ID of Unknown Ball Valve
I've received a few NIM 1/4 ball valves and cannot ID their manufacture and specs.
I'd like to know what these ball valves are spec'd for; i.e. fluid/type; gas/type, etc and their working and max. pressure ratings.
The markings on the handle are;
ZHINDA MS58/300WOGI (silver exterior metal in color, ball valve is some sort of metal), with female threads on both ends.
-10 DEGREE CELSIUS < T < 180 DEGREES CELSIUS
Body Cast Markings are ZHINDA with company logo on one side and 1/4 on the other.
A google search was negative.
Thanks for your assistance
RE: ID of Unknown Ball Valve
Corrosion resistant, exotic alloy valves from The Alloy Valve Stockist in Barcelona, Spain http://valvestockist.com
