New to Abaqus: Thermal Expansion
Hi everyone, I finished school recently and have started my first job as a mechanical engineer. One of the things I am tasked with doing right now is to perform Abaqus thermal stress simulations on a thermoelectric generator. I have no previous experience with Abaqus so i'm looking for some help/guidelines. I'm starting small, with small examples and going to work my way up to eventually modelling the whole TEG. for now though, all I want to do is a simple thermal expansion.
I have entered my material properties and designed a rectangular part (representative of my element). I want to see how much it expands when the temperature increases by 100 degrees celsius with no mechanical boundary conditions. every way i try to do it gives me errors when i submit the job due to too many iterations. my prodecure clearly has something wrong.
all i want to do is make sure my abaqus calculation concurs with my analytical one. it's length is 0.25m, so the piece should expand 0.25xCTEx100 in that direction, but i have not been able to achieve this result in abaqus.
thanks in advance!
thanks in advance!
RE: New to Abaqus: Thermal Expansion
What I guess is wrong is that you don't put any boundary condition. you should at least remove rigid body motion.
Are you seeing warnings in the msg file? Zero pivit, numerical singularities, ... ?
Other than that, check your units for consistency, be sure to use an element type with thermal DOF, etc.
The warnings i get are "There is zero HEAT FLUX" and I have also gotten Zero Pivot error on DOF 11 when I've tried doing it different ways. After several repetitions of the "THere is zero HEAT FLUX" warning I get a "Too many iterations error".
What is process that you would go through to do this simple type of simulation.
how to do it:
see the simple example in attachment, i just put some random values for all parameters.
do file->import->model
its not the cleanest but you should manage to find your error :)
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
