, pozicionalas: MachiningZero a 0,0,0-ba '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Try Dim MyForm As New JournalDialog MyForm.Text = "Elektrodamaras" Dim dFelfogasSzama, dSzikrakozErtek As Double Try If MyForm.ShowDialog = Windows.Forms.DialogResult.OK Then dFelfogasSzama = MyForm.GetFelfogasSzama dSzikrakozErtek = MyForm.GetSzikrakozErtek Dim fileNew1 As FileNew fileNew1 = Ses.Parts.FileNew() fileNew1.TemplateFileName = "Blank" fileNew1.Application = FileNewApplication.Gateway fileNew1.Units = Part.Units.Millimeters 'fileNew1.TemplateType = FileNewTemplateType.Item 'Dim currprt as String = Ses.Parts.Work.FullPath Dim addprt as String If dSzikrakozErtek = 0 Then addprt = "-" & dFelfogasSzama & "-00" & ".prt" Else addprt = "-" & dFelfogasSzama & "-" & dSzikrakozErtek*200 & ".prt" End If '------------ Dim f, f2 as string f = E_file_name f2 = Replace (f, "_", "") f2 = Replace (f2, "-", "") Dim Epos as integer = InStr(f2, "E") If Len(Left$(f2, Epos )) = 7 Then f2 = Replace (f2, "E", "00E") & addprt Else f2 = f2 & addprt End If Dim parentprt as String = Replace (currprt, E_file_name, f2) fileNew1.NewFileName = parentprt fileNew1.MasterFileName = "" fileNew1.UseBlankTemplate = True fileNew1.MakeDisplayedPart = True Dim nXObject8 As NXObject nXObject8 = fileNew1.Commit() workPart = Ses.Parts.Work fileNew1.Destroy() 'Dim result1 As Boolean = Ses.IsCamSessionInitialized() 'Dim kinematicConfigurator1 As SIM.KinematicConfigurator = workPart.CreateKinematicConfigurator() Ses.ListingWindow.WriteLine(parentprt) Dim part1 As Part = CType(Ses.Parts.FindObject( E_file_name ), Part) Dim basePoint1 As Point3d basePoint1.x=-MachiningZero(0) basePoint1.y=-MachiningZero(1) basePoint1.z=-MachiningZero(2) Dim orientation1 As Matrix3x3 orientation1.Xx = 1.0 orientation1.Xy = 0.0 orientation1.Xz = 0.0 orientation1.Yx = 0.0 orientation1.Yy = 1.0 orientation1.Yz = 0.0 orientation1.Zx = 0.0 orientation1.Zy = 0.0 orientation1.Zz = 1.0 Dim partLoadStatus1 As PartLoadStatus Dim component1 As Assemblies.Component component1 = workPart.ComponentAssembly.AddMasterPartComponent(part1, "None", E_file_name, basePoint1, orientation1, -1, partLoadStatus1) partLoadStatus1.Dispose() '---------------------- 'expression from the input value '---------------------- Dim myExpName As String = "offset" Dim myStringValue As String = "-" & (MyForm.GetSzikrakozString()) Dim MyExpression As Expression Dim expExists As Boolean = False For Each myExp As Expression In workPart.Expressions.ToArray If myExp.Name = myExpName Then expExists = True MyExpression = myExp Exit For End If Next Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit) If Not expExists Then MyExpression = workPart.Expressions.CreateWithUnits(myExpName & "=" & myStringValue, unit1) Else MyExpression.RightHandSide = myStringValue End If '---------------------- 'Ses.ListingWindow.Open 'Ses.ListingWindow.WriteLine("") '---------------------- End If Catch ex As NXException ' displayedPart.LogFile.WriteLine(ex.ToString) Finally UFSes.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM) UFSes.Abort.EnableAbort() End Try MyForm.Close MyForm.Dispose MyForm = Nothing Catch ex As Exception MsgBox(ex.Message, MsgBoxStyle.Critical, "Error, Aborting!") End Try Application.Exit() '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'reorient electrode part according to calculated Matrix '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim Alkatresz As Assemblies.Component For Each MyComponent As Assemblies.Component In workPart.ComponentAssembly.RootComponent.GetChildren 'Ses.listingwindow.Writeline("MyComponent.name.ToLower()= " & MyComponent.name.ToLower() & "E_file_name.ToLower() :" & E_file_name.ToLower()) If MyComponent.name.ToLower() = E_file_name.ToLower() Then Alkatresz = MyComponent End If Next Dim NullEltolas As Vector3d = New Vector3d(0, 0, 0) Dim ForgatasiMtx As Matrix3x3 ForgatasiMtx.Xx = mtx_vals(0) ForgatasiMtx.Xy = mtx_vals(1) ForgatasiMtx.Xz = mtx_vals(2) ForgatasiMtx.Yx = mtx_vals(3) ForgatasiMtx.Yy = mtx_vals(4) ForgatasiMtx.Yz = mtx_vals(5) ForgatasiMtx.Zx = mtx_vals(6) ForgatasiMtx.Zy = mtx_vals(7) ForgatasiMtx.Zz = mtx_vals(8) 'Ses.listingwindow.Writeline( "ForgatasiMtx" ) 'Ses.listingwindow.Writeline(ForgatasiMtx.Xx & "; " & ForgatasiMtx.Xy & "; " & ForgatasiMtx.Xz) 'Ses.listingwindow.Writeline(ForgatasiMtx.Yx & "; " & ForgatasiMtx.Yy & "; " & ForgatasiMtx.Yz) 'Ses.listingwindow.Writeline(ForgatasiMtx.Zx & "; " & ForgatasiMtx.Zy & "; " & ForgatasiMtx.Zz) Dim moving as integer = Movepart(NullEltolas, ForgatasiMtx, Alkatresz) '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'IMPORT CAM '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim partImporter1 As PartImporter partImporter1 = workPart.ImportManager.CreatePartImporter() partImporter1.FileName = "y:\_NX\EF_custom\templates\Elektrodamaras_negoffset.prt" 'Ses.ListingWindow.WriteLine(partImporter1.FileName) partImporter1.Scale = 1.0 partImporter1.CreateNamedGroup = False partImporter1.ImportViews = False partImporter1.ImportCamObjects = True partImporter1.LayerOption = PartImporter.LayerOptionType.Original partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work Dim nXMatrix1 As NXMatrix = CType(workPart.NXMatrices.FindObject("WCS"), NXMatrix) partImporter1.DestinationCoordinateSystem = nXMatrix1 Dim destinationPoint1 As Point3d = New Point3d(0.0, 0.0, 0.0) partImporter1.DestinationPoint = destinationPoint1 Dim nXObject7 As NXObject nXObject7 = partImporter1.Commit() partImporter1.Destroy() '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'Move Minmaxpoints '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'E_file_name 'solidbody: E_solidbody 'Dim bod as Body = E_solidbody In E_file_name 'Dim component11 As Assemblies.Component = E_file_name 'Dim bod as Body =CType(component11.E_solidbody, Body) 'Dim outp(3) as Double 'outp = Ask_XY_bounds (bod) 'For Each aPoint As Point In workPart.Points ' If apoint.name= "Min" ' aPoint.x = outp(1) ' aPoint.y = outp(3) ' aPoint.z = -magassag ' End If ' If apoint.name= "Max" ' apoint.x = outp(0) ' apoint.y = outp(2) ' apoint.z = 0 ' End If 'Next '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- End Sub '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Function get_longest_edge_vec(ByVal edges() As Edge) As Double() Dim inx As Integer = 0 Dim Oldalelhossz as Double = 0 Dim vec(2) as Double vec(0)=1 vec(1)=0 vec(2)=0 For inx = 0 To edges.GetUpperBound(0) If edges(inx).SolidEdgeType.ToString = "Linear" Then Dim Vizsgalt_elhossz as Double = edges(inx).GetLength() If Vizsgalt_elhossz > Oldalelhossz Then Oldalelhossz = Vizsgalt_elhossz Dim sp(2) As Double Dim ep(2) As Double Dim lineData As UFCurve.Line 'lineData.start_point = sp 'lineData.end_point = ep UFSes.Curve.AskLineData(edges(inx).Tag, lineData) sp = lineData.start_point ep = lineData.end_point UFSes.Vec3.Sub(ep, sp, vec) vec(0)= vec(0) / Oldalelhossz vec(1)= vec(1) / Oldalelhossz vec(2)= vec(2) / Oldalelhossz End If End If Next inx Return vec End Function Function get_edge_center(ByVal aEdge As Edge) As Double() Dim arc_evaluator As System.IntPtr Dim arc_data As NXOpen.UF.UFEval.Arc Dim aEdge_tag As Tag = aEdge.Tag Dim pointPos as integer 'pont ellenorzesehez, hogy kivul van-e a testen UFSes.Eval.Initialize(aEdge_tag, arc_evaluator) UFSes.Eval.AskArc(arc_evaluator, arc_data) Return arc_data.center End Function Public Function Ask_XY_bounds(ByVal bod as Body) As Double() Dim iCount, iIndex As Integer Dim tPlane as tag Dim dist(3), outp(3), dPoint(2), dDirection(2) As Double Dim selpnt(1), pnt As Point3d Dim accu As New Double Dim MarkId As Session.UndoMarkId tPlane = tag.Null For iCount = 0 To 3 Select Case iCount Case 0 dPoint(0) = 5000 dDirection(0) = 1 'XMAX Case 1 dPoint(0) = -5000 dDirection(0) = -1 'XMIN Case 2 dPoint(0) = 0 dPoint(1) = 5000 dDirection(0) = 0 dDirection(1) = 1 Case 3 dPoint(1) = -5000 dDirection(1) = 1 'YMAX End Select MarkID = ses.SetUndoMark(Session.MarkVisibility.Invisible, "Datum Plane") ufses.Modl.CreateFixedDplane(dPoint, dDirection, tPlane) dist(iCount) = ses.Measurement.GetMinimumDistance(bod, NXObjectManager.Get(tPlane), selpnt(0), selpnt(1), accu) Ses.UpdateManager.AddToDeleteList( NXObjectManager.Get(tPlane) ) Ses.UpdateManager.DoUpdate(MarkID) Ses.DeleteUndoMark(MarkID, "Datum Plane") outp(0) = dist(1) - 5000 outp(1) = dist(3) - 5000 outp(2) = 5000 - dist(0) outp(3) = 5000 - dist(2) Next Return outp End Function Public Function Movepart(ByVal eltolas As Vector3d, forgatasiMtx As Matrix3x3, mozgatandoAlkatresz As Assemblies.Component ) As Integer Dim nullAssemblies_Component As Assemblies.Component = Nothing Dim compoPositioner As Positioning.ComponentPositioner = workPart.ComponentAssembly.Positioner Dim My_network As Positioning.Network My_network = compoPositioner.EstablishNetwork() Dim compoNetwork As Positioning.ComponentNetwork = CType(My_network, Positioning.ComponentNetwork) compoNetwork.MoveObjectsState = True compoNetwork.DisplayComponent = nullAssemblies_Component compoNetwork.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing compoNetwork.RemoveAllConstraints() Dim mozgatandoObjects(0) As NXObject mozgatandoObjects(0) = mozgatandoAlkatresz compoNetwork.SetMovingGroup(mozgatandoObjects) compoNetwork.BeginDrag() compoNetwork.DragByTransform(eltolas, forgatasiMtx) compoNetwork.EndDrag() compoNetwork.ResetDisplay() compoNetwork.ApplyToModel() compoNetwork.Solve() compoPositioner.ClearNetwork() compoPositioner.DeleteNonPersistentConstraints() compoPositioner.EndMoveComponent() Return 1 End Function End Module----
kukelyk
The journal references a file that I do not have and I also do not currently have access to a CAM license. I've commented out several lines of code to get it to run on my system.
The journal doesn't complete all its tasks as intended, but I think I have a better understanding of the problem. In essence, you create a reference to a body in the work part then create a new assembly file and add the initial work part as a component; now you want to measure the distance from the initial body reference (now contained in a component in the current assembly) to another object in the assembly. Is this correct?
kukelyk
Are you getting some error or incorrect result when you try that?
I cannot figure out how to reference that body.
if I uncomment and modify
CODE --> vb
CODE --> vb
what should I put into the parenthesis? Ask_XY_bounds(??)
kukelyk
outp(0) = X min
outp(1) = Y min
outp(2) = X max
outp(3) = Y max
The values reported should be with respect to the display part's absolute coordinate system. What type of values are you getting vs. what values do you expect? I have not had a chance to thoroughly try the Ask_XY_bounds function yet.
I ran the attached journal in an OOTB NX7, and I got this:
(I removed some code, what needs Custom_dirs)
Real bounding dimensions after repositioning (measured by hand..):
Xmin = -14.400000000
Ymin = -11.000000000
Xmax = 57.600000000
Ymax = 11.000000000
values obtained by ASK_XY_Bounds()
Xmin= -55.2467808842584;
Ymin= 10.5226781572328;
Xmax= 22.8224307161472;
Ymax= 49.4481738878103
These are the bounding dimensions in the Csys of the sample_electrode.x_t
CODE --> vb
Option Strict Off Imports System Imports NXOpen Imports System.IO Imports System.Math Imports NXOpen.UF Imports NXOpen.ASSEMBLIES Imports NXOpen.Utilities Imports System.Windows.Forms Imports System.Runtime.InteropServices '- - - - - - - - - - - - - - - - - - - - - - Module NXJournal Public Ses As Session = Session.GetSession() Public UISes As UI = UI.GetUI() Public UFSes As UFSession = UFSession.GetUFSession() Public workPart As NXOpen.Part = Ses.Parts.Work Public dp As Part = Ses.Parts.Display Public msg As NXMessageBox = UI.GetUI().NXMessageBox Public Class JournalDialog Inherits System.Windows.Forms.Form Dim UFSes As UFSession = UFSession.GetUFSession() Public Sub New() MyBase.New() ' The Me.InitializeComponent call is required for Windows Forms designer support. Me.InitializeComponent() ' ' TODO : Add constructor code after InitializeComponents ' Dim xPos, yPos As Short UFSes.Ui.GetDa1Coords(xPos, yPos) NXOpenUI.FormUtilities.ReparentForm(Me) NXOpenUI.FormUtilities.SetApplicationIcon(Me) Me.Location = New System.Drawing.Point(CType(xPos, Integer), CType(yPos, Integer)) End Sub ''' <summary> ''' Designer variable used to keep track of non-visual components. ''' </summary> Private components As System.ComponentModel.IContainer ''' <summary> ''' Disposes resources used by the form. ''' </summary> ''' <param name="disposing">true if managed resources should be disposed; otherwise, false.</param> Protected Overrides Sub Dispose(ByVal disposing As Boolean) If disposing Then If Not (components Is Nothing) Then components.Dispose() End If End If MyBase.Dispose(disposing) End Sub ''' <summary> ''' This method is required for Windows Forms designer support. ''' Do not change the method contents inside the source code editor. The Forms designer might ''' not be able to load this method if it was changed manually. ''' </summary> Private Sub InitializeComponent() Me.label1 = New System.Windows.Forms.Label Me.label2 = New System.Windows.Forms.Label Me.Felfogas = New System.Windows.Forms.TextBox Me.Szikrakoz = New System.Windows.Forms.TextBox Me.buttonCancel = New System.Windows.Forms.Button Me.buttonOK = New System.Windows.Forms.Button Me.SuspendLayout ' 'label1 ' Me.label1.FlatStyle = System.Windows.Forms.FlatStyle.System Me.label1.Location = New System.Drawing.Point(21, 19) Me.label1.Name = "label1" Me.label1.Size = New System.Drawing.Size(147, 24) Me.label1.TabIndex = 0 Me.label1.Text = "Felfogas szama" ' 'label2 ' Me.label2.FlatStyle = System.Windows.Forms.FlatStyle.System Me.label2.Location = New System.Drawing.Point(21, 49) Me.label2.Name = "label2" Me.label2.Size = New System.Drawing.Size(147, 24) Me.label2.TabIndex = 1 Me.label2.Text = "Szikrakoz" ' ' 'Felfogas ' Me.Felfogas.Location = New System.Drawing.Point(174, 16) Me.Felfogas.Name = "Felfogas" Me.Felfogas.Size = New System.Drawing.Size(100, 20) Me.Felfogas.TabIndex = 4 Me.Felfogas.Text = "1" Me.Felfogas.TextAlign = System.Windows.Forms.HorizontalAlignment.Right ' 'Szikrakoz ' Me.Szikrakoz.Location = New System.Drawing.Point(174, 46) Me.Szikrakoz.Name = "Szikrakoz" Me.Szikrakoz.Size = New System.Drawing.Size(100, 20) Me.Szikrakoz.TabIndex = 5 Me.Szikrakoz.Text = "0.2" Me.Szikrakoz.TextAlign = System.Windows.Forms.HorizontalAlignment.Right ' 'buttonCancel ' Me.buttonCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel Me.buttonCancel.FlatStyle = System.Windows.Forms.FlatStyle.System Me.buttonCancel.Location = New System.Drawing.Point(49, 77) Me.buttonCancel.Name = "buttonCancel" Me.buttonCancel.Size = New System.Drawing.Size(75, 23) Me.buttonCancel.TabIndex = 8 Me.buttonCancel.Text = "Cancel" ' 'buttonOK ' Me.buttonOK.DialogResult = System.Windows.Forms.DialogResult.OK Me.buttonOK.FlatStyle = System.Windows.Forms.FlatStyle.System Me.buttonOK.Location = New System.Drawing.Point(174, 77) Me.buttonOK.Name = "buttonOK" Me.buttonOK.Size = New System.Drawing.Size(75, 23) Me.buttonOK.TabIndex = 9 Me.buttonOK.Text = "OK" ' 'JournalDialog ' Me.AcceptButton = Me.buttonOK Me.CancelButton = Me.buttonCancel Me.ClientSize = New System.Drawing.Size(301, 107) Me.Controls.Add(Me.buttonOK) Me.Controls.Add(Me.buttonCancel) Me.Controls.Add(Me.Szikrakoz) Me.Controls.Add(Me.Felfogas) Me.Controls.Add(Me.label2) Me.Controls.Add(Me.label1) Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog Me.MaximizeBox = false Me.MinimizeBox = false Me.Name = "JournalDialog" Me.Text = "Rohteil" Me.TopMost = true Me.ResumeLayout(false) Me.PerformLayout End Sub Private buttonOK As System.Windows.Forms.Button Private buttonCancel As System.Windows.Forms.Button Private Szikrakoz As System.Windows.Forms.TextBox Private Felfogas As System.Windows.Forms.TextBox Private label2 As System.Windows.Forms.Label Private label1 As System.Windows.Forms.Label Public Function GetFelfogasSzama() As Double Dim Value As String = Me.Felfogas.Text If String.IsNullOrEmpty(Value) Then Value = "0.0" Return CDbl(Value) End Function Public Function GetSzikrakozErtek() As Double Dim Value As String = Me.Szikrakoz.Text If String.IsNullOrEmpty(Value) Then Value = "0.0" Return CDbl(Value) End Function Public Function GetSzikrakozString() As String Dim SzkString As String = Me.Szikrakoz.Text If String.IsNullOrEmpty(SzkString) Then SzkString = "0.0" Return SzkString End Function End Class '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# Sub Main() Ses.ListingWindow.Open 'Ses.ListingWindow.WriteLine("________ujra_______" ) Dim WpSolidsNo as integer = 0 Dim WpVisibleSolidsNo as integer = 0 Dim currprt as String = Ses.Parts.Work.FullPath Dim currprt_FullPathWoutExt as string = Left$(currprt, InStrRev(currprt, ".") -1 ) 'find last dot, and trim Dim E_file_name as string = Right$(currprt_FullPathWoutExt, ( Len(currprt_FullPathWoutExt) - InStrRev(currprt_FullPathWoutExt, "\")) ) Dim MarkId As Session.UndoMarkId Dim Neighbourfacetype As Integer = Nothing Dim facetype As Integer = Nothing Dim kerulet as Double Dim Xdirection , Zdirection as Direction Dim Oldalelhossz as Double = 0 Dim Vizsgalt_elhossz as Double = 0 Dim pointPos as Integer 'pont ellenorzesehez, hogy kivul van-e a testen Dim XVector(2), ZVector(2), YVector(2), BasePoint(2), ZplusdirPoint(2), CenterPoint(2) As Double Dim E_solidbody As Body Dim pnt As Point3d 'defaults XVector(0) = 1.0 XVector(1) = 0.0 XVector(2) = 0.0 YVector(0) = 0.0 YVector(1) = 1.0 YVector(2) = 0.0 ZVector(0) = 0.0 ZVector(1) = 0.0 ZVector(2) = 1.0 BasePoint(0) = 0.0 BasePoint(1) = 0.0 BasePoint(2) = 0.0 ZplusdirPoint (0) = 0.0 ZplusdirPoint (1) = 0.0 ZplusdirPoint (2) = 1.0 If (dp Is Nothing) Then msg.Show("", NXOpen.NXMessageBox.DialogType.Error, "No Display Part !") Return End If 'szamlaljuk meg a testeket For Each aBody As Body In workPart.Bodies If aBody.IsSolidBody = True Then WpSolidsNo +=1 If NOT aBody.IsBlanked Then 'if visible solidbody WpVisibleSolidsNo +=1 End If End If Next 'Ses.ListingWindow.WriteLine("solids: " & WpSolidsNo & ", visible of them: " & WpVisibleSolidsNo) If WpSolidsNo = 0 Then MsgBox( "A modell nem tartalmaz Solid-okat" ) Return Else If WpSolidsNo >1 Then If WpVisibleSolidsNo > 1 'ha tobb lathato solid van... UISes.SelectionManager.SelectObject("Tobb testet talaltam..", "Valaszd ki az elektrodat", Selection.SelectionScope.WorkPart, False, False, E_solidbody, pnt) Else For Each bBody As Body In workPart.Bodies If bBody.IsBlanked = False Then E_solidbody =bBody End If Next End If Else If WpSolidsNo = 1 Then For Each cBody As Body In workPart.Bodies If cBody.IsBlanked = True Then cBody.Unblank End If E_solidbody = cBody Next End If 'Ses.ListingWindow.WriteLine(E_solidbody.Name ) For Each aFace As Face In E_solidbody.GetFaces UFSes.Modl.AskFaceType(aFace.Tag, facetype) If facetype = 16 Then 'if cylindrical face For Each aEdge As Edge In aFace.GetEdges kerulet = Math.Round((aEdge.GetLength()),6) If kerulet = Math.Round((UFConstants.PI * 20),6) Then 'and the edge length = 20pi then For Each NeighbourFace as face In aEdge.GetFaces 'get edge parents UFSes.Modl.AskFaceType(NeighbourFace.Tag, Neighbourfacetype) Dim NeighbourFaceEdges() As Edge = NeighbourFace.GetEdges() 'get parents' edges 'If (Neighbourfacetype = 22) & (NeighbourFaceEdges.GetUpperBound(0) > 2) Then If (Neighbourfacetype = 22) Then 'if the face next to the cylinder is planar If NeighbourFaceEdges.GetUpperBound(0) > 2 Then 'and has more than 3 boundary edges BasePoint = get_edge_center(aEdge) XVector = get_longest_edge_vec(NeighbourFaceEdges) Else ZplusdirPoint = get_edge_center(aEdge) End if End if Next End If Next End If Next UFSes.Vec3.Sub(ZplusdirPoint, BasePoint, ZVector ) YVector(0) = (ZVector(1) * XVector(2) - ZVector(2) * XVector(1)) YVector(1) = (ZVector(2) * XVector(0) - ZVector(0) * XVector(2)) YVector(2) = (ZVector(0) * XVector(1) - ZVector(1) * XVector(0)) Dim mtx As NXOpen.Tag = NXOpen.Tag.Null Dim new_csys As NXOpen.Tag = NXOpen.Tag.Null Dim mtx_vals(8) As Double ufses.Mtx3.Initialize(XVector, YVector, mtx_vals) '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- ' Darab magassaganak meghatarozasa: ' eltolt sik letrehozasa mereshez ' meres '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim tPlane as tag tPlane = tag.Null Dim dPoint(2), dDirection(2) As Double Dim szorzo as Double = 1000 dpoint(0) = Basepoint(0) + szorzo * Zvector(0) dpoint(1) = Basepoint(1) + szorzo * Zvector(1) dpoint(2) = Basepoint(2) + szorzo * Zvector(2) Dim Zvectorlength as Double = Sqrt(Zvector(0)*Zvector(0)+Zvector(1)*Zvector(1)+Zvector(2)*Zvector(2) ) dDirection(0)= Zvector(0)/ Zvectorlength dDirection(1)= Zvector(1)/ Zvectorlength dDirection(2)= Zvector(2)/ Zvectorlength MarkID = ses.SetUndoMark(Session.MarkVisibility.Invisible, "Datum Plane") ufses.Modl.CreateFixedDplane(dPoint, dDirection, tPlane) Dim selpnt(1) As Point3d Dim dist, accu, magassag As Double dist = ses.Measurement.GetMinimumDistance(E_solidbody, NXObjectManager.Get(tPlane), selpnt(0), selpnt(1), accu) Ses.UpdateManager.AddToDeleteList( NXObjectManager.Get(tPlane) ) Ses.UpdateManager.DoUpdate(MarkID) Ses.DeleteUndoMark(MarkID, "Datum Plane") magassag = szorzo-dist '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim MachiningZero(2) As Double MachiningZero(0)= Basepoint(0)+ magassag * dDirection(0) MachiningZero(1)= Basepoint(1)+ magassag * dDirection(1) MachiningZero(2)= Basepoint(2)+ magassag * dDirection(2) ufses.Csys.CreateMatrix(mtx_vals, mtx) ufses.Csys.CreateCsys(MachiningZero, mtx, new_csys) 'Tudjuk: 'elektroda file: E_file_name 'solidbody: E_solidbody 'eltolas: MachiningZero 'Orientacio: mtx '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'parent prt letrehozasa marashoz, pozicionalas: MachiningZero a 0,0,0-ba '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Try Dim MyForm As New JournalDialog MyForm.Text = "Elektrodamaras" Dim dFelfogasSzama, dSzikrakozErtek As Double Try If MyForm.ShowDialog = Windows.Forms.DialogResult.OK Then dFelfogasSzama = MyForm.GetFelfogasSzama dSzikrakozErtek = MyForm.GetSzikrakozErtek Dim fileNew1 As FileNew fileNew1 = Ses.Parts.FileNew() fileNew1.TemplateFileName = "Blank" fileNew1.Application = FileNewApplication.Gateway fileNew1.Units = Part.Units.Millimeters 'fileNew1.TemplateType = FileNewTemplateType.Item 'Dim currprt as String = Ses.Parts.Work.FullPath Dim addprt as String If dSzikrakozErtek = 0 Then addprt = "-" & dFelfogasSzama & "-00" & ".prt" Else addprt = "-" & dFelfogasSzama & "-" & dSzikrakozErtek*200 & ".prt" End If '------------ Dim f, f2 as string f = E_file_name f2 = Replace (f, "_", "") f2 = Replace (f2, "-", "") Dim Epos as integer = InStr(f2, "E") If Len(Left$(f2, Epos )) = 7 Then f2 = Replace (f2, "E", "00E") & addprt Else f2 = f2 & addprt End If Dim parentprt as String = Replace (currprt, E_file_name, f2) fileNew1.NewFileName = parentprt fileNew1.MasterFileName = "" fileNew1.UseBlankTemplate = True fileNew1.MakeDisplayedPart = True Dim nXObject8 As NXObject nXObject8 = fileNew1.Commit() workPart = Ses.Parts.Work fileNew1.Destroy() 'Dim result1 As Boolean = Ses.IsCamSessionInitialized() 'Dim kinematicConfigurator1 As SIM.KinematicConfigurator = workPart.CreateKinematicConfigurator() ' Ses.ListingWindow.WriteLine(parentprt) Dim part1 As Part = CType(Ses.Parts.FindObject( E_file_name ), Part) Dim basePoint1 As Point3d basePoint1.x=-MachiningZero(0) basePoint1.y=-MachiningZero(1) basePoint1.z=-MachiningZero(2) Dim orientation1 As Matrix3x3 orientation1.Xx = 1.0 orientation1.Xy = 0.0 orientation1.Xz = 0.0 orientation1.Yx = 0.0 orientation1.Yy = 1.0 orientation1.Yz = 0.0 orientation1.Zx = 0.0 orientation1.Zy = 0.0 orientation1.Zz = 1.0 Dim partLoadStatus1 As PartLoadStatus Dim component1 As Assemblies.Component component1 = workPart.ComponentAssembly.AddMasterPartComponent(part1, "None", E_file_name, basePoint1, orientation1, -1, partLoadStatus1) partLoadStatus1.Dispose() '---------------------- 'expression from the input value '---------------------- Dim myExpName As String = "offset" Dim myStringValue As String = "-" & (MyForm.GetSzikrakozString()) Dim MyExpression As Expression Dim expExists As Boolean = False For Each myExp As Expression In workPart.Expressions.ToArray If myExp.Name = myExpName Then expExists = True MyExpression = myExp Exit For End If Next Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit) If Not expExists Then MyExpression = workPart.Expressions.CreateWithUnits(myExpName & "=" & myStringValue, unit1) Else MyExpression.RightHandSide = myStringValue End If '---------------------- 'Ses.ListingWindow.Open 'Ses.ListingWindow.WriteLine("") '---------------------- End If Catch ex As NXException ' displayedPart.LogFile.WriteLine(ex.ToString) Finally UFSes.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM) UFSes.Abort.EnableAbort() End Try MyForm.Close MyForm.Dispose MyForm = Nothing Catch ex As Exception MsgBox(ex.Message, MsgBoxStyle.Critical, "Error, Aborting!") End Try Application.Exit() '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'reorient electrode part according to calculated Matrix '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Dim Alkatresz As Assemblies.Component For Each MyComponent As Assemblies.Component In workPart.ComponentAssembly.RootComponent.GetChildren 'Ses.listingwindow.Writeline("MyComponent.name.ToLower()= " & MyComponent.name.ToLower() & "E_file_name.ToLower() :" & E_file_name.ToLower()) If MyComponent.name.ToLower() = E_file_name.ToLower() Then Alkatresz = MyComponent End If Next Dim NullEltolas As Vector3d = New Vector3d(0, 0, 0) Dim ForgatasiMtx As Matrix3x3 ForgatasiMtx.Xx = mtx_vals(0) ForgatasiMtx.Xy = mtx_vals(1) ForgatasiMtx.Xz = mtx_vals(2) ForgatasiMtx.Yx = mtx_vals(3) ForgatasiMtx.Yy = mtx_vals(4) ForgatasiMtx.Yz = mtx_vals(5) ForgatasiMtx.Zx = mtx_vals(6) ForgatasiMtx.Zy = mtx_vals(7) ForgatasiMtx.Zz = mtx_vals(8) 'Ses.listingwindow.Writeline( "ForgatasiMtx" ) 'Ses.listingwindow.Writeline(ForgatasiMtx.Xx & "; " & ForgatasiMtx.Xy & "; " & ForgatasiMtx.Xz) 'Ses.listingwindow.Writeline(ForgatasiMtx.Yx & "; " & ForgatasiMtx.Yy & "; " & ForgatasiMtx.Yz) 'Ses.listingwindow.Writeline(ForgatasiMtx.Zx & "; " & ForgatasiMtx.Zy & "; " & ForgatasiMtx.Zz) Dim moving as integer = Movepart(NullEltolas, ForgatasiMtx, Alkatresz) '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'Move Minmaxpoints '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- 'E_file_name 'solidbody: E_solidbody 'Dim bod as Body = E_solidbody In E_file_name 'Dim component11 As Assemblies.Component = E_file_name 'Dim bod as Body =CType(component11.E_solidbody, Body) Dim outp(3) as Double outp = Ask_XY_bounds (E_solidbody) Ses.listingwindow.Writeline(outp(0) & "; " & outp(1) & "; " & outp(2) & "; " & outp(3)) 'For Each aPoint As Point In workPart.Points ' If apoint.name= "Min" ' aPoint.x = outp(1) ' aPoint.y = outp(3) ' aPoint.z = -magassag ' End If ' If apoint.name= "Max" ' apoint.x = outp(0) ' apoint.y = outp(2) ' apoint.z = 0 ' End If 'Next '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- End Sub '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- '=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=#=# '=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Function get_longest_edge_vec(ByVal edges() As Edge) As Double() Dim inx As Integer = 0 Dim Oldalelhossz as Double = 0 Dim vec(2) as Double vec(0)=1 vec(1)=0 vec(2)=0 For inx = 0 To edges.GetUpperBound(0) If edges(inx).SolidEdgeType.ToString = "Linear" Then Dim Vizsgalt_elhossz as Double = edges(inx).GetLength() If Vizsgalt_elhossz > Oldalelhossz Then Oldalelhossz = Vizsgalt_elhossz Dim sp(2) As Double Dim ep(2) As Double Dim lineData As UFCurve.Line 'lineData.start_point = sp 'lineData.end_point = ep UFSes.Curve.AskLineData(edges(inx).Tag, lineData) sp = lineData.start_point ep = lineData.end_point UFSes.Vec3.Sub(ep, sp, vec) vec(0)= vec(0) / Oldalelhossz vec(1)= vec(1) / Oldalelhossz vec(2)= vec(2) / Oldalelhossz End If End If Next inx Return vec End Function Function get_edge_center(ByVal aEdge As Edge) As Double() Dim arc_evaluator As System.IntPtr Dim arc_data As NXOpen.UF.UFEval.Arc Dim aEdge_tag As Tag = aEdge.Tag Dim pointPos as integer 'pont ellenorzesehez, hogy kivul van-e a testen UFSes.Eval.Initialize(aEdge_tag, arc_evaluator) UFSes.Eval.AskArc(arc_evaluator, arc_data) Return arc_data.center End Function Public Function Ask_XY_bounds(ByVal bod as Body) As Double() Dim iCount, iIndex As Integer Dim tPlane as tag Dim dist(3), outp(3), dPoint(2), dDirection(2) As Double Dim selpnt(1), pnt As Point3d Dim accu As New Double Dim MarkId As Session.UndoMarkId tPlane = tag.Null For iCount = 0 To 3 Select Case iCount Case 0 dPoint(0) = 5000 dDirection(0) = 1 'XMAX Case 1 dPoint(0) = -5000 dDirection(0) = -1 'XMIN Case 2 dPoint(0) = 0 dPoint(1) = 5000 dDirection(0) = 0 dDirection(1) = 1 Case 3 dPoint(1) = -5000 dDirection(1) = 1 'YMAX End Select MarkID = ses.SetUndoMark(Session.MarkVisibility.Invisible, "Datum Plane") ufses.Modl.CreateFixedDplane(dPoint, dDirection, tPlane) dist(iCount) = ses.Measurement.GetMinimumDistance(bod, NXObjectManager.Get(tPlane), selpnt(0), selpnt(1), accu) Ses.UpdateManager.AddToDeleteList( NXObjectManager.Get(tPlane) ) Ses.UpdateManager.DoUpdate(MarkID) Ses.DeleteUndoMark(MarkID, "Datum Plane") outp(0) = dist(1) - 5000 outp(1) = dist(3) - 5000 outp(2) = 5000 - dist(0) outp(3) = 5000 - dist(2) Next Return outp End Function Public Function Movepart(ByVal eltolas As Vector3d, forgatasiMtx As Matrix3x3, mozgatandoAlkatresz As Assemblies.Component ) As Integer Dim nullAssemblies_Component As Assemblies.Component = Nothing Dim compoPositioner As Positioning.ComponentPositioner = workPart.ComponentAssembly.Positioner Dim My_network As Positioning.Network My_network = compoPositioner.EstablishNetwork() Dim compoNetwork As Positioning.ComponentNetwork = CType(My_network, Positioning.ComponentNetwork) compoNetwork.MoveObjectsState = True compoNetwork.DisplayComponent = nullAssemblies_Component compoNetwork.NetworkArrangementsMode = Positioning.ComponentNetwork.ArrangementsMode.Existing compoNetwork.RemoveAllConstraints() Dim mozgatandoObjects(0) As NXObject mozgatandoObjects(0) = mozgatandoAlkatresz compoNetwork.SetMovingGroup(mozgatandoObjects) compoNetwork.BeginDrag() compoNetwork.DragByTransform(eltolas, forgatasiMtx) compoNetwork.EndDrag() compoNetwork.ResetDisplay() compoNetwork.ApplyToModel() compoNetwork.Solve() compoPositioner.ClearNetwork() compoPositioner.DeleteNonPersistentConstraints() compoPositioner.EndMoveComponent() Return 1 End Function End Module----
kukelyk
CODE
dim nxObject1 as NXObject nxObject1 = component1.FindOccurrence(solid1) outp = Ask_XY_bounds(nxObject1) lw.WriteLine("output: ") lw.WriteLine(outp(0).ToString) lw.WriteLine(outp(1).ToString) lw.WriteLine(outp(2).ToString) lw.WriteLine(outp(3).ToString) lw.WriteLine("")www.nxjournaling.com
kukelyk
