Reinforced Earth Bridge Abutment
I am working on several Bridge Replacement projects and looking for imput on utilizing reinforced earth abutments. These bridges are very low volume 10 ADT ~ farm to market crossings. Normal practice is to drive piling to glacial till deposits 75' - 200' below grade. In doing this the bridge is ridid and the approaches are not. severe settlement occurs seasonally and is a continual maintenacne / safety problem. The clay soil deposits are low density high moisture and very expansive. Has any one built reinforced earth abutments to carry short span steel bridge and traffic on low density high moisture expansive clay soils. Soil bearing capacity can be as low as 1500 psf. Piling to these depths (75' -200') for low volume crossing seems to be overkill. Any comments appreciated!
RE: Reinforced Earth Bridge Abutment
Do you use relieving slabs at the approaches? That would help a lot with the required maintenance.
If you stick with piling, you should investigate founding higher than the 75' - 200' rock. I agree that is overkill. I would look at expanded base cast in place piling (Frankipiles), founded at maybe 20'. Talk to Franki or a specialist piling contractor in your area.
Most counties and cities try to follow state guidelines due to funding mechanisms so even though it's not a state agency they may still take a dim view to seating on MSE wall.
if you do have an abutment on MSE wall, you'll want to have an open seat abutment so if the abutment settles it won't induce stress into the superstructure as it would for integral construction.
Sometimes it doesn't pay to go the cheap route just a lot of headaches later.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
