abaqus plastic data
abaqus plastic data
abaqus plastic data
Hello all
I want to model an blank in abaqus and the material is pure aluminum (A1100-O) with E = 70,000MPa, ρ = 2700 kg/m3,ν = 0.3, ¯σ = 180¯ε0.2 MPa and also i know "The strain hardening is described using individual points on the flow stress versus plastic strain curve, with an initial yield stress of 100 MPa and a maximum flow stress of 207 MPa."
i used elastic and density data but how can i use plastic specification...
i need to add plastic material in property module but i dont know how to use the above data to fill plastic data table in abaqus?
Best Regards
RE: abaqus plastic data
Please Read 23.1.1 in Abaqus user manual, specifically stress and strain measure. You will see how plastic strain is calculated from the true stress-strain curve.
