M, M+B with shell Elements
Dear All,
Would you mind tell me how can I get the Membrane and Membrane + Bending stress using shell element with ansys workbench 14
If I use the Linearized stress intensity ansys request me to choose 2 points for the path...
Thanks a lot !
Thanks a lot !
RE: M, M+B with shell Elements
Thanks for your help. So in Ansys to know the M should I select - Stress Intensity: Middle and for M+B - Stress Intensity: Top/bottom ?. I´m quite new using ansys.
What about the "membrane" and "bending" option in the Solution-insert-stress-MEMBRANE or BENDING ?.
Best regards!
