Heat exchanger idea
Heat exchanger idea
I've built a heat exchanger for a cooling system that will be immersed in cold water. I would like to cool both an engine and the exhaust manifold in a closed circuit. I'm wondering if an aluminum heat exchanger with about 10 square feet of surface area immersed in 60f water would be sufficient to prevent the coolant in the system from boiling. The exhaust headers are water jacketed in a closed system. Been a whole lifetime since I've done any intense thermo calcs. The engine is a gm 181 ci hyster forklift engine. Any thoughts advice? Something "cool" to ponder.
RE: Heat exchanger idea
Mike
