Product vs Component
In the Product Structure terminology there are several terms like:
Raw Material, Part, Part Product, Sub-Assembly, Sub-Component, Sub-Product, Assembly, Product, Component.
What is the right use of the terms Product and Component? Are these terms equivalent?
Finally, what is the exact technical definition of these two terms?
Thanks in advance.
Thanks in advance.
-GEL
Imposible is nothing.
RE: Product vs Component
personally i'd go with
Raw Material, Part (or Detail), Sub-ass'y, ass'y (this should IMO refer to the top level assembly)
and like graham says one company's ass'y can be another's raw material.
and, btw, somethings are impossible !?
Quando Omni Flunkus Moritati
It all depends on content.
In general a "product" is what a company offers for sale.
For a steel mill: Raw material = iron ore. Product = steel plate.
For a fabricator: Raw material = steel plate (purchased from the steel mill). Product = cut, formed, welded etc. steel something. This steel something might be one component in a locomotive.
The locomotive builder might purchase several different steel somethings from the fabricator. When bolted together they might become engine bay sub-assembly for the locomotive.
There is no hard-and-fast definition.
I think a product is what leaves the factory in return for money from a customer. It might be a component of the customer's product after that, but it was my product when I sold it.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
We do measurement reports on parts in their own merit but than you do a measurement report on the product in which you check the function of all the components in the assembly context.
A sub-assembly is more of a process dependent jargon. If a bunch of components are assembled together and than all this is assembled again, the previous would be a sub-assembly in the latter.
As for component, again disregarding mathematical and electrical connotations, it could be considered a constituent part of a system, e.g., a part of a mixture, an ingredient.
IMO, "component" is a word that can mean pretty much whatever you want it to mean. "part" is a well understood engineering term, so to is "sub-ass'y" and "ass'y". You can call the final output of your process a "product" ... personally, I hate that term, it makes me think you don't know what you're making, so you substitute a generic term "product".
This term comes from DS CATIA.
"Part Product" is a Product that consists of only one part.
The need for "Part Products" comes from the fact that in CATIA a Product is a "Collection of Products".
-GEL
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
In CATIA Object Model:
-a Product is a "Collection of Products".
-a Drawing is a "Collection of 2D Views of a Part or Product".
-Product and Drawing are different object classes(types)
-GEL
When you write manuals and technical articles, you need to use terminology with far greater precision than you would in regular conversation. For fun sometimes, search Eng-tips for discussions about bolts versus screws.
The subject of Catia has been brought up. Does whatever article you are reading contain a glossary?
JHG
is the basic question how to relate CATIA terminology to general usage, or technical usage for building assembly trees ?
as far as i know (which isn't very far) CATIA doesn't use the terms sub-part, sub-component, or even component. i thought their terms were part (CATPart) and product (CATProduct).
My question is about what is the right terminology, if exists, for Product Structure (or as you call it Assembly Tree)
-GEL
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
From the perspective of a cycle which begin as an initiative to produce something (A) and end as a deliverable for producing welfare or economic benefit (B).
Product is located at the end of the process (B).
Component is somewhere in the ongoing process between (A and B).
Component does not produce welfare or economic benefit (B) - directly.
No reliable source behind... just a personal perspective.
a reasonable product structure would be ...
1) GA ... the top assembly, the final product (if you will),
2) this is comprised of sub-assemblies ... you might say that a major sub-assembly is a collection of minor sub-asseblies, you could include a level called "component" to avoid using the term "sub-assembly" repeatedly.
3) at the bottom of it all are detail parts.
so it could look like GA < major component < component < major sub-assembly < sub-assembly < part.
now this of course doesn't mean that there are only 6 levels in the GA product structure.
you might look into project management for better definition.
