Bluetooth for iOS
Bluetooth for iOS
Hi, I am working on a weight scale project with bluetooh. The scale will send the numeric data to iOS or Android then showing the result on screen. The scale will be using only bluetooth HID profile. Have many questions for bluetooth device work with iOS and Android.
For iOS,
1. As we us only HID profile, there is no need to apply for the MFi program. Is this correct?
2. If number 1 is correct, is there any license or cert I need to apply with Apple in order to be legal with iOS product? Yes, FCC, CE and ROHS will be apply
Last, What would be the best selection of bluetooth module work on both work with both iOS and Android?
Thanks a lot.
For iOS,
Thanks a lot.
RE: Bluetooth for iOS
1) Correct. See http://support.apple.com/kb/HT3647 for the full list of supported profiles by device and http://mfi.apple.com/faqs#1-1 for the official statement that MFi is not necessary.
2) Not with Apple specifically. You could register a company identifier with the Bluetooth SIG, but for a HID accessory you can just use a Vendor ID (VID) assigned by the USB Implementers Forum. See https://developer.apple.com/hardwaredrivers/Blueto... page 10 for that statement and a bucket load of other relevant info.
Of course, to use any of the "Made for iOS" trademarks and logos you need to sign up (probably with MFi) and to develop any client side software you'll need to register as an iOS developer ($50 from memory), but apart from that it's just a generic Bluetooth device to the iOS device.
Last) Not sure what you mean by "module". Do you mean a Bluetooth IC? If so, then I suspect there'd be more important design criteria to satisfy than Android/iOS compatibility - as long as you follow the Bluetooth standard the chip will be fairly transparent to the device.
