Cooling system heat exchanger
I've built a heat exchanger for a cooling system that will be immersed in cold water. I would like to cool both an engine and the exhaust manifold in a closed circuit. I'm wondering if an aluminum heat exchanger with about 10 square feet of surface area immersed in 60f water would be sufficient to prevent the coolant in the system from boiling. The exhaust headers are water jacketed in a closed system. Been a whole since I've done any intense thermo calcs. The engine is a gm 181 ci hyster forklift engine. Any thoughts advice? Something "cool" to ponder.
RE: Cooling system heat exchanger
This may shed some light: www.maplesoft.com/view.aspx?SF=6403/Radiator.pdf
TTFN
They are often fabricated from half-pipes or channels welded to the hull plates.
They also typically have quite a lot more surface area than you mention.
Engine manufacturers often provide software to help size keel coolers for their marine engines. An engine dealer can probably get you a copy.
Mike Halloran
Pembroke Pines, FL, USA
The boat is not always traveling fast, and you have to allow some cushion for paint, barnacles and other marine growth.
Mike Halloran
