I want the roots of a function using Mathcad
Hello Everyone,
Is there a way in mathcad to obtain the roots of a function f(omega)=0? I am doing it at the moment by first plotting the function and then searching for the places where it is equal to zero. But how do i solve the function directly without first plotting it?
Thanks!
Jimmy
RE: I want the roots of a function using Mathcad
I found a way around this. Thanks!
I use the root function.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
This is what I did using the polyroots function.
If I have f(x)=x^n+k1x^(n-1)+.....+k0 and I want the solution for f(x)=0
I first find the coefficients of f(x) using
G=f(x)coeffs,x------->
The coeffs --------> is obtained by using coeffs under Symbolic and the x is added by using the "comma" key on the keyboard. With the coeffients defined:
r:=polyroots(G)
r=
would give you the zeros of the function f(x)
Jimmy
