Cuts through a toroid
Hello all,
I am having some trouble cutting holes through my toroid at different angles.
I created my toroid by creating a reference axis from the origin to the front plane, then selecting the top plane. I then created a square 2 inches from the origin point, exited the sketch and revolved base around the reference axis.
What I am trying to do now is cut holes through the toroid from the center outward through the inner side of the toroid every 30 degrees. How can I accomplish this?
Thanks in advanced for any help anyone can give me.
Stephen
Stephen
RE: Cuts through a toroid
After creating the first hole with the Hole Wizard, use the Circular Pattern to create the others.
