CAT00215 - ERROR RETURNED BY ROUTINE MDMAR IN IWPROC :
Getting this error when I try to activate a part in V4
theres the entire error
 0 ********************** SIZE OF THE WORKING CATIA MODEL **********************
 0 INDEX (KBYTES)___:     34928
 0 DATA (KBYTES)____:     96789
 0 ******************************************************************************
            MODEL INCLUDING A PRJMODEL CAN NOT BE READ
            THE DECLARATION CATSITE.PRJMODEL MUST BE SET TO TRUE
 UTI21380 - ERROR RETURNED BY ROUTINE UTIMRE   :
            ERROR WHEN READING MODEL
            CRAIG D.     UNIQUE TOOL SHOW-SIDE SUNROOF  COMPONENTS    30SEP02 01MX
 *    ERROR IN SUBROUTINE : G7MREA   WHEN CALLING SUBROUTINE : MDMAR           *
 *         ERROR CODE :   215                                                  *
 *                 ERROR IN CATGEO/CATMSP SOFTWARE                             *
 *         ERROR WHEN USING  SUBROUTINE : MDMAR                                *
 *         CURRENT MODEL NUMBER : NONE                                         *
 *         ERROR CODE :   215      SEVERITY  4                                 *
 *   MODEL INCLUDING A PRJMODEL CAN NOT BE READ                                *
 *   THE DECLARATION CATSITE.PRJMODEL MUST BE SET TO TRUE                      *
Is this because of the V5 to V4 and how do I correct it
RE: CAT00215 - ERROR RETURNED BY ROUTINE MDMAR IN IWPROC :
In order to be able to read this file with CATIA V4, you must add in your USRENV.dcls that following line:
CATSITE.PRJMODEL=TRUE;
great, I had a typo.
working good now..
you da man,
thanks
 Ken
