hydrogen compressor what is better diaphragm type or piston type compressor
hydrogen compressor service what is better diaphragm type or piston type compressor and why?
RE: hydrogen compressor what is better diaphragm type or piston type compressor
Depends. What material is the diaphragm?
Diaphragm material are as following:
the upper and lower diaphragm are SS
the middle diaphragm is SS with TFE coating
In general, the diaphragm will seal better* than a piston. But the piston can take higher pressure differentials/compression ratios, and won't suffer from eventual fatigue failure like the diaphragm will.
* do realize sealing hydrogen is a bit like herding cats - it diffuses through solid materials.
