Import drafting views
Hi All,
Is it possible to import drafting views from other parts in NX.
basenxuser
RE: Import drafting views
The best you can do is make a screen shot of this view from an other part and insert in drafting as image (Insert - image...)
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
When you say a 'Drafting View' are we talking about something with dimensions and annotation, perhaps even a section view from an existing Drawing onto the face of a totally different part file's Drawing?
If so, the easiest approach would be to do a 'Copy & Paste' of the view of interest from one Drawing sheet to the other. I just tried this using NX 8.5 and it worked pretty well.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John,
I am talking about from one part to another part.
basenxuser
Have you tried doing the 'Copy & Paste' that I suggested? As I said, I've tested this and it seems to work for what you're trying to do.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Open your part withthe views that you would like to export. File>Export>Part
choose existing, select the part you would like to export the sheets to. select "drawing selection" and choose the sheets that have your views that you would like to export.
CaptainCAD88,
Thanks for your reply to this thread!
Very useful!
MZ7DYJ
CaptainCAD88,
I tryed to follow your direction, but importing bring just a drawing sheet, not the views!
MZ7DYJ
You cant import a sheet from a paret file but you can export a sheet to a part file, that is why you need to open the part with the views that you need and export the sheet from that file to your working file.
Just went through this the other day. Below are some steps recommended to me by GTAC.
Have both drawings loaded.
Open drawing A and create a CGM file of what you want in drawing B. We hide everything except for what we wanted.
Open drawing B and create a blank view.
Now import the CGM file into this view. This geometry is not associative to anything.
Took us a few stabs but we did get it to work.
Jurgen
NX8 TCUA8.3
