Geometric condtion fail
I'm working on two product and one of the items I'm working on I can't seem to get it as I want.
The item is becoming a wrist with embedded NFC payment tag, but that comes after the shaping of the product.
Problem one:
Constantly geometric condition failures and I can't seem to be able to do it in any other way so it doesnt occur.
I'm trying to get the cut in lines seen on the picture all the way around the band, starting of with this and then trying to circular pattern the two cuts.
Any tips / clues how to solve it? Or other ways how to make it?
Problem two
The other shape I just have no clue how to start making it (without possibly using 3d sketch) in SW.
So just some tips to get me started on how to make that the facetted band would be really appriciated.
Here a drawing of what the intention is of making in SW.
RE: Geometric condtion fail
Can you attach the first part here?
Looks like you might be able to do a mirror and then circular pattern.
Emboss/Deboss might be a solution in place of Sweep.
Is it possible to lay this out as a flat sheet - then apply a flex feature to roll it up?
Rollupswx, I'v attached the file. You can give it a try and if you get it working please eplain in short how you did it.
Bether to learn from the mistakes then just let someone els do it.
And for Rbpmc, I'v alredy found making a hexagon then using lofted cut did the trick.
But the flex feature would be way more neat to use, altough I wonder if that work with this kind of complex shape.
Previously haven't gotten that good a experience in what its capable of.
One way to make the faceted face would be to use the Polygon sketch tool, with a polygon of arbitrary number of sides (I used 9) and a second sketch on a parallel plane with the polygon rotated.
From there you can create planes constrained by 3 of the nodes, and do 2D sketches of triangles between the points.
Then -Planar Surface, -repeat an an adjoining "triangle, Knit, -circular pattern, -knit the whole mess together. Sounds like more work than it is.
Does not account for your overlap at the bottom, but maybe its useful as a jumping off point. There are certainly more ways to do this, but this one popped into my head when I saw the sketch.
