What temperature to use for cooling degree day?
What is a realistic temperature to use for CCD? I will be using the hours in conjunction with SEER to estimate future cost for KW-HR for a heat pump. Also how many years back should be included, ie 2012,2011 ,etc?
RE: What temperature to use for cooling degree day?
Here's a discussion that's pretty accurate: http://en.wikipedia.org/wiki/Typical_meteorologica...
There are lots of conversion programs to turn that TMY file into readable data. This one from the U of Wisconsin Solar Energy Labs puts the TMY directly into Excel:
http://sel.me.wisc.edu/trnsys/weather/tmy2data.htm
As for your base temperature, the typical one we pick is 65°F for residential low-rise buildings, 50°-55°F for commercial and institutional spaces (except health care occupancies). Degree days is pretty meaningless for hospitals or any other facility that is heavily internally loaded.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
First, for cooling you also would need wetbulb degree days and solar radiation. Second, your building, internal loads etc. play a role.
a 8760-hour energy simulation is a must to even have a chance, and event hat is based on many assumptions.
CDD*24 = hours.
DesignTons*hours /SEER =kw-hr
Degree days are just too course to return anything meaninful.
