Shading not correct for all surface parts in NX7.5.5.4
I have a strange behavior with a Workstation DELL with quadro 2000
The shading is correct with solid body but only some faces are shaded with surface model. And If I turn the model, the shading is reversed (have a look at back_view.jpg and front_view.jpg)
Preferences / Visualization / Visual / two sided light ON doesn't solve the problem
If I set a small transluency on all faces (1%) the shading is almost correct
Thanks in advance for your suggestion
Didier Psaltopoulos
http://www.psi-cad.com
RE: Shading not correct for all surface parts in NX7.5.5.4
Preferences -> Visualization performance -> general graphics
Turn off the "backface culling" option.
www.nxjournaling.com
Thanks Cowski,
I had forgotten this setting. I will try tomorrow and let you informed
Didier Psaltopoulos
Hi Cowski,
finally I could test it now. thank you again
Didier Psaltopoulos
