Equation for curve
Equation for curve
I wish to draw a hypoellips curve and for this I will use and equation where the "square root" is a part. But it shall be posible to take root expressed by a real
The ground equation is
x^a + y^a =1
For the curve could this be expressed as follow
x = t
z = 0
y = (1 - (x)^a ) -^a
for bescribing y I wish the correct syntax instead of -^a.
x^a + y^a =1
x = t
z = 0
RE: Equation for curve
I had found a solution.
Thanks for the reply.
Smiszek
