StaadPro Buckling Analysis
I need someone to show me the steps to perform buckling analysis in staadpro.
E.g: A steel strut 0.15m diameter and 12m long, built in rigidly at the bottom but completely unrestrained at the top. Ans = 89.4kN. Take E= 205GPa.
I have tried tirelessly but still cannot get the correct factor.
Please do help by sending me a stepwise description of the process and possibly a staadpro file containing the solution.
Thanks.
atika4ufolks@yahoo.com
RE: StaadPro Buckling Analysis
Sorry, I cannot halp you with STAADpro. In danger of being regarded as overly pessimistic, I would be very careful with doing buckling analysis with numerical methods. A buckling analysis is very dependent on geometry. And the real geometry (reality) is not perfect, whereas the numerical system assumes it is. (just try to model a perfect (100% straight) strut and one with a slight imperfection, you will see ahuge difference in buckling load) Of course you can include uncertainty factors, and with the right parameters and large safety factors you can calcualte a reasonable buckling load. I prefer hand calculations or non-linear buckling analysis.
I can't help with STAADPro either, but a linear buckling analysis should give a result very close to the Euler buckling load, and to a non-linear buckling analysis.
Based on the information provided the numbers I get are:
Euler buckling load: 87.29 kN
Linear buckling analysis (1 segment): 87.95 kN
Linear buckling analysis (10 segments): 87.29 kN
Non-linear buckling analysis (10 segments): 87.47 kN
What buckling load are you getting from your STAADPro analysis?
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Thanks everyone.. Sorted myself out already. I was modelling wrongly initially using staad plane instead of space. Got 87.29kN.
Thanks.
