Forged Flaged Y-Strainers
Are Flaged Y-Strainers are totally forged in one shot from the foundry or the forged body is welded later to the forged flanges? Pls reply my dear friends urgently to close my PO....
RE: Forged Flaged Y-Strainers
Forged parts are made in a forge.
WRT your question, what are your customer's requirements?
Mike Halloran
Pembroke Pines, FL, USA
Most strainers are made by Casting and Fabricated
Casting Strainer => The whole body are made by casting
Fabricated Strainer => The body are by pipe and fittings. The end body (the flanges & blinds) are by forging. Then they are welded (fabricated) together.
Another type of strainer under special requirements (such as high pressure), some strainer manufacturer made by Machining a metal bar to be the strainer body (no welding parts from fabricated and no porosity from casting)
So i never heard of forge stainer.
If your pressure and temp is not critical, just stick on the casting or fabricated type strainer. I think in your case, your client intend on fabricated type strainer (which some parts are made by forging).
