what grade of stainless steel do i have here? xxx35-020
hello
i was given these big 6" diameter solid stainless steel shafts.
i cant figure out the grade on them.
they have alot of numbers on them but i cant find any info in my searches.
here are some of the numbers
2042
919400a1
xxx35-020
does anyone have an idea?
thanks
steve
2042
919400a1
xxx35-020
thanks
steve
RE: what grade of stainless steel do i have here? xxx35-020
Those numbers are most certainly a heat and/or lot identification, but without the documentation, they don't mean much. You could take a sample and have a chemical composition test run. Depending on the composition, and the product form, you might be able to run down the producer and those numbers may mean something to them, but without knowing the producer, they aren't going mean much.
rp
