ASME VIII Div 1 App 2 vs API 6A
Rookie engineer here.
I was asked to check an API 6A flange (15,000 psi) for excessive stresses using the ASME VIII Div 1 App 2 calculation, the stresses exceed the allowable when the flange dims match the API dims.
Is the ASME VIII flange calculations applicable to API 6A.
I will go through the standard again and look out for ommisions, just wondering if you more experienced guys could give me a heads up.
Muz
Muz
RE: ASME VIII Div 1 App 2 vs API 6A
