Instance Feature in NX7.5 will not let you to replace/unselect featuers after a pattern is created?
I have previously worked in N 8 and NX8.5 and is used to create pattern with the "Pattern Feature" wich is great. At my current workplace NX7.5 is being used and here you need to use Instance Feature -> Circular Array or Rectangular Array. It seems to me that this feature will not let you to replace/unselect or ad featuers in the pattern after a pattern is created?
For example if you created a hole then made the pattern, then you realized you wanted to ad threads or camfer to the hole or somting else. Then you will not be able to ad this to the pattern, is that how it is?
Thanks in advance
// Erkka
Thanks in advance
// Erkka
RE: Instance Feature in NX7.5 will not let you to replace/unselect featuers after a pattern is created?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks in advance
// Erkka
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Best Regards
// Erkka
