Capacitive discharge vs batteries in breaker operation
Hi there. I an unfamiliar with capacitive discharge on medium voltage breakers and their pros and cons vs using batteries on MV breaker operation. I was always under the impression that if power were lost you you can operate the breakers and meters under battery power.
Thanks.
b
Thanks.
b
RE: Capacitive discharge vs batteries in breaker operation
The down side is they don't power microprocassor relays very well.
But the capacitors can be charged by a station power source, or by CT current.
There were some microprocessor relays made outside the US that not only could be operated with batteries (only station power and CT current), and provide tripping capacitors internally. Not sure how they would work with US made breakers however.
"Will work for (the memory of) salami"
Besides if station power does not return following a breaker operation, then there is no need to close the breaker.
