Bucket-type Strainer vs Y-type Strainer
Between bucket-type strainer and Y-type strainer, which is the best to be recommended to be installed at pump suction?
I am what I am by His grace
RE: Bucket-type Strainer vs Y-type Strainer
You've been around long enough on this site to know you shouldn't double post.
Any way, in response to your question it depends how dirty your fluid is and how oftern you expect to clean them out.. IMHO, Y filters are good for "bolt catcher" application and commissioning, but not for long term use as they need to be drained of product, if a liquid, and all the crud falls on the floor when you undo it. Anything is better than an inline top hat filter....
Bucket or basket strainers are normally a QO top and you can retrieve and replace a basket filter very easily.
If you size them right, the the pressure differecne should be similar.
Be careful about the pressure drop when dirty on any inlet side filter as it can easily climb and affect your pump NPSHA figure. For this reason, I would prefer a basket strainer as it has a bigger surface area and won't clog as fast, but as said at the start - depends on your fluid and what the filter level is.
Thanks LittleInch, I appreciate your response.
Am sorry for the double posting.
You can "star" a very good answer like the one you got and I think it deserves a star.
