copy sets from assembly module to part module.
I made many partitions and sets in the assembly module, when i try to make submodel from global model which has all these sets and partitions, i found that all these partitions and sets which were generated in the assembly module could not be generated in the submodel. I notice that this problem disappear when all the sets and partitions are generated in the part module.
So, i need to find a way to copy or propagate all the sets and partitions generated in the Assembly module to the part module.
Can you please advice me.
RE: copy sets from assembly module to part module.
Actually they are many, but the model is complex and re-generating the model from the begining is time consuming, how can that in the input file.
Suppose the name of the set in the assembly module is set-1, how can i copy that set to the part module.
How can i copy set or a group of sets from the Assembly module to the part module.
Thank you iceBreakerSour.
I got it
You are welcome. I did not want to give away the answer for a good reason and I hope you understand why.
Now, in general, use a similar trick to learn *anything* in Abaqus. Create a *very* simple problem 1D/2D/3D with one or a few elements and learn whatever you need to learn. This is perhaps the best way to become a better modeler. If you can strengthen your theory, then you'll become even better. You won't have to run into multiple forums asking questions from unknown people - who may or may not give you the right/best advice.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
I agree with you. And I really appreciate your help and your advice.May God help you and increase your knowledge since you are helping people.
