Problem During Compilation
Hello all,
I have this subroutine and I'm getting problems during compilation. Here's my subroutine:
SUBROUTINE DFLUX(FLUX,SOL,JSTEP,JINC,TIME,NOEL,NPT,COORDS,JLTYP,
1 TEMP,PRESS,SNAME)
C
INCLUDE 'ABA_PARAM.INC'
C
DIMENSION COORDS(3),FLUX(2),TIME(2)
CHARACTER*80 SNAME
C
PARAMETER(PI_OVER_180=3.141592653589793/180)
C SUBMERGE_SPEED: in/sec
SUBMERGE_SPEED = 0.525
C THERMAL ENVIRONMENT
BATH_TEMPERATURE = 828.0
AIR_TEMPERATURE = 65.0
C THERMAL PROPERTY
BATH_CONVECTION_H = 0.000509578
AIR_CONVECTION_H = 0.0000339719
C GEOMETRY
GX0 = 0.0
GY0 = -23.5
GZ0 = 0.0
GX1 = 0.0
GY1 = 16.6875
GZ1 = 21.0478
C PLANE
THETA = 86.0*PI_OVER_180
A = 0.0
B = SIN(THETA)
C = COS(THETA)
GD0 = A*GX0+B*GY0+C*GZ0
GD1 = A*GX1+B*GY1+C*GZ1
D = GD0 + SUBMERGE_SPEED*TIME(2)
C FLUX
F = A*COORDS(1)+B*COORDS(2)+C*COORDS(3)-D
IF (F .LT. 0.0) THEN
FLUX(1) = BATH_CONVECTION_H*(BATH_TEMPERATURE-SOL)
FLUX(2) = -1.0*BATH_CONVECTION_H
ELSE
FLUX(1) = AIR_CONVECTION_H*(AIR_TEMPERATURE-SOL)
FLUX(2) = -1.0*AIR_CONVECTION_H
ENDIF
RETURN
END
Abaqus is linked to a compiler as you can see in the following link:
RE: Problem During Compilation
a) What have you tried to debug it?
b) Did you try it on a single element?
c) Did you try to debug it externally (i.e., not with Abaqus) just as a subroutine by passing dummy variables?
If you have not, try such techniques. And upload the code; no one wants to keep creating spaces in their editor. Also, for whatever's precious sake, use comments in a code! Finally, tell us what you are trying to do; upload a simple inp with your code and tell us a little about the problem!
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
a) No, because it has been working with previous versions of ABAQUS
b) Yes, didn't work
c) No
I'm trying to conduct a heat transfer analysis, with non-uniform flux. As a result my material properties are changing with temperature in a non-uniform way. Also I want to be able to conduct a parametric study on the non-uniform flux that's why I went with the subroutine.
If there is any other question I'd be happy to answer!
Here's the inp file,
(I found that one "," is too much. Now I get "Abaqus is unable to execute the command: Abaqus/Standard Analysis Please check the validity of the command on this computer.")
Here's my .inp file:
CODE
*Heading
** Job name: BarT Model name: Bar
** Generated by: Abaqus/CAE 6.9-EF2
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Bar
*Node
      1,          -4.,           4.,      1.90625
      2,          -4.,      4.09375,           2.
      3,          -4.,           4.,           2.
      4,          -4.,           5.,           2.
      5,          -4.,           5.,           1.
      6,          -4.,      4.09375,           1.
      7,          -4.,           4.,      1.09375
      8,          -4.,           4.,           1.
      9,          -5.,           4.,           1.
     10,          -5.,           4.,           2.
     11,          -5.,           5.,           2.
     12,          -5.,           5.,           1.
     13,          -4.,           4.,      2.09375
     14,          -4.,           4.,      2.90625
     15,          -4.,      4.09375,           3.
     16,          -4.,           5.,           3.
     17,          -4.,           4.,           3.
     18,          -5.,           4.,           3.
     19,          -5.,           5.,           3.
     20,          -4.,           5.,           0.
     21,          -4.,           4.,      0.90625
     22,          -4.,           4.,           0.
     23,          -5.,           4.,           0.
     24,          -5.,           5.,           0.
     25,          -3.,      4.09375,           1.
     26,          -3.,           4.,      0.90625
     27,          -3.,           4.,           0.
     28,          -3.,           5.,           0.
     29,          -3.,           5.,           1.
     30,          -3.,      4.09375,           3.
     31,          -3.,           4.,      2.90625
     32,          -3.,           4.,      2.09375
     33,          -3.,      4.09375,           2.
     34,          -3.,           5.,           2.
     35,          -3.,           5.,           3.
     36,          -3.,           4.,      1.09375
     37,          -3.,           4.,      1.90625
     38,          -4.,      4.09375,           4.
     39,          -4.,           4.,      4.09375
     40,          -4.,           4.,           4.
     41,          -4.,           4.,      4.90625
     42,          -4.,      4.09375,           5.
     43,          -4.,           4.,           5.
     44,          -4.,           5.,           5.
     45,          -4.,           5.,           4.
     46,          -5.,           4.,           4.
     47,          -5.,           4.,           5.
     48,          -5.,           5.,           5.
     49,          -5.,           5.,           4.
     50,          -4.,           4.,      3.90625
     51,          -4.,           4.,      3.09375
     52,          -4.,      4.09375,           6.
     53,          -4.,           4.,      6.09375
     54,          -4.,           4.,           6.
     55,          -4.,           4.,           7.
     56,          -4.,           5.,           7.
     57,          -4.,           5.,           6.
     58,          -5.,           4.,           6.
     59,          -5.,           4.,           7.
     60,          -5.,           5.,           7.
     61,          -5.,           5.,           6.
     62,          -4.,           4.,      5.90625
     63,          -4.,           4.,      5.09375
     64,          -4.,           4.,           9.
     65,          -4.,           4.,           8.
     66,          -3.,           4.,           8.
     67,          -3.,           4.,           9.
     68,          -4.,           3.,           9.
     69,          -4.,           3.,           8.
     70,          -3.,           3.,           8.
     71,          -3.,           3.,           9.
     72,          -5.,           4.,           8.
     73,          -4.,           5.,           8.
     74,          -5.,           5.,           8.
     75,          -4.,           4.,          10.
     76,          -3.,           4.,          10.
     77,          -4.,           3.,          10.
     78,          -3.,           3.,          10.
     79,          -4.,           5.,           9.
     80,          -5.,           5.,           9.
     81,          -5.,           4.,           9.
     82,          -4.,           5.,          10.
     83,          -5.,           5.,          10.
     84,          -5.,           4.,          10.
     85,          -4.,           3.,           7.
     86,          -5.,           3.,           7.
     87,          -5.,           3.,           8.
     88,          -3.,           5.,           8.
     89,          -3.,           5.,           9.
     90,          -3.,           5.,          10.
     91,          -4.,      3.90625,           5.
     92,          -4.,      3.90625,           6.
     93,          -4.,           3.,           5.
     94,          -4.,           3.,           6.
     95,          -5.,           3.,           5.
     96,          -5.,           3.,           6.
     97,          -4.,      3.90625,           3.
     98,          -4.,      3.90625,           4.
     99,          -4.,           3.,           3.
    100,          -4.,           3.,           4.
    101,          -5.,           3.,           3.
    102,          -5.,           3.,           4.
    103,          -4.,      3.90625,           1.
    104,          -4.,      3.90625,           2.
    105,          -4.,           3.,           1.
    106,          -4.,           3.,           2.
    107,          -5.,           3.,           1.
    108,          -5.,           3.,           2.
    109,          -4.,           3.,           0.
    110,          -5.,           3.,           0.
    111,          -3.,      3.90625,           1.
    112,          -3.,           3.,           1.
    113,          -3.,           3.,           0.
    114,          -3.,      3.90625,           3.
    115,          -3.,           3.,           3.
    116,          -3.,           3.,           2.
    117,          -3.,      3.90625,           2.
    118,          -3.,           4.,      4.90625
    119,          -3.,      3.90625,           5.
    120,          -3.,           3.,           5.
    121,          -3.,           3.,           4.
    122,          -3.,      3.90625,           4.
    123,          -3.,           4.,      4.09375
    124,          -3.,           4.,      3.09375
    125,          -3.,           4.,      3.90625
    126,          -3.,      3.90625,           6.
    127,          -3.,           4.,      6.09375
    128,          -3.,           4.,           7.
    129,          -3.,           3.,           7.
    130,          -3.,           3.,           6.
    131,          -3.,           4.,      5.09375
    132,          -3.,           4.,      5.90625
    133,          -5.,           3.,          10.
    134,          -5.,           3.,           9.
    135,          -3.,           5.,           7.
    136,          -3.,      4.09375,           5.
    137,          -3.,           5.,           5.
    138,          -3.,           5.,           6.
    139,          -3.,      4.09375,           6.
    140,          -3.,           5.,           4.
    141,          -3.,      4.09375,           4.
    142,          -4.,   4.02453518,   1.90951753
    143,          -4.,   4.04702997,   1.91889966
    144,          -4.,   4.06577253,   1.93319404
    145,          -4.,   4.08044147,   1.95185173
    146,          -4.,    4.0902667,   1.97468197
    147,          -4.,   4.06816053,           2.
    148,          -4.,   4.04477119,           2.
    149,          -4.,   4.02227402,           2.
    150,          -4.,           4.,   1.97766066
    151,          -4.,           4.,   1.95512819
    152,          -4.,           4.,   1.93175268
    153,          -4.,   4.09074783,   1.02353466
    154,          -4.,   4.08220148,   1.04507756
    155,          -4.,   4.06894112,   1.06353092
    156,          -4.,   4.05089092,   1.07873476
    157,          -4.,   4.02770996,   1.08956122
    158,          -4.,           4.,   1.19600487
    159,          -4.,           4.,   1.28466964
    160,          -4.,           4.,   1.38075674
    161,          -4.,           4.,   1.47571158
    162,          -4.,           4.,   1.56763971
    163,          -4.,           4.,   1.65430248
    164,          -4.,           4.,   1.73882568
    165,          -4.,           4.,   1.81846964
    166,          -4.,   4.16168213,           2.
    167,          -4.,    4.2298007,           2.
    168,          -4.,   4.30357361,           2.
    169,          -4.,   4.38937473,           2.
    170,          -4.,   4.48417044,           2.
    171,          -4.,   4.58394909,           2.
    172,          -4.,   4.68604755,           2.
    173,          -4.,     4.789258,           2.
    174,          -4.,    4.8944397,           2.
    175,          -4.,           5.,   1.90666962
    176,          -4.,           5.,   1.81331825
    177,          -4.,           5.,   1.72020626
    178,          -4.,           5.,   1.62761402
    179,          -4.,           5.,   1.53575552
    180,          -4.,           5.,   1.44471991
    181,          -4.,           5.,   1.35448492
    182,          -4.,           5.,   1.26497471
    183,          -4.,           5.,   1.17611253
    184,          -4.,           5.,    1.0878247
    185,          -4.,   4.89500761,           1.
    186,          -4.,   4.79059315,           1.
    187,          -4.,   4.69113874,           1.
    188,          -4.,   4.59396315,           1.
    189,          -4.,   4.49909496,           1.
    190,          -4.,    4.4083147,           1.
    191,          -4.,   4.32152939,           1.
    192,          -4.,   4.23945093,           1.
    193,          -4.,   4.16602993,           1.
    194,          -4.,           4.,   1.06880665
    195,          -4.,           4.,   1.04572082
    196,          -4.,           4.,   1.02293539
    197,          -4.,   4.02224541,           1.
    198,          -4.,   4.04476166,           1.
    199,          -4.,   4.06817436,           1.
    200,   -4.0999999,           5.,           1.
    201,  -4.19999981,           5.,           1.
    202,  -4.30000019,           5.,           1.
    203,   -4.4000001,           5.,           1.
    204,         -4.5,           5.,           1.
    205,   -4.5999999,           5.,           1.
    206,  -4.69999981,           5.,           1.
    207,  -4.80000019,           5.,           1.
    208,   -4.9000001,           5.,           1.
    209,   -4.9000001,           5.,           2.
    210,  -4.80000019,           5.,           2.
    211,  -4.69999981,           5.,           2.
    212,   -4.5999999,           5.,           2.
    213,         -4.5,           5.,           2.
    214,   -4.4000001,           5.,           2.
    215,  -4.30000019,           5.,           2.
    216,  -4.19999981,           5.,           2.
    217,   -4.0999999,           5.,           2.
    218,   -4.9000001,           4.,           2.
    219,  -4.80000019,           4.,           2.
    220,  -4.69999981,           4.,           2.
    221,   -4.5999999,           4.,           2.
    222,         -4.5,           4.,           2.
    223,   -4.4000001,           4.,           2.
    224,  -4.30000019,           4.,           2.
    225,  -4.19999981,           4.,           2.
    226,   -4.0999999,           4.,           2.
    227,   -4.9000001,           4.,           1.
    228,  -4.80000019,           4.,           1.
    229,  -4.69999981,           4.,           1.
    230,   -4.5999999,           4.,           1.
    231,         -4.5,           4.,           1.
    232,   -4.4000001,           4.,           1.
    233,  -4.30000019,           4.,           1.
    234,  -4.19999981,           4.,           1.
    235,   -4.0999999,           4.,           1.
    236,          -5.,           4.,   1.02293539
    237,          -5.,           4.,   1.04572082
    238,          -5.,           4.,   1.06880665
    239,          -5.,           4.,      1.09375
    240,          -5.,           4.,    1.1959933
    241,          -5.,           4.,   1.28467679
    242,          -5.,           4.,    1.3807888
    243,          -5.,           4.,   1.47567558
    244,          -5.,           4.,    1.5677737
    245,          -5.,           4.,   1.65489125
    246,          -5.,           4.,   1.73922157
    247,          -5.,           4.,   1.81893182
    248,          -5.,           4.,      1.90625
    249,          -5.,           4.,   1.93175268
    250,          -5.,           4.,   1.95512819
    251,          -5.,           4.,   1.97766066
    252,          -5.,   4.02227402,           2.
    253,          -5.,   4.04477119,           2.
    254,          -5.,   4.06816053,           2.
    255,          -5.,      4.09375,           2.
    256,          -5.,   4.16161203,           2.
    257,          -5.,   4.22976112,           2.
    258,          -5.,   4.30356359,           2.
    259,          -5.,   4.38937283,           2.
    260,          -5.,   4.48416996,           2.
    261,          -5.,   4.58394909,           2.
    262,          -5.,   4.68604708,           2.
    263,          -5.,     4.789258,           2.
    264,          -5.,    4.8944397,           2.
    265,          -5.,           5.,   1.90666962
    266,          -5.,           5.,   1.81331825
    267,          -5.,           5.,   1.72020614
    268,          -5.,           5.,   1.62761402
    269,          -5.,           5.,   1.53575552
    270,          -5.,           5.,   1.44471991
    271,          -5.,           5.,   1.35448492
    272,          -5.,           5.,   1.26497471
    273,          -5.,           5.,   1.17611253
    274,          -5.,           5.,    1.0878247
    275,          -5.,   4.89500809,           1.
    276,          -5.,   4.79059315,           1.
    277,          -5.,   4.69114208,           1.
    278,          -5.,   4.59433365,           1.
    279,          -5.,   4.49960423,           1.
    280,          -5.,   4.40878439,           1.
    281,          -5.,   4.32177258,           1.
    282,          -5.,   4.23990154,           1.
    283,          -5.,   4.16601658,           1.
    284,          -5.,      4.09375,           1.
    285,          -5.,   4.06817436,           1.
    286,          -5.,   4.04476166,           1.
    287,          -5.,   4.02224541,           1.
    288,          -4.,   4.09023237,   2.02544022
    289,          -4.,   4.08048105,   2.04808164
    290,          -4.,   4.06615973,    2.0664227
    291,          -4.,   4.04792595,    2.0805738
    292,          -4.,   4.02554178,   2.09020352
    293,          -4.,           4.,   2.06831408
    294,          -4.,           4.,   2.04493904
    295,          -4.,           4.,   2.02237296
    296,          -4.,   4.03038311,   2.91130996
    297,          -4.,   4.05580616,   2.92466927
    298,          -4.,   4.07577896,   2.94480395
    299,          -4.,   4.08906841,   2.97074437
    300,          -4.,   4.16051006,           3.
    301,          -4.,   4.22912169,           3.
    302,          -4.,   4.30865097,           3.
    303,          -4.,   4.39743853,           3.
    304,          -4.,    4.4904213,           3.
    305,          -4.,   4.58789587,           3.
    306,          -4.,   4.68705225,           3.
    307,          -4.,   4.78975964,           3.
    308,          -4.,   4.89457941,           3.
    309,          -4.,           5.,    2.9175415
    310,          -4.,           5.,   2.83483577
    311,          -4.,           5.,   2.75144887
    312,          -4.,           5.,   2.66646767
    313,          -4.,           5.,   2.57763124
    314,          -4.,           5.,   2.48536658
    315,          -4.,           5.,   2.39205194
    316,          -4.,           5.,   2.29633784
    317,          -4.,           5.,   2.19771409
    318,          -4.,           5.,   2.09881759
    319,          -4.,           4.,   2.18229747
    320,          -4.,           4.,   2.26945853
    321,          -4.,           4.,   2.36413836
    322,          -4.,           4.,   2.46745372
    323,          -4.,           4.,   2.57741237
    324,          -4.,           4.,   2.69320965
    325,          -4.,           4.,   2.79755664
    326,          -4.,   4.05993605,           3.
    327,          -4.,   4.02930593,           3.
    328,          -4.,           4.,   2.97727394
    329,          -4.,           4.,   2.95459414
    330,          -4.,           4.,   2.93154669
    331,   -4.9000001,           5.,           3.
    332,  -4.80000019,           5.,           3.
    333,  -4.69999981,           5.,           3.
    334,   -4.5999999,           5.,           3.
    335,         -4.5,           5.,           3.
    336,   -4.4000001,           5.,           3.
    337,  -4.30000019,           5.,           3.
    338,  -4.19999981,           5.,           3.
    339,   -4.0999999,           5.,           3.
    340,   -4.0999999,           4.,           3.
    341,  -4.19999981,           4.,           3.
    342,  -4.30000019,           4.,           3.
    343,   -4.4000001,           4.,           3.
    344,         -4.5,           4.,           3.
    345,   -4.5999999,           4.,           3.
    346,  -4.69999981,           4.,           3.
    347,  -4.80000019,           4.,           3.
    348,   -4.9000001,           4.,           3.
    349,          -5.,           4.,   2.02237296
    350,          -5.,           4.,   2.04493904
    351,          -5.,           4.,   2.06831408
    352,          -5.,           4.,      2.09375
    353,          -5.,           4.,   2.18219471
    354,          -5.,           4.,   2.26937294
    355,          -5.,           4.,   2.36404705
    356,          -5.,           4.,    2.4673667
    357,          -5.,           4.,    2.5773921
    358,          -5.,           4.,   2.69318724
    359,          -5.,           4.,   2.79750061
    360,          -5.,           4.,      2.90625
    361,          -5.,           4.,   2.93154669
    362,          -5.,           4.,   2.95459414
    363,          -5.,           4.,   2.97727394
    364,          -5.,   4.02930593,           3.
    365,          -5.,   4.05993605,           3.
    366,          -5.,      4.09375,           3.
    367,          -5.,   4.16023064,           3.
    368,          -5.,   4.22873497,           3.
    369,          -5.,   4.30843306,           3.
    370,          -5.,   4.39756155,           3.
    371,          -5.,   4.49048328,           3.
    372,          -5.,   4.58795023,           3.
    373,          -5.,   4.68706512,           3.
    374,          -5.,   4.78976345,           3.
    375,          -5.,   4.89458084,           3.
    376,          -5.,           5.,    2.9175415
    377,          -5.,           5.,   2.83483577
    378,          -5.,           5.,   2.75144887
    379,          -5.,           5.,   2.66646767
    380,          -5.,           5.,   2.57763124
    381,          -5.,           5.,   2.48536658
    382,          -5.,           5.,   2.39205194
    383,          -5.,           5.,   2.29633784
    384,          -5.,           5.,   2.19771409
    385,          -5.,           5.,   2.09881759
    386,          -4.,   4.02203655,  0.908876777
    387,          -4.,   4.04264116,  0.916508734
    388,          -4.,   4.06063557,  0.928499043
    389,          -4.,   4.07616043,  0.945331633
    390,          -4.,   4.08884764,  0.970080733
    391,          -4.,           5.,  0.899779499
    392,          -4.,           5.,  0.799583256
    393,          -4.,           5.,  0.699396074
    394,          -4.,           5.,  0.599217594
    395,          -4.,           5.,  0.499076724
    396,          -4.,           5.,  0.399024606
    397,          -4.,           5.,  0.299102724
    398,          -4.,           5.,  0.199316502
    399,          -4.,           5., 0.0996359214
    400,          -4.,   4.91381073,           0.
    401,          -4.,   4.82578707,           0.
    402,          -4.,   4.73567247,           0.
    403,          -4.,   4.64442396,           0.
    404,          -4.,   4.55296326,           0.
    405,          -4.,   4.46127796,           0.
    406,          -4.,    4.3701272,           0.
    407,          -4.,   4.27966499,           0.
    408,          -4.,   4.18753386,           0.
    409,          -4.,   4.09371185,           0.
    410,          -4.,           4., 0.0994528159
    411,          -4.,           4.,  0.199099138
    412,          -4.,           4.,  0.299183965
    413,          -4.,           4.,  0.399916738
    414,          -4.,           4.,  0.501541972
    415,          -4.,           4.,  0.603787422
    416,          -4.,           4.,  0.705030262
    417,          -4.,           4.,  0.804038644
    418,          -4.,           4.,  0.977053523
    419,          -4.,           4.,  0.954231679
    420,          -4.,           4.,  0.931131601
    421,   -4.0999999,           4.,           0.
    422,  -4.19999981,           4.,           0.
    423,  -4.30000019,           4.,           0.
    424,   -4.4000001,           4.,           0.
    425,         -4.5,           4.,           0.
    426,   -4.5999999,           4.,           0.
    427,  -4.69999981,           4.,           0.
    428,  -4.80000019,           4.,           0.
    429,   -4.9000001,           4.,           0.
    430,   -4.9000001,           5.,           0.
    431,  -4.80000019,           5.,           0.
    432,  -4.69999981,           5.,           0.
    433,   -4.5999999,           5.,           0.
    434,         -4.5,           5.,           0.
    435,   -4.4000001,           5.,           0.
    436,  -4.30000019,           5.,           0.
    437,  -4.19999981,           5.,           0.
    438,   -4.0999999,           5.,           0.
    439,          -5.,           4., 0.0994525626
    440,          -5.,           4.,  0.199098632
    441,          -5.,           4.,  0.299182981
    442,          -5.,           4.,  0.399915397
    443,          -5.,           4.,  0.501552284
    444,          -5.,           4.,  0.603811979
    445,          -5.,           4.,  0.705083013
    446,          -5.,           4.,  0.804041386
    447,          -5.,           4.,      0.90625
    448,          -5.,           4.,  0.931131601
    449,          -5.,           4.,  0.954231679
    450,          -5.,           4.,  0.977053523
    451,          -5.,           5.,  0.899779499
    452,          -5.,           5.,  0.799583256
    453,          -5.,           5.,  0.699396074
    454,          -5.,           5.,  0.599217594
    455,          -5.,           5.,  0.499076724
    456,          -5.,           5.,  0.399024606
    457,          -5.,           5.,  0.299102724
    458,          -5.,           5.,  0.199316502
    459,          -5.,           5., 0.0996359214
    460,          -5.,   4.91381073,           0.
    461,          -5.,   4.82578707,           0.
    462,          -5.,   4.73546553,           0.
    463,          -5.,   4.64397287,           0.
    464,          -5.,   4.55240965,           0.
    465,          -5.,   4.46086073,           0.
    466,          -5.,   4.36996222,           0.
    467,          -5.,   4.27966499,           0.
    468,          -5.,   4.18753386,           0.
    469,          -5.,   4.09371185,           0.
    470,   -3.0999999,           4.,      0.90625
    471,  -3.20000005,           4.,      0.90625
    472,  -3.29999995,           4.,      0.90625
    473,   -3.4000001,           4.,      0.90625
    474,         -3.5,           4.,      0.90625
    475,   -3.5999999,           4.,      0.90625
    476,  -3.70000005,           4.,      0.90625
    477,  -3.79999995,           4.,      0.90625
    478,   -3.9000001,           4.,      0.90625
    479,   -3.9000001,           4.,           0.
    480,  -3.79999995,           4.,           0.
    481,  -3.70000005,           4.,           0.
    482,   -3.5999999,           4.,           0.
    483,         -3.5,           4.,           0.
    484,   -3.4000001,           4.,           0.
    485,  -3.29999995,           4.,           0.
    486,  -3.20000005,           4.,           0.
    487,   -3.0999999,           4.,           0.
    488,   -3.0999999,      4.09375,           1.
    489,  -3.20000005,      4.09375,           1.
    490,  -3.29999995,      4.09375,           1.
    491,   -3.4000001,      4.09375,           1.
    492,         -3.5,      4.09375,           1.
    493,   -3.5999999,      4.09375,           1.
    494,  -3.70000005,      4.09375,           1.
    495,  -3.79999995,      4.09375,           1.
    496,   -3.9000001,      4.09375,           1.
    497,   -3.9000001,           5.,           0.
    498,  -3.79999995,           5.,           0.
    499,  -3.70000005,           5.,           0.
    500,   -3.5999999,           5.,           0.
    501,         -3.5,           5.,           0.
    502,   -3.4000001,           5.,           0.
    503,  -3.29999995,           5.,           0.
    504,  -3.20000005,           5.,           0.
    505,   -3.0999999,           5.,           0.
    506,   -3.0999999,           5.,           1.
    507,  -3.20000005,           5.,           1.
    508,  -3.29999995,           5.,           1.
    509,   -3.4000001,           5.,           1.
    510,         -3.5,           5.,           1.
    511,   -3.5999999,           5.,           1.
    512,  -3.70000005,           5.,           1.
    513,  -3.79999995,           5.,           1.
    514,   -3.9000001,           5.,           1.
    515,          -3.,   4.08885431,  0.970100522
    516,          -3.,   4.07607841,  0.945217609
    517,          -3.,     4.059659,  0.927682281
    518,          -3.,   4.04139137,   0.91588223
    519,          -3.,   4.02111483,  0.908658803
    520,          -3.,           4.,  0.804035902
    521,          -3.,           4.,  0.704977512
    522,          -3.,           4.,  0.603762865
    523,          -3.,           4.,  0.501531661
    524,          -3.,           4.,  0.399918109
    525,          -3.,           4.,  0.299184978
    526,          -3.,           4.,   0.19909966
    527,          -3.,           4., 0.0994530693
    528,          -3.,   4.09371185,           0.
    529,          -3.,   4.18753386,           0.
    530,          -3.,   4.27966499,           0.
    531,          -3.,   4.37029219,           0.
    532,          -3.,   4.46169519,           0.
    533,          -3.,   4.55351686,           0.
    534,          -3.,   4.64487505,           0.
    535,          -3.,   4.73587942,           0.
    536,          -3.,   4.82578707,           0.
    537,          -3.,   4.91381073,           0.
    538,          -3.,           5., 0.0996359214
    539,          -3.,           5.,  0.199316502
    540,          -3.,           5.,  0.299102724
    541,          -3.,           5.,  0.399024606
    542,          -3.,           5.,  0.499076724
    543,          -3.,           5.,  0.599217594
    544,          -3.,           5.,  0.699396074
    545,          -3.,           5.,  0.799583256
    546,          -3.,           5.,  0.899779499
    547,          -3.,   4.89500761,           1.
    548,          -3.,   4.79059219,           1.
    549,          -3.,   4.69113541,           1.
    550,          -3.,   4.59359217,           1.
    551,          -3.,   4.49858522,           1.
    552,          -3.,    4.4078455,           1.
    553,          -3.,    4.3212862,           1.
    554,          -3.,   4.23900032,           1.
    555,          -3.,   4.16604328,           1.
    556,   -3.0999999,           4.,      2.90625
    557,  -3.20000005,           4.,      2.90625
    558,  -3.29999995,           4.,      2.90625
    559,   -3.4000001,           4.,      2.90625
    560,         -3.5,           4.,      2.90625
    561,   -3.5999999,           4.,      2.90625
    562,  -3.70000005,           4.,      2.90625
    563,  -3.79999995,           4.,      2.90625
    564,   -3.9000001,           4.,      2.90625
    565,   -3.9000001,           4.,      2.09375
    566,  -3.79999995,           4.,      2.09375
    567,  -3.70000005,           4.,      2.09375
    568,   -3.5999999,           4.,      2.09375
    569,         -3.5,           4.,      2.09375
    570,   -3.4000001,           4.,      2.09375
    571,  -3.29999995,           4.,      2.09375
    572,  -3.20000005,           4.,      2.09375
    573,   -3.0999999,           4.,      2.09375
    574,   -3.9000001,      4.09375,           2.
    575,  -3.79999995,      4.09375,           2.
    576,  -3.70000005,      4.09375,           2.
    577,   -3.5999999,      4.09375,           2.
    578,         -3.5,      4.09375,           2.
    579,   -3.4000001,      4.09375,           2.
    580,  -3.29999995,      4.09375,           2.
    581,  -3.20000005,      4.09375,           2.
    582,   -3.0999999,      4.09375,           2.
    583,   -3.0999999,      4.09375,           3.
    584,  -3.20000005,      4.09375,           3.
    585,  -3.29999995,      4.09375,           3.
    586,   -3.4000001,      4.09375,           3.
    587,         -3.5,      4.09375,           3.
    588,   -3.5999999,      4.09375,           3.
    589,  -3.70000005,      4.09375,           3.
    590,  -3.79999995,      4.09375,           3.
    591,   -3.9000001,      4.09375,           3.
    592,   -3.0999999,           5.,           2.
    593,  -3.20000005,           5.,           2.
    594,  -3.29999995,           5.,           2.
    595,   -3.4000001,           5.,           2.
    596,         -3.5,           5.,           2.
    597,   -3.5999999,           5.,           2.
    598,  -3.70000005,           5.,           2.
    599,  -3.79999995,           5.,           2.
    600,   -3.9000001,           5.,           2.
    601,   -3.0999999,           5.,           3.
    602,  -3.20000005,           5.,           3.
    603,  -3.29999995,           5.,           3.
    604,   -3.4000001,           5.,           3.
    605,         -3.5,           5.,           3.
    606,   -3.5999999,           5.,           3.
    607,  -3.70000005,           5.,           3.
    608,  -3.79999995,           5.,           3.
    609,   -3.9000001,           5.,           3.
    610,          -3.,    4.0895133,   2.97213531
    611,          -3.,   4.07688046,   2.94634891
    612,          -3.,    4.0565629,   2.92523599
    613,          -3.,   4.03046989,   2.91133976
    614,          -3.,           4.,   2.79761291
    615,          -3.,           4.,   2.69323206
    616,          -3.,           4.,   2.57743239
    617,          -3.,           4.,   2.46754074
    618,          -3.,           4.,   2.36422968
    619,          -3.,           4.,   2.26954365
    620,          -3.,           4.,   2.18240023
    621,          -3.,    4.0249877,    2.0903585
    622,          -3.,   4.04739189,   2.08088923
    623,          -3.,   4.06628942,     2.066293
    624,          -3.,   4.08098507,    2.0472281
    625,          -3.,   4.09045172,   2.02464867
    626,          -3.,    4.1617527,           2.
    627,          -3.,   4.22984076,           2.
    628,          -3.,    4.3035841,           2.
    629,          -3.,   4.38937569,           2.
    630,          -3.,   4.48417091,           2.
    631,          -3.,   4.58394909,           2.
    632,          -3.,   4.68604755,           2.
    633,          -3.,     4.789258,           2.
    634,          -3.,    4.8944397,           2.
    635,          -3.,           5.,   2.09881759
    636,          -3.,           5.,   2.19771409
    637,          -3.,           5.,   2.29633784
    638,          -3.,           5.,   2.39205194
    639,          -3.,           5.,   2.48536658
    640,          -3.,           5.,   2.57763124
    641,          -3.,           5.,   2.66646767
    642,          -3.,           5.,   2.75144887
    643,          -3.,           5.,   2.83483577
    644,          -3.,           5.,    2.9175415
    645,          -3.,   4.89457798,           3.
    646,          -3.,   4.78975582,           3.
    647,          -3.,   4.68703938,           3.
    648,          -3.,   4.58784199,           3.
    649,          -3.,   4.49035931,           3.
    650,          -3.,   4.39731503,           3.
    651,          -3.,   4.30886841,           3.
    652,          -3.,    4.2295084,           3.
    653,          -3.,   4.16078949,           3.
    654,   -3.9000001,           4.,      1.90625
    655,  -3.79999995,           4.,      1.90625
    656,  -3.70000005,           4.,      1.90625
    657,   -3.5999999,           4.,      1.90625
    658,         -3.5,           4.,      1.90625
    659,   -3.4000001,           4.,      1.90625
    660,  -3.29999995,           4.,      1.90625
    661,  -3.20000005,           4.,      1.90625
    662,   -3.0999999,           4.,      1.90625
    663,   -3.9000001,           4.,      1.09375
    664,  -3.79999995,           4.,      1.09375
    665,  -3.70000005,           4.,      1.09375
    666,   -3.5999999,           4.,      1.09375
    667,         -3.5,           4.,      1.09375
    668,   -3.4000001,           4.,      1.09375
    669,  -3.29999995,           4.,      1.09375
    670,  -3.20000005,           4.,      1.09375
    671,   -3.0999999,           4.,      1.09375
    672,          -3.,   4.02748585,   1.08963037
    673,          -3.,    4.0507102,   1.07885122
    674,          -3.,   4.06936216,   1.06307113
    675,          -3.,   4.08283329,   1.04390562
    676,          -3.,   4.09098387,   1.02260566
    677,          -3.,           5.,    1.0878247
    678,          -3.,           5.,   1.17611253
    679,          -3.,           5.,   1.26497471
    680,          -3.,           5.,   1.35448492
    681,          -3.,           5.,   1.44471991
    682,          -3.,           5.,   1.53575552
    683,          -3.,           5.,   1.62761402
    684,          -3.,           5.,   1.72020626
    685,          -3.,           5.,   1.81331837
    686,          -3.,           5.,   1.90666962
    687,          -3.,   4.09047031,   1.97541964
    688,          -3.,   4.08089399,    1.9526161
    689,          -3.,   4.06579256,   1.93321395
    690,          -3.,   4.04632759,   1.91849649
    691,          -3.,   4.02386713,   1.90933895
    692,          -3.,           4.,   1.81800747
    693,          -3.,           4.,   1.73842978
    694,          -3.,           4.,    1.6537137
    695,          -3.,           4.,    1.5675056
    696,          -3.,           4.,   1.47574759
    697,          -3.,           4.,   1.38072455
    698,          -3.,           4.,   1.28466249
    699,          -3.,           4.,   1.19601631
    700,          -4.,   4.09065485,   4.02389145
    701,          -4.,   4.08180618,   4.04579067
    702,          -4.,   4.06832075,   4.06419754
    703,          -4.,   4.05005455,   4.07926893
    704,          -4.,   4.02662802,   4.08988905
    705,          -4.,           4.,   4.06799603
    706,          -4.,           4.,   4.04455757
    707,          -4.,           4.,    4.0221405
    708,          -4.,   4.02308321,           4.
    709,          -4.,   4.04589176,           4.
    710,          -4.,   4.06890154,           4.
    711,          -4.,   4.03370094,   4.91251707
    712,          -4.,   4.05926514,    4.9273591
    713,          -4.,   4.07739305,   4.94709063
    714,          -4.,   4.08946609,   4.97198439
    715,          -4.,   4.06013775,           5.
    716,          -4.,   4.02947235,           5.
    717,          -4.,           4.,   4.97677326
    718,          -4.,           4.,   4.95401096
    719,          -4.,           4.,   4.93123245
    720,          -4.,   4.18447495,           5.
    721,          -4.,   4.27451706,           5.
    722,          -4.,   4.37127304,           5.
    723,          -4.,   4.47272015,           5.
    724,          -4.,   4.57664299,           5.
    725,          -4.,   4.68163204,           5.
    726,          -4.,   4.78766155,           5.
    727,          -4.,   4.89381504,           5.
    728,          -4.,           5.,   4.90022087
    729,          -4.,           5.,    4.8004818
    730,          -4.,           5.,   4.70069313
    731,          -4.,           5.,   4.60077524
    732,          -4.,           5.,   4.50069046
    733,          -4.,           5.,   4.40045214
    734,          -4.,           5.,   4.30014944
    735,          -4.,           5.,   4.19992542
    736,          -4.,           5.,   4.09988308
    737,          -4.,   4.89366484,           4.
    738,          -4.,   4.78722763,           4.
    739,          -4.,   4.68052483,           4.
    740,          -4.,   4.57327509,           4.
    741,          -4.,   4.46769047,           4.
    742,          -4.,   4.36333084,           4.
    743,          -4.,   4.26825333,           4.
    744,          -4.,   4.18132401,           4.
    745,          -4.,           4.,   4.18770313
    746,          -4.,           4.,   4.27868938
    747,          -4.,           4.,   4.37490606
    748,          -4.,           4.,   4.47031546
    749,          -4.,           4.,   4.56664562
    750,          -4.,           4.,   4.66058254
    751,          -4.,           4.,   4.74898767
    752,          -4.,           4.,   4.82788515
    753,   -4.0999999,           4.,           5.
    754,  -4.19999981,           4.,           5.
    755,  -4.30000019,           4.,           5.
    756,   -4.4000001,           4.,           5.
    757,         -4.5,           4.,           5.
    758,   -4.5999999,           4.,           5.
    759,  -4.69999981,           4.,           5.
    760,  -4.80000019,           4.,           5.
    761,   -4.9000001,           4.,           5.
    762,   -4.9000001,           4.,           4.
    763,  -4.80000019,           4.,           4.
    764,  -4.69999981,           4.,           4.
    765,   -4.5999999,           4.,           4.
    766,         -4.5,           4.,           4.
    767,   -4.4000001,           4.,           4.
    768,  -4.30000019,           4.,           4.
    769,  -4.19999981,           4.,           4.
    770,   -4.0999999,           4.,           4.
    771,   -4.0999999,           5.,           5.
    772,  -4.19999981,           5.,           5.
    773,  -4.30000019,           5.,           5.
    774,   -4.4000001,           5.,           5.
    775,         -4.5,           5.,           5.
    776,   -4.5999999,           5.,           5.
    777,  -4.69999981,           5.,           5.
    778,  -4.80000019,           5.,           5.
    779,   -4.9000001,           5.,           5.
    780,   -4.0999999,           5.,           4.
    781,  -4.19999981,           5.,           4.
    782,  -4.30000019,           5.,           4.
    783,   -4.4000001,           5.,           4.
    784,         -4.5,           5.,           4.
    785,   -4.5999999,           5.,           4.
    786,  -4.69999981,           5.,           4.
    787,  -4.80000019,           5.,           4.
    788,   -4.9000001,           5.,           4.
    789,          -5.,           4.,    4.0221405
    790,          -5.,           4.,   4.04455757
    791,          -5.,           4.,   4.06799603
    792,          -5.,           4.,      4.09375
    793,          -5.,           4.,   4.18774223
    794,          -5.,           4.,   4.27873182
    795,          -5.,           4.,   4.37493038
    796,          -5.,           4.,   4.47031212
    797,          -5.,           4.,   4.56661177
    798,          -5.,           4.,   4.66040421
    799,          -5.,           4.,   4.74888706
    800,          -5.,           4.,   4.82777023
    801,          -5.,           4.,      4.90625
    802,          -5.,           4.,   4.93123245
    803,          -5.,           4.,   4.95401096
    804,          -5.,           4.,   4.97677326
    805,          -5.,   4.02947235,           5.
    806,          -5.,   4.06013775,           5.
    807,          -5.,      4.09375,           5.
    808,          -5.,   4.18426991,           5.
    809,          -5.,   4.27436256,           5.
    810,          -5.,   4.37117243,           5.
    811,          -5.,   4.47266245,           5.
    812,          -5.,   4.57661963,           5.
    813,          -5.,   4.68162727,           5.
    814,          -5.,   4.78765965,           5.
    815,          -5.,   4.89381409,           5.
    816,          -5.,           5.,   4.90022087
    817,          -5.,           5.,    4.8004818
    818,          -5.,           5.,   4.70069265
    819,          -5.,           5.,   4.60077524
    820,          -5.,           5.,   4.50069046
    821,          -5.,           5.,   4.40045214
    822,          -5.,           5.,   4.30014944
    823,          -5.,           5.,   4.19992542
    824,          -5.,           5.,   4.09988308
    825,          -5.,   4.89366961,           4.
    826,          -5.,   4.78723812,           4.
    827,          -5.,   4.68054581,           4.
    828,          -5.,   4.57334518,           4.
    829,          -5.,   4.46781635,           4.
    830,          -5.,   4.36333418,           4.
    831,          -5.,   4.26822472,           4.
    832,          -5.,   4.18128109,           4.
    833,          -5.,      4.09375,           4.
    834,          -5.,   4.06890154,           4.
    835,          -5.,   4.04589176,           4.
    836,          -5.,   4.02308321,           4.
    837,          -4.,   4.03191137,   3.91184831
    838,          -4.,    4.0585537,   3.92678452
    839,          -4.,   4.07748747,   3.94722891
    840,          -4.,   4.08942556,   3.97185564
    841,          -4.,           4.,   3.97091913
    842,          -4.,           4.,   3.94040442
    843,          -4.,   4.08921671,   3.02880025
    844,          -4.,   4.07636404,   3.05438399
    845,          -4.,   4.05681324,   3.07457423
    846,          -4.,   4.03130102,   3.08837032
    847,          -4.,           4.,   3.06841063
    848,          -4.,           4.,   3.04539442
    849,          -4.,           4.,   3.02275944
    850,          -4.,           4.,   3.19063258
    851,          -4.,           4.,   3.28638506
    852,          -4.,           4.,   3.38822675
    853,          -4.,           4.,   3.48909521
    854,          -4.,           4.,   3.58712196
    855,          -4.,           4.,   3.67896605
    856,          -4.,           4.,   3.76133227
    857,          -4.,           4.,   3.83510137
    858,          -4.,           5.,   3.89402628
    859,          -4.,           5.,   3.78752518
    860,          -4.,           5.,   3.68222618
    861,          -4.,           5.,   3.57873392
    862,          -4.,           5.,   3.47779608
    863,          -4.,           5.,   3.37965775
    864,          -4.,           5.,   3.28378963
    865,          -4.,           5.,   3.18858695
    866,          -4.,           5.,   3.09410286
    867,          -5.,           4.,   3.02275944
    868,          -5.,           4.,   3.04539442
    869,          -5.,           4.,   3.06841063
    870,          -5.,           4.,      3.09375
    871,          -5.,           4.,   3.19068241
    872,          -5.,           4.,   3.28643417
    873,          -5.,           4.,   3.38825655
    874,          -5.,           4.,   3.48911428
    875,          -5.,           4.,   3.58713293
    876,          -5.,           4.,   3.67898536
    877,          -5.,           4.,   3.76138163
    878,          -5.,           4.,   3.83518696
    879,          -5.,           4.,      3.90625
    880,          -5.,           4.,   3.94040442
    881,          -5.,           4.,   3.97091913
    882,          -5.,           5.,    3.8940258
    883,          -5.,           5.,   3.78752398
    884,          -5.,           5.,   3.68222523
    885,          -5.,           5.,   3.57873344
    886,          -5.,           5.,   3.47779584
    887,          -5.,           5.,   3.37965775
    888,          -5.,           5.,   3.28378963
    889,          -5.,           5.,   3.18858695
    890,          -5.,           5.,   3.09410286
    891,          -4.,   4.09111404,    6.0220747
    892,          -4.,   4.08336163,   6.04289436
    893,          -4.,    4.0706315,   6.06164598
    894,          -4.,   4.05435467,   6.07638502
    895,          -4.,   4.02982712,   6.08887863
    896,          -4.,           4.,   6.06837082
    897,          -4.,           4.,   6.04532719
    898,          -4.,           4.,   6.02270317
    899,          -4.,   4.02252483,           6.
    900,          -4.,   4.04519653,           6.
    901,          -4.,   4.06855679,           6.
    902,          -4.,           4.,   6.16480303
    903,          -4.,           4.,   6.23736858
    904,          -4.,           4.,   6.31965208
    905,          -4.,           4.,     6.407372
    906,          -4.,           4.,   6.49943066
    907,          -4.,           4.,   6.59440422
    908,          -4.,           4.,    6.6909771
    909,          -4.,           4.,   6.79143906
    910,          -4.,           4.,   6.89545441
    911,          -4.,   4.10009527,           7.
    912,          -4.,   4.20017958,           7.
    913,          -4.,    4.3002615,           7.
    914,          -4.,   4.40034199,           7.
    915,          -4.,   4.50040913,           7.
    916,          -4.,   4.60043764,           7.
    917,          -4.,    4.7004056,           7.
    918,          -4.,   4.80031061,           7.
    919,          -4.,   4.90016556,           7.
    920,          -4.,           5.,   6.91383553
    921,          -4.,           5.,   6.82583857
    922,          -4.,           5.,   6.73595619
    923,          -4.,           5.,   6.64496994
    924,          -4.,           5.,   6.55362177
    925,          -4.,           5.,   6.46180058
    926,          -4.,           5.,   6.37038803
    927,          -4.,           5.,   6.27974176
    928,          -4.,           5.,   6.18758535
    929,          -4.,           5.,   6.09373856
    930,          -4.,   4.89947414,           6.
    931,          -4.,   4.79881191,           6.
    932,          -4.,   4.69765854,           6.
    933,          -4.,   4.59470749,           6.
    934,          -4.,   4.49272776,           6.
    935,          -4.,   4.39267063,           6.
    936,          -4.,   4.29203224,           6.
    937,          -4.,   4.19502687,           6.
    938,   -4.0999999,           4.,           7.
    939,  -4.19999981,           4.,           7.
    940,  -4.30000019,           4.,           7.
    941,   -4.4000001,           4.,           7.
    942,         -4.5,           4.,           7.
    943,   -4.5999999,           4.,           7.
    944,  -4.69999981,           4.,           7.
    945,  -4.80000019,           4.,           7.
    946,   -4.9000001,           4.,           7.
    947,   -4.9000001,           4.,           6.
    948,  -4.80000019,           4.,           6.
    949,  -4.69999981,           4.,           6.
    950,   -4.5999999,           4.,           6.
    951,         -4.5,           4.,           6.
    952,   -4.4000001,           4.,           6.
    953,  -4.30000019,           4.,           6.
    954,  -4.19999981,           4.,           6.
    955,   -4.0999999,           4.,           6.
    956,   -4.0999999,           5.,           7.
    957,  -4.19999981,           5.,           7.
    958,  -4.30000019,           5.,           7.
    959,   -4.4000001,           5.,           7.
    960,         -4.5,           5.,           7.
    961,   -4.5999999,           5.,           7.
    962,  -4.69999981,           5.,           7.
    963,  -4.80000019,           5.,           7.
    964,   -4.9000001,           5.,           7.
    965,   -4.0999999,           5.,           6.
    966,  -4.19999981,           5.,           6.
    967,  -4.30000019,           5.,           6.
    968,   -4.4000001,           5.,           6.
    969,         -4.5,           5.,           6.
    970,   -4.5999999,           5.,           6.
    971,  -4.69999981,           5.,           6.
    972,  -4.80000019,           5.,           6.
    973,   -4.9000001,           5.,           6.
    974,          -5.,           4.,   6.02270317
    975,          -5.,           4.,   6.04532719
    976,          -5.,           4.,   6.06837082
    977,          -5.,           4.,      6.09375
    978,          -5.,           4.,   6.16478777
    979,          -5.,           4.,   6.23723316
    980,          -5.,           4.,   6.31949806
    981,          -5.,           4.,   6.40724707
    982,          -5.,           4.,   6.49935246
    983,          -5.,           4.,   6.59436464
    984,          -5.,           4.,   6.69097805
    985,          -5.,           4.,   6.79143953
    986,          -5.,           4.,   6.89545441
    987,          -5.,   4.10009575,           7.
    988,          -5.,   4.20017958,           7.
    989,          -5.,    4.3002615,           7.
    990,          -5.,   4.40034199,           7.
    991,          -5.,   4.50040913,           7.
    992,          -5.,   4.60043764,           7.
    993,          -5.,   4.70040607,           7.
    994,          -5.,   4.80031061,           7.
    995,          -5.,   4.90016556,           7.
    996,          -5.,           5.,   6.91383553
    997,          -5.,           5.,   6.82583857
    998,          -5.,           5.,   6.73595572
    999,          -5.,           5.,   6.64496946
   1000,          -5.,           5.,   6.55362082
   1001,          -5.,           5.,   6.46179914
   1002,          -5.,           5.,   6.37038612
   1003,          -5.,           5.,   6.27974081
   1004,          -5.,           5.,   6.18758535
   1005,          -5.,           5.,   6.09373856
   1006,          -5.,   4.89947653,           6.
   1007,          -5.,   4.79881763,           6.
   1008,          -5.,   4.69767189,           6.
   1009,          -5.,   4.59473515,           6.
   1010,          -5.,    4.4927702,           6.
   1011,          -5.,   4.39275742,           6.
   1012,          -5.,    4.2920084,           6.
   1013,          -5.,    4.1948452,           6.
   1014,          -5.,      4.09375,           6.
   1015,          -5.,   4.06855679,           6.
   1016,          -5.,   4.04519653,           6.
   1017,          -5.,   4.02252483,           6.
   1018,          -4.,   4.02749205,   5.91037178
   1019,          -4.,    4.0512805,   5.92151833
   1020,          -4.,   4.06947041,   5.93704844
   1021,          -4.,   4.08253241,   5.95553112
   1022,          -4.,    4.0908618,   5.97690868
   1023,          -4.,           4.,   5.97728252
   1024,          -4.,           4.,   5.95469093
   1025,          -4.,           4.,    5.9316349
   1026,          -4.,   4.08948421,   5.02795744
   1027,          -4.,   4.07740641,   5.05288982
   1028,          -4.,   4.05921412,   5.07268238
   1029,          -4.,    4.0338726,   5.08741665
   1030,          -4.,           4.,   5.06847858
   1031,          -4.,           4.,   5.04566479
   1032,          -4.,           4.,   5.02301884
   1033,          -4.,           4.,   5.17448711
   1034,          -4.,           4.,    5.2561388
   1035,          -4.,           4.,   5.34597731
   1036,          -4.,           4.,   5.44003487
   1037,          -4.,           4.,   5.53623486
   1038,          -4.,           4.,    5.6314497
   1039,          -4.,           4.,   5.72684479
   1040,          -4.,           4.,   5.81574535
   1041,          -4.,           5.,   5.90010881
   1042,          -4.,           5.,   5.80010605
   1043,          -4.,           5.,   5.69994354
   1044,          -4.,           5.,   5.59967661
   1045,          -4.,           5.,   5.49941826
   1046,          -4.,           5.,   5.39926195
   1047,          -4.,           5.,   5.29925537
   1048,          -4.,           5.,   5.19939804
   1049,          -4.,           5.,   5.09965658
   1050,          -5.,           4.,   5.02301884
   1051,          -5.,           4.,   5.04566479
   1052,          -5.,           4.,   5.06847858
   1053,          -5.,           4.,      5.09375
   1054,          -5.,           4.,   5.17469978
   1055,          -5.,           4.,   5.25630188
   1056,          -5.,           4.,   5.34590149
   1057,          -5.,           4.,   5.44002676
   1058,          -5.,           4.,   5.53619623
   1059,          -5.,           4.,   5.63142109
   1060,          -5.,           4.,   5.72679996
   1061,          -5.,           4.,   5.81569958
   1062,          -5.,           4.,      5.90625
   1063,          -5.,           4.,    5.9316349
   1064,          -5.,           4.,   5.95469093
   1065,          -5.,           4.,   5.97728252
   1066,          -5.,           5.,   5.90010881
   1067,          -5.,           5.,   5.80010605
   1068,          -5.,           5.,   5.69994354
   1069,          -5.,           5.,   5.59967661
   1070,          -5.,           5.,   5.49941826
   1071,          -5.,           5.,   5.39926195
   1072,          -5.,           5.,   5.29925537
   1073,          -5.,           5.,   5.19939804
   1074,          -5.,           5.,   5.09965658
   1075,          -4.,           4.,   8.89999962
   1076,          -4.,           4.,   8.80000019
   1077,          -4.,           4.,   8.69999981
   1078,          -4.,           4.,   8.60000038
   1079,          -4.,           4.,          8.5
   1080,          -4.,           4.,   8.39999962
   1081,          -4.,           4.,   8.30000019
   1082,          -4.,           4.,   8.19999981
   1083,          -4.,           4.,   8.10000038
   1084,   -3.9000001,           4.,           8.
   1085,  -3.79999995,           4.,           8.
   1086,  -3.70000005,           4.,           8.
   1087,   -3.5999999,           4.,           8.
   1088,         -3.5,           4.,           8.
   1089,   -3.4000001,           4.,           8.
   1090,  -3.29999995,           4.,           8.
   1091,  -3.20000005,           4.,           8.
   1092,   -3.0999999,           4.,           8.
   1093,          -3.,           4.,   8.10000038
   1094,          -3.,           4.,   8.19999981
   1095,          -3.,           4.,   8.30000019
   1096,          -3.,           4.,   8.39999962
   1097,          -3.,           4.,          8.5
   1098,          -3.,           4.,   8.60000038
   1099,          -3.,           4.,   8.69999981
   1100,          -3.,           4.,   8.80000019
   1101,          -3.,           4.,   8.89999962
   1102,   -3.0999999,           4.,           9.
   1103,  -3.20000005,           4.,           9.
   1104,  -3.29999995,           4.,           9.
   1105,   -3.4000001,           4.,           9.
   1106,         -3.5,           4.,           9.
   1107,   -3.5999999,           4.,           9.
   1108,  -3.70000005,           4.,           9.
   1109,  -3.79999995,           4.,           9.
   1110,   -3.9000001,           4.,           9.
   1111,          -4.,    3.9000001,           9.
   1112,          -4.,   3.79999995,           9.
   1113,          -4.,   3.70000005,           9.
   1114,          -4.,    3.5999999,           9.
   1115,          -4.,          3.5,           9.
   1116,          -4.,    3.4000001,           9.
   1117,          -4.,   3.29999995,           9.
   1118,          -4.,   3.20000005,           9.
   1119,          -4.,    3.0999999,           9.
   1120,          -3.,    3.0999999,           9.
   1121,          -3.,   3.20000005,           9.
   1122,          -3.,   3.29999995,           9.
   1123,          -3.,    3.4000001,           9.
   1124,          -3.,          3.5,           9.
   1125,          -3.,    3.5999999,           9.
   1126,          -3.,   3.70000005,           9.
   1127,          -3.,   3.79999995,           9.
   1128,          -3.,    3.9000001,           9.
   1129,          -3.,    3.0999999,           8.
   1130,          -3.,   3.20000005,           8.
   1131,          -3.,   3.29999995,           8.
   1132,          -3.,    3.4000001,           8.
   1133,          -3.,          3.5,           8.
   1134,          -3.,    3.5999999,           8.
   1135,          -3.,   3.70000005,           8.
   1136,          -3.,   3.79999995,           8.
   1137,          -3.,    3.9000001,           8.
   1138,          -4.,    3.9000001,           8.
   1139,          -4.,   3.79999995,           8.
   1140,          -4.,   3.70000005,           8.
   1141,          -4.,    3.5999999,           8.
   1142,          -4.,          3.5,           8.
   1143,          -4.,    3.4000001,           8.
   1144,          -4.,   3.29999995,           8.
   1145,          -4.,   3.20000005,           8.
   1146,          -4.,    3.0999999,           8.
   1147,          -4.,           3.,   8.89999962
   1148,          -4.,           3.,   8.80000019
   1149,          -4.,           3.,   8.69999981
   1150,          -4.,           3.,   8.60000038
   1151,          -4.,           3.,          8.5
   1152,          -4.,           3.,   8.39999962
   1153,          -4.,           3.,   8.30000019
   1154,          -4.,           3.,   8.19999981
   1155,          -4.,           3.,   8.10000038
   1156,   -3.9000001,           3.,           8.
   1157,  -3.79999995,           3.,           8.
   1158,  -3.70000005,           3.,           8.
   1159,   -3.5999999,           3.,           8.
   1160,         -3.5,           3.,           8.
   1161,   -3.4000001,           3.,           8.
   1162,  -3.29999995,           3.,           8.
   1163,  -3.20000005,           3.,           8.
   1164,   -3.0999999,           3.,           8.
   1165,          -3.,           3.,   8.10000038
   1166,          -3.,           3.,   8.19999981
   1167,          -3.,           3.,   8.30000019
   1168,          -3.,           3.,   8.39999962
   1169,          -3.,           3.,          8.5
   1170,          -3.,           3.,   8.60000038
   1171,          -3.,           3.,   8.69999981
   1172,          -3.,           3.,   8.80000019
   1173,          -3.,           3.,   8.89999962
   1174,   -3.0999999,           3.,           9.
   1175,  -3.20000005,           3.,           9.
   1176,  -3.29999995,           3.,           9.
   1177,   -3.4000001,           3.,           9.
   1178,         -3.5,           3.,           9.
   1179,   -3.5999999,           3.,           9.
   1180,  -3.70000005,           3.,           9.
   1181,  -3.79999995,           3.,           9.
   1182,   -3.9000001,           3.,           9.
   1183,          -4.,           4.,    7.0999999
   1184,          -4.,           4.,   7.19999981
   1185,          -4.,           4.,   7.30000019
   1186,          -4.,           4.,    7.4000001
   1187,          -4.,           4.,          7.5
   1188,          -4.,           4.,    7.5999999
   1189,          -4.,           4.,   7.69999981
   1190,          -4.,           4.,   7.80000019
   1191,          -4.,           4.,    7.9000001
   1192,   -4.0999999,           4.,           8.
   1193,  -4.19999981,           4.,           8.
   1194,  -4.30000019,           4.,           8.
   1195,   -4.4000001,           4.,           8.
   1196,         -4.5,           4.,           8.
   1197,   -4.5999999,           4.,           8.
   1198,  -4.69999981,           4.,           8.
   1199,  -4.80000019,           4.,           8.
   1200,   -4.9000001,           4.,           8.
   1201,          -5.,           4.,    7.9000001
   1202,          -5.,           4.,   7.80000019
   1203,          -5.,           4.,   7.69999981
   1204,          -5.,           4.,    7.5999999
   1205,          -5.,           4.,          7.5
   1206,          -5.,           4.,    7.4000001
   1207,          -5.,           4.,   7.30000019
   1208,          -5.,           4.,   7.19999981
   1209,          -5.,           4.,    7.0999999
   1210,          -5.,    4.0999999,           8.
   1211,          -5.,   4.19999981,           8.
   1212,          -5.,   4.30000019,           8.
   1213,          -5.,    4.4000001,           8.
   1214,          -5.,          4.5,           8.
   1215,          -5.,    4.5999999,           8.
   1216,          -5.,   4.69999981,           8.
   1217,          -5.,   4.80000019,           8.
   1218,          -5.,    4.9000001,           8.
   1219,          -4.,    4.0999999,           8.
   1220,          -4.,   4.19999981,           8.
   1221,          -4.,   4.30000019,           8.
   1222,          -4.,    4.4000001,           8.
   1223,          -4.,          4.5,           8.
   1224,          -4.,    4.5999999,           8.
   1225,          -4.,   4.69999981,           8.
   1226,          -4.,   4.80000019,           8.
   1227,          -4.,    4.9000001,           8.
   1228,          -4.,           5.,    7.9000001
   1229,          -4.,           5.,   7.80000019
   1230,          -4.,           5.,   7.69999981
   1231,          -4.,           5.,    7.5999999
   1232,          -4.,           5.,          7.5
   1233,          -4.,           5.,    7.4000001
   1234,          -4.,           5.,   7.30000019
   1235,          -4.,           5.,   7.19999981
   1236,          -4.,           5.,    7.0999999
   1237,          -5.,           5.,    7.0999999
   1238,          -5.,           5.,   7.19999981
   1239,          -5.,           5.,   7.30000019
   1240,          -5.,           5.,    7.4000001
   1241,          -5.,           5.,          7.5
   1242,          -5.,           5.,    7.5999999
   1243,          -5.,           5.,   7.69999981
   1244,          -5.,           5.,   7.80000019
   1245,          -5.,           5.,    7.9000001
   1246,   -4.9000001,           5.,           8.
   1247,  -4.80000019,           5.,           8.
   1248,  -4.69999981,           5.,           8.
   1249,   -4.5999999,           5.,           8.
   1250,         -4.5,           5.,           8.
   1251,   -4.4000001,           5.,           8.
   1252,  -4.30000019,           5.,           8.
   1253,  -4.19999981,           5.,           8.
   1254,   -4.0999999,           5.,           8.
   1255,          -4.,           4.,   9.89999962
   1256,          -4.,           4.,   9.80000019
   1257,          -4.,           4.,   9.69999981
   1258,          -4.,           4.,   9.60000038
   1259,          -4.,           4.,          9.5
   1260,          -4.,           4.,   9.39999962
   1261,          -4.,           4.,   9.30000019
   1262,          -4.,           4.,   9.19999981
   1263,          -4.,           4.,   9.10000038
   1264,          -3.,           4.,   9.10000038
   1265,          -3.,           4.,   9.19999981
   1266,          -3.,           4.,   9.30000019
   1267,          -3.,           4.,   9.39999962
   1268,          -3.,           4.,          9.5
   1269,          -3.,           4.,   9.60000038
   1270,          -3.,           4.,   9.69999981
   1271,          -3.,           4.,   9.80000019
   1272,          -3.,           4.,   9.89999962
   1273,   -3.0999999,           4.,          10.
   1274,  -3.20000005,           4.,          10.
   1275,  -3.29999995,           4.,          10.
   1276,   -3.4000001,           4.,          10.
   1277,         -3.5,           4.,          10.
   1278,   -3.5999999,           4.,          10.
   1279,  -3.70000005,           4.,          10.
   1280,  -3.79999995,           4.,          10.
   1281,   -3.9000001,           4.,          10.
   1282,          -4.,    3.9000001,          10.
   1283,          -4.,   3.79999995,          10.
   1284,          -4.,   3.70000005,          10.
   1285,          -4.,    3.5999999,          10.
   1286,          -4.,          3.5,          10.
   1287,          -4.,    3.4000001,          10.
   1288,          -4.,   3.29999995,          10.
   1289,          -4.,   3.20000005,          10.
   1290,          -4.,    3.0999999,          10.
   1291,          -3.,    3.0999999,          10.
   1292,          -3.,   3.20000005,          10.
   1293,          -3.,   3.29999995,          10.
   1294,          -3.,    3.4000001,          10.
   1295,          -3.,          3.5,          10.
   1296,          -3.,    3.5999999,          10.
   1297,          -3.,   3.70000005,          10.
   1298,          -3.,   3.79999995,          10.
   1299,          -3.,    3.9000001,          10.
   1300,          -4.,           3.,   9.89999962
   1301,          -4.,           3.,   9.80000019
   1302,          -4.,           3.,   9.69999981
   1303,          -4.,           3.,   9.60000038
   1304,          -4.,           3.,          9.5
   1305,          -4.,           3.,   9.39999962
   1306,          -4.,           3.,   9.30000019
   1307,          -4.,           3.,   9.19999981
   1308,          -4.,           3.,   9.10000038
   1309,          -3.,           3.,   9.10000038
   1310,          -3.,           3.,   9.19999981
   1311,          -3.,           3.,   9.30000019
   1312,          -3.,           3.,   9.39999962
   1313,          -3.,           3.,          9.5
   1314,          -3.,           3.,   9.60000038
   1315,          -3.,           3.,   9.69999981
   1316,          -3.,           3.,   9.80000019
   1317,          -3.,           3.,   9.89999962
   1318,   -3.0999999,           3.,          10.
   1319,  -3.20000005,           3.,          10.
   1320,  -3.29999995,           3.,          10.
   1321,   -3.4000001,           3.,          10.
   1322,         -3.5,           3.,          10.
   1323,   -3.5999999,           3.,          10.
   1324,  -3.70000005,           3.,          10.
   1325,  -3.79999995,           3.,          10.
   1326,   -3.9000001,           3.,          10.
   1327,          -4.,    4.0999999,           9.
   1328,          -4.,   4.19999981,           9.
   1329,          -4.,   4.30000019,           9.
   1330,          -4.,    4.4000001,           9.
   1331,          -4.,          4.5,           9.
   1332,          -4.,    4.5999999,           9.
   1333,          -4.,   4.69999981,           9.
   1334,          -4.,   4.80000019,           9.
   1335,          -4.,    4.9000001,           9.
   1336,   -4.0999999,           5.,           9.
   1337,  -4.19999981,           5.,           9.
   1338,  -4.30000019,           5.,           9.
   1339,   -4.4000001,           5.,           9.
   1340,         -4.5,           5.,           9.
   1341,   -4.5999999,           5.,           9.
   1342,  -4.69999981,           5.,           9.
   1343,  -4.80000019,           5.,           9.
   1344,   -4.9000001,           5.,           9.
   1345,          -5.,    4.9000001,           9.
   1346,          -5.,   4.80000019,           9.
   1347,          -5.,   4.69999981,           9.
   1348,          -5.,    4.5999999,           9.
   1349,          -5.,          4.5,           9.
   1350,          -5.,    4.4000001,           9.
   1351,          -5.,   4.30000019,           9.
   1352,          -5.,   4.19999981,           9.
   1353,          -5.,    4.0999999,           9.
   1354,   -4.9000001,           4.,           9.
   1355,  -4.80000019,           4.,           9.
   1356,  -4.69999981,           4.,           9.
   1357,   -4.5999999,           4.,           9.
   1358,         -4.5,           4.,           9.
   1359,   -4.4000001,           4.,           9.
   1360,  -4.30000019,           4.,           9.
   1361,  -4.19999981,           4.,           9.
   1362,   -4.0999999,           4.,           9.
   1363,          -5.,           4.,   9.89999962
   1364,          -5.,           4.,   9.80000019
   1365,          -5.,           4.,   9.69999981
   1366,          -5.,           4.,   9.60000038
   1367,          -5.,           4.,          9.5
   1368,          -5.,           4.,   9.39999962
   1369,          -5.,           4.,   9.30000019
   1370,          -5.,           4.,   9.19999981
   1371,          -5.,           4.,   9.10000038
   1372,          -5.,           5.,   9.89999962
   1373,          -5.,           5.,   9.80000019
   1374,          -5.,           5.,   9.69999981
   1375,          -5.,           5.,   9.60000038
   1376,          -5.,           5.,          9.5
   1377,          -5.,           5.,   9.39999962
   1378,          -5.,           5.,   9.30000019
   1379,          -5.,           5.,   9.19999981
   1380,          -5.,           5.,   9.10000038
   1381,          -4.,           5.,   9.89999962
   1382,          -4.,           5.,   9.80000019
   1383,          -4.,           5.,   9.69999981
   1384,          -4.,           5.,   9.60000038
   1385,          -4.,           5.,          9.5
   1386,          -4.,           5.,   9.39999962
   1387,          -4.,           5.,   9.30000019
   1388,          -4.,           5.,   9.19999981
   1389,          -4.,           5.,   9.10000038
   1390,          -4.,    4.0999999,          10.
   1391,          -4.,   4.19999981,          10.
   1392,          -4.,   4.30000019,          10.
   1393,          -4.,    4.4000001,          10.
   1394,          -4.,          4.5,          10.
   1395,          -4.,    4.5999999,          10.
   1396,          -4.,   4.69999981,          10.
   1397,          -4.,   4.80000019,          10.
   1398,          -4.,    4.9000001,          10.
   1399,   -4.0999999,           5.,          10.
   1400,  -4.19999981,           5.,          10.
   1401,  -4.30000019,           5.,          10.
   1402,   -4.4000001,           5.,          10.
   1403,         -4.5,           5.,          10.
   1404,   -4.5999999,           5.,          10.
   1405,  -4.69999981,           5.,          10.
   1406,  -4.80000019,           5.,          10.
   1407,   -4.9000001,           5.,          10.
   1408,          -5.,    4.9000001,          10.
   1409,          -5.,   4.80000019,          10.
   1410,          -5.,   4.69999981,          10.
   1411,          -5.,    4.5999999,          10.
   1412,          -5.,          4.5,          10.
   1413,          -5.,    4.4000001,          10.
   1414,          -5.,   4.30000019,          10.
   1415,          -5.,   4.19999981,          10.
   1416,          -5.,    4.0999999,          10.
   1417,   -4.9000001,           4.,          10.
   1418,  -4.80000019,           4.,          10.
   1419,  -4.69999981,           4.,          10.
   1420,   -4.5999999,           4.,          10.
   1421,         -4.5,           4.,          10.
   1422,   -4.4000001,           4.,          10.
   1423,  -4.30000019,           4.,          10.
   1424,  -4.19999981,           4.,          10.
   1425,   -4.0999999,           4.,          10.
   1426,          -4.,   3.88400626,           7.
   1427,          -4.,   3.76914096,           7.
   1428,          -4.,   3.65751266,           7.
   1429,          -4.,    3.5459404,           7.
   1430,          -4.,   3.43482447,           7.
   1431,          -4.,   3.34511542,           7.
   1432,          -4.,   3.25648594,           7.
   1433,          -4.,   3.16876054,           7.
   1434,          -4.,   3.08330345,           7.
   1435,          -4.,           3.,    7.0999999
   1436,          -4.,           3.,   7.19999981
   1437,          -4.,           3.,   7.30000019
   1438,          -4.,           3.,    7.4000001
   1439,          -4.,           3.,          7.5
   1440,          -4.,           3.,    7.5999999
   1441,          -4.,           3.,   7.69999981
   1442,          -4.,           3.,   7.80000019
   1443,          -4.,           3.,    7.9000001
   1444,   -4.9000001,           3.,           8.
   1445,  -4.80000019,           3.,           8.
   1446,  -4.69999981,           3.,           8.
   1447,   -4.5999999,           3.,           8.
   1448,         -4.5,           3.,           8.
   1449,   -4.4000001,           3.,           8.
   1450,  -4.30000019,           3.,           8.
   1451,  -4.19999981,           3.,           8.
   1452,   -4.0999999,           3.,           8.
   1453,   -4.9000001,           3.,           7.
   1454,  -4.80000019,           3.,           7.
   1455,  -4.69999981,           3.,           7.
   1456,   -4.5999999,           3.,           7.
   1457,         -4.5,           3.,           7.
   1458,   -4.4000001,           3.,           7.
   1459,  -4.30000019,           3.,           7.
   1460,  -4.19999981,           3.,           7.
   1461,   -4.0999999,           3.,           7.
   1462,          -5.,    3.8840065,           7.
   1463,          -5.,   3.76914096,           7.
   1464,          -5.,   3.65751266,           7.
   1465,          -5.,    3.5459404,           7.
   1466,          -5.,   3.43482447,           7.
   1467,          -5.,   3.34511542,           7.
   1468,          -5.,   3.25648594,           7.
   1469,          -5.,   3.16876054,           7.
   1470,          -5.,   3.08330345,           7.
   1471,          -5.,           3.,    7.0999999
   1472,          -5.,           3.,   7.19999981
   1473,          -5.,           3.,   7.30000019
   1474,          -5.,           3.,    7.4000001
   1475,          -5.,           3.,          7.5
   1476,          -5.,           3.,    7.5999999
   1477,          -5.,           3.,   7.69999981
   1478,          -5.,           3.,   7.80000019
   1479,          -5.,           3.,    7.9000001
   1480,          -5.,    3.0999999,           8.
   1481,          -5.,   3.20000005,           8.
   1482,          -5.,   3.29999995,           8.
   1483,          -5.,    3.4000001,           8.
   1484,          -5.,          3.5,           8.
   1485,          -5.,    3.5999999,           8.
   1486,          -5.,   3.70000005,           8.
   1487,          -5.,   3.79999995,           8.
   1488,          -5.,    3.9000001,           8.
   1489,          -3.,    4.0999999,           8.
   1490,          -3.,   4.19999981,           8.
   1491,          -3.,   4.30000019,           8.
   1492,          -3.,    4.4000001,           8.
   1493,          -3.,          4.5,           8.
   1494,          -3.,    4.5999999,           8.
   1495,          -3.,   4.69999981,           8.
   1496,          -3.,   4.80000019,           8.
   1497,          -3.,    4.9000001,           8.
   1498,   -3.0999999,           5.,           8.
   1499,  -3.20000005,           5.,           8.
   1500,  -3.29999995,           5.,           8.
   1501,   -3.4000001,           5.,           8.
   1502,         -3.5,           5.,           8.
   1503,   -3.5999999,           5.,           8.
   1504,  -3.70000005,           5.,           8.
   1505,  -3.79999995,           5.,           8.
   1506,   -3.9000001,           5.,           8.
   1507,          -4.,           5.,   8.10000038
   1508,          -4.,           5.,   8.19999981
   1509,          -4.,           5.,   8.30000019
   1510,          -4.,           5.,   8.39999962
   1511,          -4.,           5.,          8.5
   1512,          -4.,           5.,   8.60000038
   1513,          -4.,           5.,   8.69999981
   1514,          -4.,           5.,   8.80000019
   1515,          -4.,           5.,   8.89999962
   1516,          -3.,           5.,   8.89999962
   1517,          -3.,           5.,   8.80000019
   1518,          -3.,           5.,   8.69999981
   1519,          -3.,           5.,   8.60000038
   1520,          -3.,           5.,          8.5
   1521,          -3.,           5.,   8.39999962
   1522,          -3.,           5.,   8.30000019
   1523,          -3.,           5.,   8.19999981
   1524,          -3.,           5.,   8.10000038
   1525,          -3.,    4.0999999,           9.
   1526,          -3.,   4.19999981,           9.
   1527,          -3.,   4.30000019,           9.
   1528,          -3.,    4.4000001,           9.
   1529,          -3.,          4.5,           9.
   1530,          -3.,    4.5999999,           9.
   1531,          -3.,   4.69999981,           9.
   1532,          -3.,   4.80000019,           9.
   1533,          -3.,    4.9000001,           9.
   1534,   -3.0999999,           5.,           9.
   1535,  -3.20000005,           5.,           9.
   1536,  -3.29999995,           5.,           9.
   1537,   -3.4000001,           5.,           9.
   1538,         -3.5,           5.,           9.
   1539,   -3.5999999,           5.,           9.
   1540,  -3.70000005,           5.,           9.
   1541,  -3.79999995,           5.,           9.
   1542,   -3.9000001,           5.,           9.
   1543,          -3.,           5.,   9.10000038
   1544,          -3.,           5.,   9.19999981
   1545,          -3.,           5.,   9.30000019
   1546,          -3.,           5.,   9.39999962
   1547,          -3.,           5.,          9.5
   1548,          -3.,           5.,   9.60000038
   1549,          -3.,           5.,   9.69999981
   1550,          -3.,           5.,   9.80000019
   1551,          -3.,           5.,   9.89999962
   1552,          -3.,    4.0999999,          10.
   1553,          -3.,   4.19999981,          10.
   1554,          -3.,   4.30000019,          10.
   1555,          -3.,    4.4000001,          10.
   1556,          -3.,          4.5,          10.
   1557,          -3.,    4.5999999,          10.
   1558,          -3.,   4.69999981,          10.
   1559,          -3.,   4.80000019,          10.
   1560,          -3.,    4.9000001,          10.
   1561,   -3.0999999,           5.,          10.
   1562,  -3.20000005,           5.,          10.
   1563,  -3.29999995,           5.,          10.
   1564,   -3.4000001,           5.,          10.
   1565,         -3.5,           5.,          10.
   1566,   -3.5999999,           5.,          10.
   1567,  -3.70000005,           5.,          10.
   1568,  -3.79999995,           5.,          10.
   1569,   -3.9000001,           5.,          10.
   1570,          -4.,   3.96481895,    5.0868988
   1571,          -4.,   3.93949938,   5.07161522
   1572,          -4.,   3.92113709,   5.05069208
   1573,          -4.,   3.91002607,   5.02633953
   1574,          -4.,    3.9398818,           5.
   1575,          -4.,   3.97054434,           5.
   1576,          -4.,   3.91084051,   5.97102308
   1577,          -4.,   3.92363501,   5.94561768
   1578,          -4.,   3.94225454,   5.92614508
   1579,          -4.,   3.96750474,   5.91206169
   1580,          -4.,   3.97064757,           6.
   1581,          -4.,   3.94001532,           6.
   1582,          -4.,   3.81929517,           5.
   1583,          -4.,   3.73164225,           5.
   1584,          -4.,   3.63476801,           5.
   1585,          -4.,   3.52953196,           5.
   1586,          -4.,   3.42410827,           5.
   1587,          -4.,   3.31741023,           5.
   1588,          -4.,   3.21118498,           5.
   1589,          -4.,   3.10547829,           5.
   1590,          -4.,           3.,    5.0886941
   1591,          -4.,           3.,   5.17727089
   1592,          -4.,           3.,   5.26599503
   1593,          -4.,           3.,   5.35519409
   1594,          -4.,           3.,   5.44515181
   1595,          -4.,           3.,   5.53601646
   1596,          -4.,           3.,   5.62777281
   1597,          -4.,           3.,   5.72026777
   1598,          -4.,           3.,    5.8132782
   1599,          -4.,           3.,   5.90658188
   1600,          -4.,   3.10562658,           6.
   1601,          -4.,   3.21124649,           6.
   1602,          -4.,   3.31674623,           6.
   1603,          -4.,   3.42113829,           6.
   1604,          -4.,   3.52481127,           6.
   1605,          -4.,   3.62686729,           6.
   1606,          -4.,   3.72508526,           6.
   1607,          -4.,   3.81535077,           6.
   1608,   -4.9000001,           3.,           5.
   1609,  -4.80000019,           3.,           5.
   1610,  -4.69999981,           3.,           5.
   1611,   -4.5999999,           3.,           5.
   1612,         -4.5,           3.,           5.
   1613,   -4.4000001,           3.,           5.
   1614,  -4.30000019,           3.,           5.
   1615,  -4.19999981,           3.,           5.
   1616,   -4.0999999,           3.,           5.
   1617,   -4.0999999,           3.,           6.
   1618,  -4.19999981,           3.,           6.
   1619,  -4.30000019,           3.,           6.
   1620,   -4.4000001,           3.,           6.
   1621,         -4.5,           3.,           6.
   1622,   -4.5999999,           3.,           6.
   1623,  -4.69999981,           3.,           6.
   1624,  -4.80000019,           3.,           6.
   1625,   -4.9000001,           3.,           6.
   1626,          -5.,   3.97054434,           5.
   1627,          -5.,    3.9398818,           5.
   1628,          -5.,      3.90625,           5.
   1629,          -5.,   3.81951571,           5.
   1630,          -5.,   3.73181105,           5.
   1631,          -5.,   3.63486767,           5.
   1632,          -5.,   3.52957916,           5.
   1633,          -5.,   3.42412901,           5.
   1634,          -5.,   3.31741667,           5.
   1635,          -5.,   3.21118784,           5.
   1636,          -5.,   3.10547924,           5.
   1637,          -5.,           3.,    5.0886941
   1638,          -5.,           3.,   5.17727089
   1639,          -5.,           3.,   5.26599503
   1640,          -5.,           3.,   5.35519409
   1641,          -5.,           3.,   5.44515181
   1642,          -5.,           3.,   5.53601646
   1643,          -5.,           3.,   5.62777281
   1644,          -5.,           3.,   5.72026777
   1645,          -5.,           3.,    5.8132782
   1646,          -5.,           3.,   5.90658188
   1647,          -5.,   3.10562849,           6.
   1648,          -5.,   3.21125269,           6.
   1649,          -5.,   3.31676435,           6.
   1650,          -5.,   3.42118359,           6.
   1651,          -5.,   3.52488613,           6.
   1652,          -5.,     3.626966,           6.
   1653,          -5.,   3.72520924,           6.
   1654,          -5.,   3.81552362,           6.
   1655,          -5.,      3.90625,           6.
   1656,          -5.,   3.94001532,           6.
   1657,          -5.,   3.97064757,           6.
   1658,          -4.,   3.96867156,   6.08836079
   1659,          -4.,   3.94270253,   6.07420254
   1660,          -4.,   3.92384148,   6.05467129
   1661,          -4.,   3.91112828,   6.02984762
   1662,          -4.,           3.,   6.10019732
   1663,          -4.,           3.,   6.20036554
   1664,          -4.,           3.,   6.30051804
   1665,          -4.,           3.,   6.40066576
   1666,          -4.,           3.,   6.50082064
   1667,          -4.,           3.,   6.60091782
   1668,          -4.,           3.,   6.70087814
   1669,          -4.,           3.,   6.80067635
   1670,          -4.,           3.,   6.90035486
   1671,          -5.,           3.,   6.10019732
   1672,          -5.,           3.,   6.20036554
   1673,          -5.,           3.,   6.30051804
   1674,          -5.,           3.,   6.40066576
   1675,          -5.,           3.,   6.50082064
   1676,          -5.,           3.,   6.60091782
   1677,          -5.,           3.,   6.70087814
   1678,          -5.,           3.,   6.80067635
   1679,          -5.,           3.,   6.90035486
   1680,          -4.,   3.97034812,   3.08893728
   1681,          -4.,   3.94581628,   3.07650614
   1682,          -4.,   3.92866135,    3.0608263
   1683,          -4.,   3.91675282,   3.04311562
   1684,          -4.,   3.90896153,   3.02238417
   1685,          -4.,   3.93129778,           3.
   1686,          -4.,   3.95467234,           3.
   1687,          -4.,   3.97741652,           3.
   1688,          -4.,   3.90975738,   3.97459674
   1689,          -4.,   3.91953182,   3.95189667
   1690,          -4.,   3.93631768,   3.93119884
   1691,          -4.,   3.96405101,   3.91341639
   1692,          -4.,   3.97686911,           4.
   1693,          -4.,   3.95404577,           4.
   1694,          -4.,   3.93089151,           4.
   1695,          -4.,   3.78108788,           3.
   1696,          -4.,   3.66502118,           3.
   1697,          -4.,   3.55277109,           3.
   1698,          -4.,   3.45682383,           3.
   1699,          -4.,   3.36381721,           3.
   1700,          -4.,   3.27164388,           3.
   1701,          -4.,   3.18081617,           3.
   1702,          -4.,   3.09030938,           3.
   1703,          -4.,           3.,    3.0999434
   1704,          -4.,           3.,   3.19985843
   1705,          -4.,           3.,   3.29978251
   1706,          -4.,           3.,   3.39974976
   1707,          -4.,           3.,    3.4997704
   1708,          -4.,           3.,   3.59983516
   1709,          -4.,           3.,   3.69992089
   1710,          -4.,           3.,   3.79999256
   1711,          -4.,           3.,    3.9000175
   1712,          -4.,   3.09019852,           4.
   1713,          -4.,   3.18487191,           4.
   1714,          -4.,   3.28274465,           4.
   1715,          -4.,   3.38211036,           4.
   1716,          -4.,   3.48366141,           4.
   1717,          -4.,   3.58450222,           4.
   1718,          -4.,   3.68583798,           4.
   1719,          -4.,   3.78543949,           4.
   1720,   -4.9000001,           3.,           3.
   1721,  -4.80000019,           3.,           3.
   1722,  -4.69999981,           3.,           3.
   1723,   -4.5999999,           3.,           3.
   1724,         -4.5,           3.,           3.
   1725,   -4.4000001,           3.,           3.
   1726,  -4.30000019,           3.,           3.
   1727,  -4.19999981,           3.,           3.
   1728,   -4.0999999,           3.,           3.
   1729,   -4.0999999,           3.,           4.
   1730,  -4.19999981,           3.,           4.
   1731,  -4.30000019,           3.,           4.
   1732,   -4.4000001,           3.,           4.
   1733,         -4.5,           3.,           4.
   1734,   -4.5999999,           3.,           4.
   1735,  -4.69999981,           3.,           4.
   1736,  -4.80000019,           3.,           4.
   1737,   -4.9000001,           3.,           4.
   1738,          -5.,   3.97741652,           3.
   1739,          -5.,   3.95467234,           3.
   1740,          -5.,   3.93129778,           3.
   1741,          -5.,      3.90625,           3.
   1742,          -5.,   3.78134108,           3.
   1743,          -5.,   3.66547441,           3.
   1744,          -5.,   3.55760384,           3.
   1745,          -5.,   3.45853996,           3.
   1746,          -5.,   3.36421466,           3.
   1747,          -5.,   3.27164555,           3.
   1748,          -5.,   3.18081641,           3.
   1749,          -5.,   3.09030938,           3.
   1750,          -5.,           3.,    3.0999434
   1751,          -5.,           3.,   3.19985843
   1752,          -5.,           3.,   3.29978251
   1753,          -5.,           3.,   3.39974976
   1754,          -5.,           3.,    3.4997704
   1755,          -5.,           3.,   3.59983516
   1756,          -5.,           3.,   3.69992089
   1757,          -5.,           3.,   3.79999256
   1758,          -5.,           3.,    3.9000175
   1759,          -5.,   3.09021187,           4.
   1760,          -5.,   3.18489933,           4.
   1761,          -5.,    3.2827158,           4.
   1762,          -5.,   3.38240004,           4.
   1763,          -5.,   3.48376179,           4.
   1764,          -5.,   3.58465958,           4.
   1765,          -5.,    3.6860981,           4.
   1766,          -5.,   3.78537726,           4.
   1767,          -5.,      3.90625,           4.
   1768,          -5.,   3.93089151,           4.
   1769,          -5.,   3.95404577,           4.
   1770,          -5.,   3.97686911,           4.
   1771,          -4.,   3.96750712,   4.08793879
   1772,          -4.,   3.94317627,   4.07456636
   1773,          -4.,   3.92644477,   4.05812645
   1774,          -4.,   3.91502261,   4.03959703
   1775,          -4.,   3.90840173,   4.01997042
   1776,          -4.,   3.91094065,   4.97071695
   1777,          -4.,   3.92394471,   4.94518518
   1778,          -4.,   3.94357109,   4.92513466
   1779,          -4.,   3.96947551,   4.91135836
   1780,          -4.,           3.,   4.09499598
   1781,          -4.,           3.,    4.1900835
   1782,          -4.,           3.,   4.28482628
   1783,          -4.,           3.,   4.38094521
   1784,          -4.,           3.,   4.47874117
   1785,          -4.,           3.,   4.57897043
   1786,          -4.,           3.,   4.68156242
   1787,          -4.,           3.,      4.78652
   1788,          -4.,           3.,   4.89298439
   1789,          -5.,           3.,   4.09499598
   1790,          -5.,           3.,   4.19008398
   1791,          -5.,           3.,   4.28482676
   1792,          -5.,           3.,   4.38094568
   1793,          -5.,           3.,   4.47874117
   1794,          -5.,           3.,   4.57897043
   1795,          -5.,           3.,   4.68156242
   1796,          -5.,           3.,      4.78652
   1797,          -5.,           3.,   4.89298439
   1798,          -4.,   3.97213221,   1.08951223
   1799,          -4.,   3.94661903,   1.07706833
   1800,          -4.,   3.92643666,    1.0581162
   1801,          -4.,   3.91194606,   1.03217995
   1802,          -4.,   3.94016409,           1.
   1803,          -4.,   3.97079134,           1.
   1804,          -4.,   3.91001272,   1.97370648
   1805,          -4.,   3.92023587,   1.95073807
   1806,          -4.,   3.93432069,   1.93310237
   1807,          -4.,   3.95201826,    1.9194591
   1808,          -4.,   3.97455835,   1.90976822
   1809,          -4.,   3.97777486,           2.
   1810,          -4.,    3.9553175,           2.
   1811,          -4.,   3.93193722,           2.
   1812,          -4.,   3.81436729,           1.
   1813,          -4.,   3.72329807,           1.
   1814,          -4.,   3.62707186,           1.
   1815,          -4.,    3.5246408,           1.
   1816,          -4.,   3.42100143,           1.
   1817,          -4.,   3.31677175,           1.
   1818,          -4.,    3.2112956,           1.
   1819,          -4.,    3.1056757,           1.
   1820,          -4.,           3.,   1.09999514
   1821,          -4.,           3.,   1.19999695
   1822,          -4.,           3.,   1.30002201
   1823,          -4.,           3.,   1.40008533
   1824,          -4.,           3.,   1.50019538
   1825,          -4.,           3.,   1.60034204
   1826,          -4.,           3.,   1.70046973
   1827,          -4.,           3.,   1.80049062
   1828,          -4.,           3.,   1.90033484
   1829,          -4.,   3.10531712,           2.
   1830,          -4.,   3.21064067,           2.
   1831,          -4.,   3.31595707,           2.
   1832,          -4.,   3.42084217,           2.
   1833,          -4.,   3.52521944,           2.
   1834,          -4.,   3.62715435,           2.
   1835,          -4.,   3.72361517,           2.
   1836,          -4.,   3.81376123,           2.
   1837,   -4.9000001,           3.,           1.
   1838,  -4.80000019,           3.,           1.
   1839,  -4.69999981,           3.,           1.
   1840,   -4.5999999,           3.,           1.
   1841,         -4.5,           3.,           1.
   1842,   -4.4000001,           3.,           1.
   1843,  -4.30000019,           3.,           1.
   1844,  -4.19999981,           3.,           1.
   1845,   -4.0999999,           3.,           1.
   1846,   -4.0999999,           3.,           2.
   1847,  -4.19999981,           3.,           2.
   1848,  -4.30000019,           3.,           2.
   1849,   -4.4000001,           3.,           2.
   1850,         -4.5,           3.,           2.
   1851,   -4.5999999,           3.,           2.
   1852,  -4.69999981,           3.,           2.
   1853,  -4.80000019,           3.,           2.
   1854,   -4.9000001,           3.,           2.
   1855,          -5.,   3.97079134,           1.
   1856,          -5.,   3.94016409,           1.
   1857,          -5.,      3.90625,           1.
   1858,          -5.,   3.81451988,           1.
   1859,          -5.,   3.72338486,           1.
   1860,          -5.,   3.62712646,           1.
   1861,          -5.,    3.5246706,           1.
   1862,          -5.,   3.42101288,           1.
   1863,          -5.,   3.31677389,           1.
   1864,          -5.,   3.21129656,           1.
   1865,          -5.,   3.10567617,           1.
   1866,          -5.,           3.,   1.09999514
   1867,          -5.,           3.,   1.19999695
   1868,          -5.,           3.,   1.30002201
   1869,          -5.,           3.,   1.40008533
   1870,          -5.,           3.,   1.50019538
   1871,          -5.,           3.,    1.6003418
   1872,          -5.,           3.,   1.70046949
   1873,          -5.,           3.,    1.8004905
   1874,          -5.,           3.,   1.90033484
   1875,          -5.,   3.10531735,           2.
   1876,          -5.,   3.21064115,           2.
   1877,          -5.,   3.31595564,           2.
   1878,          -5.,   3.42084217,           2.
   1879,          -5.,    3.5252223,           2.
   1880,          -5.,   3.62716579,           2.
   1881,          -5.,   3.72364426,           2.
   1882,          -5.,   3.81380844,           2.
   1883,          -5.,      3.90625,           2.
   1884,          -5.,   3.93193722,           2.
   1885,          -5.,    3.9553175,           2.
   1886,          -5.,   3.97777486,           2.
   1887,          -4.,   3.97634768,   2.09071732
   1888,          -4.,   3.95461416,   2.08203149
   1889,          -4.,    3.9360826,   2.06858301
   1890,          -4.,   3.92100668,   2.05048871
   1891,          -4.,   3.91029358,   2.02723598
   1892,          -4.,   3.90837336,      2.98016
   1893,          -4.,   3.91499662,   2.96045923
   1894,          -4.,   3.92760825,   2.94043088
   1895,          -4.,   3.94454288,   2.92441201
   1896,          -4.,   3.96986961,   2.91122365
   1897,          -4.,           3.,   2.10620093
   1898,          -4.,           3.,   2.21112633
   1899,          -4.,           3.,   2.31268859
   1900,          -4.,           3.,   2.41643453
   1901,          -4.,           3.,   2.51830912
   1902,          -4.,           3.,   2.61946201
   1903,          -4.,           3.,    2.7166338
   1904,          -4.,           3.,   2.81151199
   1905,          -4.,           3.,   2.90599561
   1906,          -5.,           3.,   2.10620093
   1907,          -5.,           3.,   2.21112704
   1908,          -5.,           3.,   2.31268859
   1909,          -5.,           3.,   2.41643453
   1910,          -5.,           3.,   2.51830864
   1911,          -5.,           3.,   2.61946034
   1912,          -5.,           3.,   2.71663284
   1913,          -5.,           3.,   2.81151175
   1914,          -5.,           3.,   2.90599561
   1915,          -4.,   3.91024065,   0.97293818
   1916,          -4.,   3.92238212,  0.947421193
   1917,          -4.,    3.9429543,   0.92560339
   1918,          -4.,   3.97067547,  0.910954356
   1919,          -4.,    3.8998363,           0.
   1920,          -4.,   3.79968762,           0.
   1921,          -4.,   3.69952655,           0.
   1922,          -4.,   3.59935474,           0.
   1923,          -4.,   3.49921203,           0.
   1924,          -4.,   3.39915442,           0.
   1925,          -4.,   3.29921746,           0.
   1926,          -4.,   3.19940972,           0.
   1927,          -4.,   3.09969497,           0.
   1928,          -4.,           3., 0.0860559121
   1929,          -4.,           3.,  0.174222842
   1930,          -4.,           3.,  0.261382103
   1931,          -4.,           3.,  0.352575421
   1932,          -4.,           3.,  0.443843186
   1933,          -4.,           3.,  0.535930753
   1934,          -4.,           3.,  0.626983583
   1935,          -4.,           3.,  0.718291759
   1936,          -4.,           3.,  0.812114835
   1937,          -4.,           3.,  0.906092048
   1938,   -4.0999999,           3.,           0.
   1939,  -4.19999981,           3.,           0.
   1940,  -4.30000019,           3.,           0.
   1941,   -4.4000001,           3.,           0.
   1942,         -4.5,           3.,           0.
   1943,   -4.5999999,           3.,           0.
   1944,  -4.69999981,           3.,           0.
   1945,  -4.80000019,           3.,           0.
   1946,   -4.9000001,           3.,           0.
   1947,          -5.,    3.8998363,           0.
   1948,          -5.,   3.79968762,           0.
   1949,          -5.,   3.69952655,           0.
   1950,          -5.,   3.59935474,           0.
   1951,          -5.,   3.49921203,           0.
   1952,          -5.,   3.39915442,           0.
   1953,          -5.,   3.29921746,           0.
   1954,          -5.,   3.19940972,           0.
   1955,          -5.,   3.09969497,           0.
   1956,          -5.,           3., 0.0860559121
   1957,          -5.,           3.,  0.174222842
   1958,          -5.,           3.,  0.261382103
   1959,          -5.,           3.,  0.352575421
   1960,          -5.,           3.,  0.443843126
   1961,          -5.,           3.,  0.535930574
   1962,          -5.,           3.,  0.626983404
   1963,          -5.,           3.,  0.718291759
   1964,          -5.,           3.,  0.812114716
   1965,          -5.,           3.,  0.906091988
   1966,   -3.0999999,           3.,           0.
   1967,  -3.20000005,           3.,           0.
   1968,  -3.29999995,           3.,           0.
   1969,   -3.4000001,           3.,           0.
   1970,         -3.5,           3.,           0.
   1971,   -3.5999999,           3.,           0.
   1972,  -3.70000005,           3.,           0.
   1973,  -3.79999995,           3.,           0.
   1974,   -3.9000001,           3.,           0.
   1975,   -3.0999999,           3.,           1.
   1976,  -3.20000005,           3.,           1.
   1977,  -3.29999995,           3.,           1.
   1978,   -3.4000001,           3.,           1.
   1979,         -3.5,           3.,           1.
   1980,   -3.5999999,           3.,           1.
   1981,  -3.70000005,           3.,           1.
   1982,  -3.79999995,           3.,           1.
   1983,   -3.9000001,           3.,           1.
   1984,   -3.0999999,      3.90625,           1.
   1985,  -3.20000005,      3.90625,           1.
   1986,  -3.29999995,      3.90625,           1.
   1987,   -3.4000001,      3.90625,           1.
   1988,         -3.5,      3.90625,           1.
   1989,   -3.5999999,      3.90625,           1.
   1990,  -3.70000005,      3.90625,           1.
   1991,  -3.79999995,      3.90625,           1.
   1992,   -3.9000001,      3.90625,           1.
   1993,          -3.,   3.97049046,  0.911015451
   1994,          -3.,   3.94230318,  0.926107168
   1995,          -3.,   3.92130733,  0.949043691
   1996,          -3.,   3.90985823,  0.974240839
   1997,          -3.,   3.81421471,           1.
   1998,          -3.,   3.72321129,           1.
   1999,          -3.,   3.62701726,           1.
   2000,          -3.,   3.52461147,           1.
   2001,          -3.,   3.42098999,           1.
   2002,          -3.,   3.31676936,           1.
   2003,          -3.,   3.21129489,           1.
   2004,          -3.,   3.10567522,           1.
   2005,          -3.,           3.,  0.906092107
   2006,          -3.,           3.,  0.812114894
   2007,          -3.,           3.,  0.718291759
   2008,          -3.,           3.,  0.626983762
   2009,          -3.,           3.,  0.535930932
   2010,          -3.,           3.,  0.443843216
   2011,          -3.,           3.,  0.352575421
   2012,          -3.,           3.,  0.261382103
   2013,          -3.,           3.,  0.174222842
   2014,          -3.,           3., 0.0860559121
   2015,          -3.,   3.09969497,           0.
   2016,          -3.,   3.19940972,           0.
   2017,          -3.,   3.29921746,           0.
   2018,          -3.,   3.39915442,           0.
   2019,          -3.,   3.49921203,           0.
   2020,          -3.,   3.59935474,           0.
   2021,          -3.,   3.69952655,           0.
   2022,          -3.,   3.79968762,           0.
   2023,          -3.,    3.8998363,           0.
   2024,   -3.0999999,      3.90625,           2.
   2025,  -3.20000005,      3.90625,           2.
   2026,  -3.29999995,      3.90625,           2.
   2027,   -3.4000001,      3.90625,           2.
   2028,         -3.5,      3.90625,           2.
   2029,   -3.5999999,      3.90625,           2.
   2030,  -3.70000005,      3.90625,           2.
   2031,  -3.79999995,      3.90625,           2.
   2032,   -3.9000001,      3.90625,           2.
   2033,   -3.9000001,           3.,           2.
   2034,  -3.79999995,           3.,           2.
   2035,  -3.70000005,           3.,           2.
   2036,   -3.5999999,           3.,           2.
   2037,         -3.5,           3.,           2.
   2038,   -3.4000001,           3.,           2.
   2039,  -3.29999995,           3.,           2.
   2040,  -3.20000005,           3.,           2.
   2041,   -3.0999999,           3.,           2.
   2042,   -3.0999999,           3.,           3.
   2043,  -3.20000005,           3.,           3.
   2044,  -3.29999995,           3.,           3.
   2045,   -3.4000001,           3.,           3.
   2046,         -3.5,           3.,           3.
   2047,   -3.5999999,           3.,           3.
   2048,  -3.70000005,           3.,           3.
   2049,  -3.79999995,           3.,           3.
   2050,   -3.9000001,           3.,           3.
   2051,   -3.0999999,      3.90625,           3.
   2052,  -3.20000005,      3.90625,           3.
   2053,  -3.29999995,      3.90625,           3.
   2054,   -3.4000001,      3.90625,           3.
   2055,         -3.5,      3.90625,           3.
   2056,   -3.5999999,      3.90625,           3.
   2057,  -3.70000005,      3.90625,           3.
   2058,  -3.79999995,      3.90625,           3.
   2059,   -3.9000001,      3.90625,           3.
   2060,          -3.,     3.969841,   2.91123343
   2061,          -3.,    3.9438808,   2.92490196
   2062,          -3.,   3.92547679,   2.94311976
   2063,          -3.,   3.91416931,   2.96228838
   2064,          -3.,   3.90815234,   2.98120952
   2065,          -3.,   3.78083491,           3.
   2066,          -3.,   3.66456819,           3.
   2067,          -3.,   3.54793859,           3.
   2068,          -3.,   3.45510769,           3.
   2069,          -3.,   3.36341977,           3.
   2070,          -3.,   3.27164221,           3.
   2071,          -3.,    3.1808157,           3.
   2072,          -3.,   3.09030914,           3.
   2073,          -3.,           3.,   2.90599561
   2074,          -3.,           3.,   2.81151199
   2075,          -3.,           3.,   2.71663499
   2076,          -3.,           3.,   2.61946392
   2077,          -3.,           3.,   2.51830935
   2078,          -3.,           3.,   2.41643453
   2079,          -3.,           3.,   2.31268859
   2080,          -3.,           3.,   2.21112561
   2081,          -3.,           3.,   2.10620093
   2082,          -3.,   3.10531712,           2.
   2083,          -3.,   3.21064043,           2.
   2084,          -3.,    3.3159585,           2.
   2085,          -3.,   3.42084241,           2.
   2086,          -3.,   3.52521658,           2.
   2087,          -3.,   3.62714291,           2.
   2088,          -3.,   3.72358608,           2.
   2089,          -3.,   3.81371403,           2.
   2090,          -3.,   3.91016793,   2.02681899
   2091,          -3.,   3.92082787,   2.05020785
   2092,          -3.,   3.93647194,   2.06894398
   2093,          -3.,   3.95572352,   2.08263564
   2094,          -3.,   3.97727108,   2.09095311
   2095,          -3.,   3.91159582,   1.03120494
   2096,          -3.,   3.92559218,   1.05703092
   2097,          -3.,   3.94612551,   1.07672417
   2098,          -3.,    3.9722631,     1.089553
   2099,          -3.,   3.97515321,   1.90960252
   2100,          -3.,   3.95262456,   1.91910112
   2101,          -3.,   3.93435884,   1.93306494
   2102,          -3.,   3.91991448,   1.95126224
   2103,          -3.,   3.90985727,   1.97424436
   2104,          -3.,           3.,   1.90033495
   2105,          -3.,           3.,   1.80049086
   2106,          -3.,           3.,   1.70046985
   2107,          -3.,           3.,   1.60034215
   2108,          -3.,           3.,   1.50019538
   2109,          -3.,           3.,   1.40008533
   2110,          -3.,           3.,   1.30002201
   2111,          -3.,           3.,   1.19999695
   2112,          -3.,           3.,   1.09999502
   2113,   -3.0999999,           4.,      4.90625
   2114,  -3.20000005,           4.,      4.90625
   2115,  -3.29999995,           4.,      4.90625
   2116,   -3.4000001,           4.,      4.90625
   2117,         -3.5,           4.,      4.90625
   2118,   -3.5999999,           4.,      4.90625
   2119,  -3.70000005,           4.,      4.90625
   2120,  -3.79999995,           4.,      4.90625
   2121,   -3.9000001,           4.,      4.90625
   2122,   -3.9000001,           4.,      4.09375
   2123,  -3.79999995,           4.,      4.09375
   2124,  -3.70000005,           4.,      4.09375
   2125,   -3.5999999,           4.,      4.09375
   2126,         -3.5,           4.,      4.09375
   2127,   -3.4000001,           4.,      4.09375
   2128,  -3.29999995,           4.,      4.09375
   2129,  -3.20000005,           4.,      4.09375
   2130,   -3.0999999,           4.,      4.09375
   2131,   -3.0999999,      3.90625,           4.
   2132,  -3.20000005,      3.90625,           4.
   2133,  -3.29999995,      3.90625,           4.
   2134,   -3.4000001,      3.90625,           4.
   2135,         -3.5,      3.90625,           4.
   2136,   -3.5999999,      3.90625,           4.
   2137,  -3.70000005,      3.90625,           4.
   2138,  -3.79999995,      3.90625,           4.
   2139,   -3.9000001,      3.90625,           4.
   2140,   -3.9000001,           3.,           4.
   2141,  -3.79999995,           3.,           4.
   2142,  -3.70000005,           3.,           4.
   2143,   -3.5999999,           3.,           4.
   2144,         -3.5,           3.,           4.
   2145,   -3.4000001,           3.,           4.
   2146,  -3.29999995,           3.,           4.
   2147,  -3.20000005,           3.,           4.
   2148,   -3.0999999,           3.,           4.
   2149,   -3.0999999,           3.,           5.
   2150,  -3.20000005,           3.,           5.
   2151,  -3.29999995,           3.,           5.
   2152,   -3.4000001,           3.,           5.
   2153,         -3.5,           3.,           5.
   2154,   -3.5999999,           3.,           5.
   2155,  -3.70000005,           3.,           5.
   2156,  -3.79999995,           3.,           5.
   2157,   -3.9000001,           3.,           5.
   2158,   -3.0999999,      3.90625,           5.
   2159,  -3.20000005,      3.90625,           5.
   2160,  -3.29999995,      3.90625,           5.
   2161,   -3.4000001,      3.90625,           5.
   2162,         -3.5,      3.90625,           5.
   2163,   -3.5999999,      3.90625,           5.
   2164,  -3.70000005,      3.90625,           5.
   2165,  -3.79999995,      3.90625,           5.
   2166,   -3.9000001,      3.90625,           5.
   2167,          -3.,   3.96955967,   4.91132975
   2168,          -3.,   3.94301033,   4.92556047
   2169,          -3.,    3.9230454,     4.946455
   2170,          -3.,   3.91057897,   4.97184038
   2171,          -3.,   3.81907487,           5.
   2172,          -3.,   3.73147297,           5.
   2173,          -3.,   3.63466835,           5.
   2174,          -3.,   3.52948523,           5.
   2175,          -3.,   3.42408752,           5.
   2176,          -3.,   3.31740379,           5.
   2177,          -3.,   3.21118212,           5.
   2178,          -3.,   3.10547709,           5.
   2179,          -3.,           3.,   4.89298439
   2180,          -3.,           3.,   4.78652048
   2181,          -3.,           3.,    4.6815629
   2182,          -3.,           3.,   4.57897043
   2183,          -3.,           3.,   4.47874117
   2184,          -3.,           3.,   4.38094521
   2185,          -3.,           3.,    4.2848258
   2186,          -3.,           3.,   4.19008303
   2187,          -3.,           3.,   4.09499598
   2188,          -3.,    3.0901854,           4.
   2189,          -3.,   3.18484449,           4.
   2190,          -3.,   3.28277326,           4.
   2191,          -3.,   3.38182044,           4.
   2192,          -3.,   3.48356104,           4.
   2193,          -3.,    3.5843451,           4.
   2194,          -3.,   3.68557787,           4.
   2195,          -3.,   3.78550148,           4.
   2196,          -3.,    3.9081862,   4.01895523
   2197,          -3.,    3.9143486,   4.03811693
   2198,          -3.,   3.92563224,   4.05708313
   2199,          -3.,   3.94268894,   4.07419252
   2200,          -3.,   3.96740127,   4.08789968
   2201,          -3.,           4.,   4.18766403
   2202,          -3.,           4.,   4.27864647
   2203,          -3.,           4.,   4.37488174
   2204,          -3.,           4.,   4.47031879
   2205,          -3.,           4.,     4.566679
   2206,          -3.,           4.,   4.66076136
   2207,          -3.,           4.,   4.74908829
   2208,          -3.,           4.,   4.82800007
   2209,   -3.0999999,           4.,      3.90625
   2210,  -3.20000005,           4.,      3.90625
   2211,  -3.29999995,           4.,      3.90625
   2212,   -3.4000001,           4.,      3.90625
   2213,         -3.5,           4.,      3.90625
   2214,   -3.5999999,           4.,      3.90625
   2215,  -3.70000005,           4.,      3.90625
   2216,  -3.79999995,           4.,      3.90625
   2217,   -3.9000001,           4.,      3.90625
   2218,   -3.9000001,           4.,      3.09375
   2219,  -3.79999995,           4.,      3.09375
   2220,  -3.70000005,           4.,      3.09375
   2221,   -3.5999999,           4.,      3.09375
   2222,         -3.5,           4.,      3.09375
   2223,   -3.4000001,           4.,      3.09375
   2224,  -3.29999995,           4.,      3.09375
   2225,  -3.20000005,           4.,      3.09375
   2226,   -3.0999999,           4.,      3.09375
   2227,          -3.,   3.90881991,   3.02180004
   2228,          -3.,   3.91642404,   3.04247475
   2229,          -3.,   3.92852378,   3.06066465
   2230,          -3.,   3.94621468,   3.07678676
   2231,          -3.,   3.97075939,   3.08907318
   2232,          -3.,           4.,   3.19058275
   2233,          -3.,           4.,   3.28633595
   2234,          -3.,           4.,   3.38819718
   2235,          -3.,           4.,   3.48907614
   2236,          -3.,           4.,   3.58711147
   2237,          -3.,           4.,    3.6789465
   2238,          -3.,           4.,   3.76128292
   2239,          -3.,           4.,   3.83501577
   2240,          -3.,   3.96479249,   3.91311216
   2241,          -3.,   3.93699026,   3.93058205
   2242,          -3.,   3.91939807,   3.95212078
   2243,          -3.,   3.90963912,   3.97502065
   2244,          -3.,           3.,    3.9000175
   2245,          -3.,           3.,   3.79999256
   2246,          -3.,           3.,   3.69992089
   2247,          -3.,           3.,   3.59983516
   2248,          -3.,           3.,    3.4997704
   2249,          -3.,           3.,   3.39974976
   2250,          -3.,           3.,   3.29978251
   2251,          -3.,           3.,   3.19985843
   2252,          -3.,           3.,    3.0999434
   2253,   -3.0999999,      3.90625,           6.
   2254,  -3.20000005,      3.90625,           6.
   2255,  -3.29999995,      3.90625,           6.
   2256,   -3.4000001,      3.90625,           6.
   2257,         -3.5,      3.90625,           6.
   2258,   -3.5999999,      3.90625,           6.
   2259,  -3.70000005,      3.90625,           6.
   2260,  -3.79999995,      3.90625,           6.
   2261,   -3.9000001,      3.90625,           6.
   2262,   -3.9000001,           3.,           6.
   2263,  -3.79999995,           3.,           6.
   2264,  -3.70000005,           3.,           6.
   2265,   -3.5999999,           3.,           6.
   2266,         -3.5,           3.,           6.
   2267,   -3.4000001,           3.,           6.
   2268,  -3.29999995,           3.,           6.
   2269,  -3.20000005,           3.,           6.
   2270,   -3.0999999,           3.,           6.
   2271,   -3.0999999,           3.,           7.
   2272,  -3.20000005,           3.,           7.
   2273,  -3.29999995,           3.,           7.
   2274,   -3.4000001,           3.,           7.
   2275,         -3.5,           3.,           7.
   2276,   -3.5999999,           3.,           7.
   2277,  -3.70000005,           3.,           7.
   2278,  -3.79999995,           3.,           7.
   2279,   -3.9000001,           3.,           7.
   2280,   -3.0999999,           4.,           7.
   2281,  -3.20000005,           4.,           7.
   2282,  -3.29999995,           4.,           7.
   2283,   -3.4000001,           4.,           7.
   2284,         -3.5,           4.,           7.
   2285,   -3.5999999,           4.,           7.
   2286,  -3.70000005,           4.,           7.
   2287,  -3.79999995,           4.,           7.
   2288,   -3.9000001,           4.,           7.
   2289,   -3.9000001,           4.,      6.09375
   2290,  -3.79999995,           4.,      6.09375
   2291,  -3.70000005,           4.,      6.09375
   2292,   -3.5999999,           4.,      6.09375
   2293,         -3.5,           4.,      6.09375
   2294,   -3.4000001,           4.,      6.09375
   2295,  -3.29999995,           4.,      6.09375
   2296,  -3.20000005,           4.,      6.09375
   2297,   -3.0999999,           4.,      6.09375
   2298,          -3.,   3.91078663,   6.02881002
   2299,          -3.,    3.9229815,   6.05345297
   2300,          -3.,   3.94208288,   6.07371998
   2301,          -3.,   3.96867704,   6.08836269
   2302,          -3.,           4.,   6.16481876
   2303,          -3.,           4.,   6.23750305
   2304,          -3.,           4.,    6.3198061
   2305,          -3.,           4.,   6.40749645
   2306,          -3.,           4.,   6.49950886
   2307,          -3.,           4.,   6.59444332
   2308,          -3.,           4.,   6.69097662
   2309,          -3.,           4.,   6.79143906
   2310,          -3.,           4.,   6.89545441
   2311,          -3.,    3.8840065,           7.
   2312,          -3.,   3.76914096,           7.
   2313,          -3.,   3.65751266,           7.
   2314,          -3.,    3.5459404,           7.
   2315,          -3.,   3.43482423,           7.
   2316,          -3.,   3.34511518,           7.
   2317,          -3.,    3.2564857,           7.
   2318,          -3.,   3.16876054,           7.
   2319,          -3.,   3.08330345,           7.
   2320,          -3.,           3.,   6.90035486
   2321,          -3.,           3.,   6.80067635
   2322,          -3.,           3.,   6.70087814
   2323,          -3.,           3.,   6.60091782
   2324,          -3.,           3.,   6.50082064
   2325,          -3.,           3.,   6.40066576
   2326,          -3.,           3.,   6.30051804
   2327,          -3.,           3.,   6.20036554
   2328,          -3.,           3.,   6.10019732
   2329,          -3.,   3.10562444,           6.
   2330,          -3.,   3.21124029,           6.
   2331,          -3.,   3.31672812,           6.
   2332,          -3.,   3.42109299,           6.
   2333,          -3.,    3.5247364,           6.
   2334,          -3.,   3.62676859,           6.
   2335,          -3.,   3.72496128,           6.
   2336,          -3.,   3.81517792,           6.
   2337,   -3.0999999,           4.,      5.90625
   2338,  -3.20000005,           4.,      5.90625
   2339,  -3.29999995,           4.,      5.90625
   2340,   -3.4000001,           4.,      5.90625
   2341,         -3.5,           4.,      5.90625
   2342,   -3.5999999,           4.,      5.90625
   2343,  -3.70000005,           4.,      5.90625
   2344,  -3.79999995,           4.,      5.90625
   2345,   -3.9000001,           4.,      5.90625
   2346,   -3.9000001,           4.,      5.09375
   2347,  -3.79999995,           4.,      5.09375
   2348,  -3.70000005,           4.,      5.09375
   2349,   -3.5999999,           4.,      5.09375
   2350,         -3.5,           4.,      5.09375
   2351,   -3.4000001,           4.,      5.09375
   2352,  -3.29999995,           4.,      5.09375
   2353,  -3.20000005,           4.,      5.09375
   2354,   -3.0999999,           4.,      5.09375
   2355,          -3.,   3.90961719,   5.02489996
   2356,          -3.,   3.91993284,   5.04876804
   2357,          -3.,   3.93751884,   5.06989384
   2358,          -3.,   3.96421003,   5.08664942
   2359,          -3.,           4.,   5.17427444
   2360,          -3.,           4.,   5.25597572
   2361,          -3.,           4.,   5.34605312
   2362,          -3.,           4.,   5.44004345
   2363,          -3.,           4.,     5.536273
   2364,          -3.,           4.,   5.63147831
   2365,          -3.,           4.,   5.72688961
   2366,          -3.,           4.,   5.81579161
   2367,          -3.,   3.96735287,   5.91211796
   2368,          -3.,   3.94149399,   5.92674637
   2369,          -3.,   3.92263055,   5.94705629
   2370,          -3.,   3.91045308,   5.97224379
   2371,          -3.,           3.,   5.90658188
   2372,          -3.,           3.,    5.8132782
   2373,          -3.,           3.,   5.72026777
   2374,          -3.,           3.,   5.62777281
   2375,          -3.,           3.,   5.53601646
   2376,          -3.,           3.,   5.44515181
   2377,          -3.,           3.,   5.35519409
   2378,          -3.,           3.,   5.26599503
   2379,          -3.,           3.,   5.17727041
   2380,          -3.,           3.,    5.0886941
   2381,          -5.,           4.,   8.10000038
   2382,          -5.,           4.,   8.19999981
   2383,          -5.,           4.,   8.30000019
   2384,          -5.,           4.,   8.39999962
   2385,          -5.,           4.,          8.5
   2386,          -5.,           4.,   8.60000038
   2387,          -5.,           4.,   8.69999981
   2388,          -5.,           4.,   8.80000019
   2389,          -5.,           4.,   8.89999962
   2390,          -5.,           5.,   8.89999962
   2391,          -5.,           5.,   8.80000019
   2392,          -5.,           5.,   8.69999981
   2393,          -5.,           5.,   8.60000038
   2394,          -5.,           5.,          8.5
   2395,          -5.,           5.,   8.39999962
   2396,          -5.,           5.,   8.30000019
   2397,          -5.,           5.,   8.19999981
   2398,          -5.,           5.,   8.10000038
   2399,          -3.,           4.,    7.0999999
   2400,          -3.,           4.,   7.19999981
   2401,          -3.,           4.,   7.30000019
   2402,          -3.,           4.,    7.4000001
   2403,          -3.,           4.,          7.5
   2404,          -3.,           4.,    7.5999999
   2405,          -3.,           4.,   7.69999981
   2406,          -3.,           4.,   7.80000019
   2407,          -3.,           4.,    7.9000001
   2408,          -3.,           3.,    7.9000001
   2409,          -3.,           3.,   7.80000019
   2410,          -3.,           3.,   7.69999981
   2411,          -3.,           3.,    7.5999999
   2412,          -3.,           3.,          7.5
   2413,          -3.,           3.,    7.4000001
   2414,          -3.,           3.,   7.30000019
   2415,          -3.,           3.,   7.19999981
   2416,          -3.,           3.,    7.0999999
   2417,          -5.,    3.9000001,           9.
   2418,          -5.,   3.79999995,           9.
   2419,          -5.,   3.70000005,           9.
   2420,          -5.,    3.5999999,           9.
   2421,          -5.,          3.5,           9.
   2422,          -5.,    3.4000001,           9.
   2423,          -5.,   3.29999995,           9.
   2424,          -5.,   3.20000005,           9.
   2425,          -5.,    3.0999999,           9.
   2426,          -5.,    3.0999999,          10.
   2427,          -5.,   3.20000005,          10.
   2428,          -5.,   3.29999995,          10.
   2429,          -5.,    3.4000001,          10.
   2430,          -5.,          3.5,          10.
   2431,          -5.,    3.5999999,          10.
   2432,          -5.,   3.70000005,          10.
   2433,          -5.,   3.79999995,          10.
   2434,          -5.,    3.9000001,          10.
   2435,   -4.0999999,           3.,          10.
   2436,  -4.19999981,           3.,          10.
   2437,  -4.30000019,           3.,          10.
   2438,   -4.4000001,           3.,          10.
   2439,         -4.5,           3.,          10.
   2440,   -4.5999999,           3.,          10.
   2441,  -4.69999981,           3.,          10.
   2442,  -4.80000019,           3.,          10.
   2443,   -4.9000001,           3.,          10.
   2444,          -5.,           3.,   9.89999962
   2445,          -5.,           3.,   9.80000019
   2446,          -5.,           3.,   9.69999981
   2447,          -5.,           3.,   9.60000038
   2448,          -5.,           3.,          9.5
   2449,          -5.,           3.,   9.39999962
   2450,          -5.,           3.,   9.30000019
   2451,          -5.,           3.,   9.19999981
   2452,          -5.,           3.,   9.10000038
   2453,   -4.9000001,           3.,           9.
   2454,  -4.80000019,           3.,           9.
   2455,  -4.69999981,           3.,           9.
   2456,   -4.5999999,           3.,           9.
   2457,         -4.5,           3.,           9.
   2458,   -4.4000001,           3.,           9.
   2459,  -4.30000019,           3.,           9.
   2460,  -4.19999981,           3.,           9.
   2461,   -4.0999999,           3.,           9.
   2462,          -3.,   4.10009575,           7.
   2463,          -3.,   4.20017958,           7.
   2464,          -3.,    4.3002615,           7.
   2465,          -3.,   4.40034199,           7.
   2466,          -3.,   4.50040913,           7.
   2467,          -3.,   4.60043764,           7.
   2468,          -3.,   4.70040607,           7.
   2469,          -3.,   4.80031061,           7.
   2470,          -3.,   4.90016556,           7.
   2471,          -3.,           5.,    7.9000001
   2472,          -3.,           5.,   7.80000019
   2473,          -3.,           5.,   7.69999981
   2474,          -3.,           5.,    7.5999999
   2475,          -3.,           5.,          7.5
   2476,          -3.,           5.,    7.4000001
   2477,          -3.,           5.,   7.30000019
   2478,          -3.,           5.,   7.19999981
   2479,          -3.,           5.,    7.0999999
   2480,   -3.0999999,           5.,           7.
   2481,  -3.20000005,           5.,           7.
   2482,  -3.29999995,           5.,           7.
   2483,   -3.4000001,           5.,           7.
   2484,         -3.5,           5.,           7.
   2485,   -3.5999999,           5.,           7.
   2486,  -3.70000005,           5.,           7.
   2487,  -3.79999995,           5.,           7.
   2488,   -3.9000001,           5.,           7.
   2489,          -5.,           3.,   8.89999962
   2490,          -5.,           3.,   8.80000019
   2491,          -5.,           3.,   8.69999981
   2492,          -5.,           3.,   8.60000038
   2493,          -5.,           3.,          8.5
   2494,          -5.,           3.,   8.39999962
   2495,          -5.,           3.,   8.30000019
   2496,          -5.,           3.,   8.19999981
   2497,          -5.,           3.,   8.10000038
   2498,   -3.0999999,      4.09375,           6.
   2499,  -3.20000005,      4.09375,           6.
   2500,  -3.29999995,      4.09375,           6.
   2501,   -3.4000001,      4.09375,           6.
   2502,         -3.5,      4.09375,           6.
   2503,   -3.5999999,      4.09375,           6.
   2504,  -3.70000005,      4.09375,           6.
   2505,  -3.79999995,      4.09375,           6.
   2506,   -3.9000001,      4.09375,           6.
   2507,   -3.9000001,      4.09375,           5.
   2508,  -3.79999995,      4.09375,           5.
   2509,  -3.70000005,      4.09375,           5.
   2510,   -3.5999999,      4.09375,           5.
   2511,         -3.5,      4.09375,           5.
   2512,   -3.4000001,      4.09375,           5.
   2513,  -3.29999995,      4.09375,           5.
   2514,  -3.20000005,      4.09375,           5.
   2515,   -3.0999999,      4.09375,           5.
   2516,   -3.0999999,           5.,           5.
   2517,  -3.20000005,           5.,           5.
   2518,  -3.29999995,           5.,           5.
   2519,   -3.4000001,           5.,           5.
   2520,         -3.5,           5.,           5.
   2521,   -3.5999999,           5.,           5.
   2522,  -3.70000005,           5.,           5.
   2523,  -3.79999995,           5.,           5.
   2524,   -3.9000001,           5.,           5.
   2525,   -3.0999999,           5.,           6.
   2526,  -3.20000005,           5.,           6.
   2527,  -3.29999995,           5.,           6.
   2528,   -3.4000001,           5.,           6.
   2529,         -3.5,           5.,           6.
   2530,   -3.5999999,           5.,           6.
   2531,  -3.70000005,           5.,           6.
   2532,  -3.79999995,           5.,           6.
   2533,   -3.9000001,           5.,           6.
   2534,          -3.,   4.03413105,   5.08731604
   2535,          -3.,   4.06026173,   5.07181644
   2536,          -3.,   4.07843828,   5.05134678
   2537,          -3.,   4.08986712,   5.02670145
   2538,          -3.,   4.18467999,           5.
   2539,          -3.,   4.27467155,           5.
   2540,          -3.,   4.37137413,           5.
   2541,          -3.,   4.47277832,           5.
   2542,          -3.,   4.57666683,           5.
   2543,          -3.,   4.68163681,           5.
   2544,          -3.,   4.78766346,           5.
   2545,          -3.,   4.89381552,           5.
   2546,          -3.,           5.,   5.09965658
   2547,          -3.,           5.,   5.19939804
   2548,          -3.,           5.,   5.29925489
   2549,          -3.,           5.,   5.39926195
   2550,          -3.,           5.,   5.49941778
   2551,          -3.,           5.,   5.59967661
   2552,          -3.,           5.,   5.69994354
   2553,          -3.,           5.,   5.80010605
   2554,          -3.,           5.,   5.90010881
   2555,          -3.,   4.89947224,           6.
   2556,          -3.,   4.79880619,           6.
   2557,          -3.,   4.69764423,           6.
   2558,          -3.,   4.59468079,           6.
   2559,          -3.,   4.49268484,           6.
   2560,          -3.,   4.39258385,           6.
   2561,          -3.,   4.29205608,           6.
   2562,          -3.,   4.19520855,           6.
   2563,          -3.,   4.09105968,   5.97770119
   2564,          -3.,   4.08302498,   5.95645761
   2565,          -3.,   4.06971693,   5.93732119
   2566,          -3.,   4.05093145,   5.92129135
   2567,          -3.,   4.02706003,   5.91024017
   2568,          -3.,   4.02986145,   6.08886719
   2569,          -3.,    4.0547266,   6.07611847
   2570,          -3.,   4.07227135,   6.05971527
   2571,          -3.,   4.08408833,   6.04145193
   2572,          -3.,   4.09133387,    6.0211463
   2573,          -3.,           5.,   6.09373856
   2574,          -3.,           5.,   6.18758535
   2575,          -3.,           5.,   6.27974272
   2576,          -3.,           5.,   6.37038946
   2577,          -3.,           5.,   6.46180153
   2578,          -3.,           5.,   6.55362272
   2579,          -3.,           5.,   6.64497042
   2580,          -3.,           5.,   6.73595619
   2581,          -3.,           5.,   6.82583857
   2582,          -3.,           5.,   6.91383553
   2583,   -3.0999999,      4.09375,           4.
   2584,  -3.20000005,      4.09375,           4.
   2585,  -3.29999995,      4.09375,           4.
   2586,   -3.4000001,      4.09375,           4.
   2587,         -3.5,      4.09375,           4.
   2588,   -3.5999999,      4.09375,           4.
   2589,  -3.70000005,      4.09375,           4.
   2590,  -3.79999995,      4.09375,           4.
   2591,   -3.9000001,      4.09375,           4.
   2592,   -3.0999999,           5.,           4.
   2593,  -3.20000005,           5.,           4.
   2594,  -3.29999995,           5.,           4.
   2595,   -3.4000001,           5.,           4.
   2596,         -3.5,           5.,           4.
   2597,   -3.5999999,           5.,           4.
   2598,  -3.70000005,           5.,           4.
   2599,  -3.79999995,           5.,           4.
   2600,   -3.9000001,           5.,           4.
   2601,          -3.,    4.0314784,   3.08830738
   2602,          -3.,   4.05767107,   3.07391286
   2603,          -3.,   4.07752228,   3.05271959
   2604,          -3.,   4.08966684,   3.02736688
   2605,          -3.,           5.,   3.09410286
   2606,          -3.,           5.,   3.18858695
   2607,          -3.,           5.,   3.28378963
   2608,          -3.,           5.,   3.37965775
   2609,          -3.,           5.,   3.47779632
   2610,          -3.,           5.,    3.5787344
   2611,          -3.,           5.,   3.68222737
   2612,          -3.,           5.,   3.78752637
   2613,          -3.,           5.,   3.89402699
   2614,          -3.,   4.89366007,           4.
   2615,          -3.,   4.78721666,           4.
   2616,          -3.,   4.68050432,           4.
   2617,          -3.,   4.57320547,           4.
   2618,          -3.,   4.46756458,           4.
   2619,          -3.,   4.36332798,           4.
   2620,          -3.,   4.26828194,           4.
   2621,          -3.,   4.18136692,           4.
   2622,          -3.,   4.08947182,   3.97200251
   2623,          -3.,   4.07717705,   3.94677639
   2624,          -3.,   4.05742455,   3.92589521
   2625,          -3.,   4.03079891,   3.91145349
   2626,          -3.,   4.08983803,   4.97320175
   2627,          -3.,    4.0783267,   4.94848299
   2628,          -3.,   4.05999899,   4.92796373
   2629,          -3.,   4.03389454,   4.91259146
   2630,          -3.,   4.02607584,    4.0900507
   2631,          -3.,   4.04951477,   4.07960749
   2632,          -3.,   4.06845236,   4.06405735
   2633,          -3.,   4.08228254,    4.0449295
   2634,          -3.,   4.09084749,   4.02314806
   2635,          -3.,           5.,    4.0998826
   2636,          -3.,           5.,   4.19992495
   2637,          -3.,           5.,   4.30014944
   2638,          -3.,           5.,   4.40045214
   2639,          -3.,           5.,   4.50069046
   2640,          -3.,           5.,   4.60077524
   2641,          -3.,           5.,   4.70069313
   2642,          -3.,           5.,   4.80048227
   2643,          -3.,           5.,   4.90022087
   2644,          -4.,   4.05670738,   1.94254065
   2645,          -4.,   4.04224634,   1.93825436
   2646,          -4.,    4.0222683,   1.93392944
   2647,          -4.,    4.0658226,    1.9772501
   2648,          -4.,   4.06119204,   1.95704365
   2649,          -4.,   4.04369736,   1.97810459
   2650,          -4.,   4.02188969,    1.9779377
   2651,          -4.,   4.04219007,   1.95735455
   2652,          -4.,   4.02158689,    1.9560833
   2653,          -4.,   4.46506214,   1.49875569
   2654,          -4.,   4.45878553,   1.60006094
   2655,          -4.,   4.45320892,   1.70732141
   2656,          -4.,   4.46440935,     1.811023
   2657,          -4.,   4.47234917,   1.90670109
   2658,          -4.,   4.49284077,   1.07527399
   2659,          -4.,   4.48920584,   1.15193701
   2660,          -4.,   4.48301697,   1.23157167
   2661,          -4.,   4.47813559,   1.31533217
   2662,          -4.,   4.47123337,   1.40377402
   2663,          -4.,   4.35188675,   1.47839856
   2664,          -4.,   4.23586702,   1.44952774
   2665,          -4.,   4.11692524,   1.42124462
   2666,          -4.,   4.57716846,   1.90505552
   2667,          -4.,   4.68312931,   1.90494609
   2668,          -4.,    4.7889576,    1.9055953
   2669,          -4.,   4.89456034,    1.9062264
   2670,          -4.,   4.57414532,   1.80878448
   2671,          -4.,   4.68266058,    1.8094306
   2672,          -4.,   4.78910732,    1.8110795
   2673,          -4.,   4.89471245,    1.8124423
   2674,          -4.,    4.5707531,   1.70988059
   2675,          -4.,   4.68239546,   1.71328211
   2676,          -4.,   4.78932905,   1.71657896
   2677,          -4.,   4.89487743,   1.71886063
   2678,          -4.,   4.57201576,   1.61004996
   2679,          -4.,   4.68332672,   1.61740446
   2680,          -4.,   4.78979397,   1.62258148
   2681,          -4.,   4.89506769,   1.62580252
   2682,          -4.,    4.5747776,   1.51276827
   2683,          -4.,   4.68374157,   1.52279377
   2684,          -4.,   4.79023314,   1.52967691
   2685,          -4.,   4.89520264,   1.53358173
   2686,          -4.,   4.57829285,   1.41947365
   2687,          -4.,   4.68531704,   1.43101764
   2688,          -4.,   4.79040956,   1.43819427
   2689,          -4.,   4.89520931,   1.44237185
   2690,          -4.,   4.58144903,    1.3300848
   2691,          -4.,    4.6857605,   1.34127975
   2692,          -4.,   4.79032326,   1.34820843
   2693,          -4.,    4.8950901,   1.35220194
   2694,          -4.,   4.58393574,   1.24412751
   2695,          -4.,   4.68591309,   1.25371504
   2696,          -4.,   4.79005527,   1.25961518
   2697,          -4.,    4.8948884,   1.26300597
   2698,          -4.,    4.5862093,   1.16102409
   2699,          -4.,   4.68592501,   1.16795516
   2700,          -4.,   4.78974199,   1.17222118
   2701,          -4.,   4.89466381,   1.17467499
   2702,          -4.,   4.58861589,   1.07996416
   2703,          -4.,   4.68610096,   1.08355856
   2704,          -4.,   4.78954268,   1.08578515
   2705,          -4.,   4.89446688,   1.08707142
   2706,          -4.,   4.31623554,   1.70869327
   2707,          -4.,   4.35614347,   1.82198858
   2708,          -4.,   4.37479067,   1.91402531
   2709,          -4.,    4.3443222,   1.58407187
   2710,          -4.,   4.09764528,   1.61630225
   2711,          -4.,   4.20015526,   1.64874518
   2712,          -4.,   4.11829376,    1.8800714
   2713,          -4.,   4.16569328,   1.83570695
   2714,          -4.,   4.22734737,   1.78133869
   2715,          -4.,   4.22359562,   1.55048048
   2716,          -4.,   4.10972738,    1.5242883
   2717,          -4.,   4.07888651,   1.69945753
   2718,          -4.,   4.05981827,   1.77348208
   2719,          -4.,   4.04335308,   1.83617282
   2720,          -4.,   4.15715408,   1.72799015
   2721,          -4.,   4.11662769,    1.7976408
   2722,          -4.,   4.08384609,   1.85338473
   2723,          -4.,   4.14308262,   1.91615391
   2724,          -4.,    4.1580534,    1.9569962
   2725,          -4.,   4.19892788,    1.8871839
   2726,          -4.,   4.21811104,   1.94296837
   2727,          -4.,   4.26824427,   1.85448098
   2728,          -4.,   4.28991795,   1.92786884
   2729,          -4.,   4.12187719,   1.30022025
   2730,          -4.,    4.3622961,   1.38124013
   2731,          -4.,   4.24857903,   1.34880376
   2732,          -4.,   4.23438644,   1.05179143
   2733,          -4.,   4.22554159,   1.10497165
   2734,          -4.,   4.20861912,    1.1614275
   2735,          -4.,   4.17871284,   1.22423196
   2736,          -4.,   4.06508923,   1.20355129
   2737,          -4.,   4.37441158,   1.29377866
   2738,          -4.,   4.38577938,   1.21406937
   2739,          -4.,   4.39475632,   1.13987803
   2740,          -4.,   4.40178299,   1.06911421
   2741,          -4.,   4.27322578,    1.2644434
   2742,          -4.,   4.29221439,   1.19102025
   2743,          -4.,   4.30688381,   1.12429357
   2744,          -4.,   4.31549597,    1.0612998
   2745,          -4.,   4.16663647,   1.04102254
   2746,          -4.,   4.15784693,   1.08242416
   2747,          -4.,   4.14019012,   1.12529135
   2748,          -4.,   4.11170769,   1.17046857
   2749,          -4.,   4.05857563,   1.05562353
   2750,          -4.,   4.06246948,   1.04137373
   2751,          -4.,   4.06642008,   1.02180147
   2752,          -4.,   4.02358389,   1.06548214
   2753,          -4.,   4.04413414,    1.0603776
   2754,          -4.,   4.02229404,   1.04346132
   2755,          -4.,   4.02226257,   1.02175617
   2756,          -4.,   4.04329634,     1.041646
   2757,          -4.,   4.04426193,   1.02130079
   2758,          -5.,   4.02520227,   1.90970099
   2759,          -5.,   4.04772854,    1.9193089
   2760,          -5.,   4.06575251,   1.93317437
   2761,          -5.,   4.07998133,   1.95109177
   2762,          -5.,    4.0900569,   1.97394621
   2763,          -5.,   4.09050274,   1.02446103
   2764,          -5.,   4.08155298,   1.04624069
   2765,          -5.,   4.06851721,   1.06398785
   2766,          -5.,   4.05107164,   1.07861769
   2767,          -5.,    4.0279336,   1.08949184
   2768,          -5.,   4.05670738,   1.94254065
   2769,          -5.,   4.04224634,   1.93825436
   2770,          -5.,    4.0222683,   1.93392944
   2771,          -5.,    4.0658226,    1.9772501
   2772,          -5.,   4.06119204,   1.95704365
   2773,          -5.,   4.04369736,   1.97810459
   2774,          -5.,   4.02188969,    1.9779377
   2775,          -5.,   4.04219007,   1.95735455
   2776,          -5.,   4.02158689,    1.9560833
   2777,          -5.,    4.4650631,   1.49875593
   2778,          -5.,   4.45878696,   1.60005951
   2779,          -5.,   4.45321178,   1.70731688
   2780,          -5.,   4.46441126,   1.81101799
   2781,          -5.,   4.47234917,   1.90670109
   2782,          -5.,   4.49281359,   1.07528114
   2783,          -5.,   4.48919249,   1.15194798
   2784,          -5.,   4.48301792,   1.23157787
   2785,          -5.,   4.47813702,   1.31533527
   2786,          -5.,   4.47123528,   1.40377617
   2787,          -5.,   4.35188961,   1.47840023
   2788,          -5.,   4.23587036,   1.44952965
   2789,          -5.,   4.11692858,   1.42124557
   2790,          -5.,   4.57716846,   1.90505505
   2791,          -5.,   4.68312883,   1.90494585
   2792,          -5.,   4.78895712,   1.90559483
   2793,          -5.,   4.89456034,   1.90622616
   2794,          -5.,   4.57414579,   1.80878258
   2795,          -5.,   4.68266058,   1.80943012
   2796,          -5.,   4.78910732,   1.81107903
   2797,          -5.,   4.89471245,    1.8124423
   2798,          -5.,   4.57075405,   1.70987892
   2799,          -5.,   4.68239594,   1.71328163
   2800,          -5.,   4.78932905,   1.71657848
   2801,          -5.,   4.89487743,   1.71886015
   2802,          -5.,   4.57201672,   1.61004925
   2803,          -5.,    4.6833272,   1.61740446
   2804,          -5.,   4.78979397,   1.62258148
   2805,          -5.,   4.89506769,   1.62580252
   2806,          -5.,   4.57477856,   1.51276875
   2807,          -5.,   4.68374157,   1.52279377
   2808,          -5.,   4.79023314,   1.52967691
   2809,          -5.,   4.89520264,   1.53358173
   2810,          -5.,   4.57829332,    1.4194746
   2811,          -5.,   4.68531704,   1.43101788
   2812,          -5.,   4.79040956,   1.43819427
   2813,          -5.,   4.89520931,   1.44237185
   2814,          -5.,   4.58144951,   1.33008623
   2815,          -5.,   4.68576097,   1.34127998
   2816,          -5.,   4.79032326,   1.34820843
   2817,          -5.,    4.8950901,   1.35220194
   2818,          -5.,   4.58393574,   1.24413013
   2819,          -5.,   4.68591356,   1.25371552
   2820,          -5.,   4.79005575,   1.25961542
   2821,          -5.,    4.8948884,   1.26300621
   2822,          -5.,   4.58620691,   1.16102791
   2823,          -5.,   4.68592501,    1.1679554
   2824,          -5.,   4.78974199,   1.17222118
   2825,          -5.,   4.89466381,   1.17467499
   2826,          -5.,   4.58860493,   1.07996702
   2827,          -5.,   4.68610048,   1.08355904
   2828,          -5.,   4.78954268,   1.08578539
   2829,          -5.,   4.89446688,   1.08707142
   2830,          -5.,   4.31624079,   1.70869064
   2831,          -5.,   4.35614824,   1.82197285
   2832,          -5.,   4.37478733,   1.91401577
   2833,          -5.,   4.34432316,   1.58407128
   2834,          -5.,   4.09763193,   1.61640203
   2835,          -5.,   4.20014286,   1.64878011
   2836,          -5.,   4.11852932,   1.87988853
   2837,          -5.,   4.16578245,   1.83564568
   2838,          -5.,   4.22737741,   1.78131008
   2839,          -5.,   4.22359467,    1.5504849
   2840,          -5.,   4.10972643,   1.52430248
   2841,          -5.,   4.07867432,   1.70135128
   2842,          -5.,    4.0598278,   1.77389348
   2843,          -5.,   4.04342461,   1.83659744
   2844,          -5.,   4.15696621,   1.72844744
   2845,          -5.,   4.11665058,   1.79782486
   2846,          -5.,   4.08402586,   1.85331392
   2847,          -5.,   4.14313412,   1.91597557
   2848,          -5.,   4.15788221,   1.95688915
   2849,          -5.,   4.19895458,   1.88710213
   2850,          -5.,   4.21806049,   1.94291496
   2851,          -5.,   4.26825619,   1.85444355
   2852,          -5.,   4.28990221,   1.92784405
   2853,          -5.,   4.12188721,    1.3002286
   2854,          -5.,    4.3623004,   1.38124514
   2855,          -5.,   4.24858761,   1.34881067
   2856,          -5.,   4.23429489,    1.0518589
   2857,          -5.,   4.22550154,   1.10509062
   2858,          -5.,   4.20865393,   1.16156006
   2859,          -5.,   4.17874718,   1.22431087
   2860,          -5.,   4.06509256,   1.20352077
   2861,          -5.,   4.37441778,    1.2937932
   2862,          -5.,   4.38578033,   1.21409464
   2863,          -5.,   4.39473248,   1.13990498
   2864,          -5.,   4.40177441,   1.06913185
   2865,          -5.,   4.27324152,   1.26447868
   2866,          -5.,   4.29222345,   1.19107676
   2867,          -5.,   4.30686903,   1.12435341
   2868,          -5.,   4.31544495,   1.06133604
   2869,          -5.,   4.16707802,   1.04114676
   2870,          -5.,   4.15775251,   1.08266544
   2871,          -5.,   4.14028931,   1.12562656
   2872,          -5.,   4.11175776,    1.1706605
   2873,          -5.,   4.05857563,   1.05562353
   2874,          -5.,   4.06246948,   1.04137373
   2875,          -5.,   4.06642008,   1.02180147
   2876,          -5.,   4.02358389,   1.06548214
   2877,          -5.,   4.04413414,    1.0603776
   2878,          -5.,   4.02229404,   1.04346132
   2879,          -5.,   4.02226257,   1.02175617
   2880,          -5.,   4.04329634,     1.041646
   2881,          -5.,   4.04426193,   1.02130079
   2882,   -4.0999999,           5.,   1.90666962
   2883,   -4.0999999,           5.,   1.81331825
   2884,   -4.0999999,           5.,   1.72020614
   2885,   -4.0999999,           5.,   1.62761402
   2886,   -4.0999999,           5.,   1.53575552
   2887,   -4.0999999,           5.,   1.44471991
   2888,   -4.0999999,           5.,   1.35448492
   2889,   -4.0999999,           5.,   1.26497471
   2890,   -4.0999999,           5.,   1.17611253
   2891,   -4.0999999,           5.,    1.0878247
   2892,  -4.19999981,           5.,   1.90666962
   2893,  -4.19999981,           5.,   1.81331825
   2894,  -4.19999981,           5.,   1.72020614
   2895,  -4.19999981,           5.,   1.62761402
   2896,  -4.19999981,           5.,   1.53575552
   2897,  -4.19999981,           5.,   1.44471991
   2898,  -4.19999981,           5.,   1.35448492
   2899,  -4.19999981,           5.,   1.26497471
   2900,  -4.19999981,           5.,   1.17611253
   2901,  -4.19999981,           5.,    1.0878247
   2902,  -4.30000019,           5.,   1.90666962
   2903,  -4.30000019,           5.,   1.81331825
   2904,  -4.30000019,           5.,   1.72020614
   2905,  -4.30000019,           5.,   1.62761402
   2906,  -4.30000019,           5.,   1.53575552
   2907,  -4.30000019,           5.,   1.44471991
   2908,  -4.30000019,           5.,   1.35448492
   2909,  -4.30000019,           5.,   1.26497471
   2910,  -4.30000019,           5.,   1.17611253
   2911,  -4.30000019,           5.,    1.0878247
   2912,   -4.4000001,           5.,   1.90666962
   2913,   -4.4000001,           5.,   1.81331825
   2914,   -4.4000001,           5.,   1.72020614
   2915,   -4.4000001,           5.,   1.62761402
   2916,   -4.4000001,           5.,   1.53575552
   2917,   -4.4000001,           5.,   1.44471991
   2918,   -4.4000001,           5.,   1.35448492
   2919,   -4.4000001,           5.,   1.26497471
   2920,   -4.4000001,           5.,   1.17611253
   2921,   -4.4000001,           5.,    1.0878247
   2922,         -4.5,           5.,   1.90666962
   2923,         -4.5,           5.,   1.81331825
   2924,         -4.5,           5.,   1.72020614
   2925,         -4.5,           5.,   1.62761402
   2926,         -4.5,           5.,   1.53575552
   2927,         -4.5,           5.,   1.44471991
   2928,         -4.5,           5.,   1.35448492
   2929,         -4.5,           5.,   1.26497471
   2930,         -4.5,           5.,   1.17611253
   2931,         -4.5,           5.,    1.0878247
   2932,   -4.5999999,           5.,   1.90666962
   2933,   -4.5999999,           5.,   1.81331825
   2934,   -4.5999999,           5.,   1.72020614
   2935,   -4.5999999,           5.,   1.62761402
   2936,   -4.5999999,           5.,   1.53575552
   2937,   -4.5999999,           5.,   1.44471991
   2938,   -4.5999999,           5.,   1.35448492
   2939,   -4.5999999,           5.,   1.26497471
   2940,   -4.5999999,           5.,   1.17611253
   2941,   -4.5999999,           5.,    1.0878247
   2942,  -4.69999981,           5.,   1.90666962
   2943,  -4.69999981,           5.,   1.81331825
   2944,  -4.69999981,           5.,   1.72020614
   2945,  -4.69999981,           5.,   1.62761402
   2946,  -4.69999981,           5.,   1.53575552
   2947,  -4.69999981,           5.,   1.44471991
   2948,  -4.69999981,           5.,   1.35448492
   2949,  -4.69999981,           5.,   1.26497471
   2950,  -4.69999981,           5.,   1.17611253
   2951,  -4.69999981,           5.,    1.0878247
   2952,  -4.80000019,           5.,   1.90666962
   2953,  -4.80000019,           5.,   1.81331825
   2954,  -4.80000019,           5.,   1.72020614
   2955,  -4.80000019,           5.,   1.62761402
   2956,  -4.80000019,           5.,   1.53575552
   2957,  -4.80000019,           5.,   1.44471991
   2958,  -4.80000019,           5.,   1.35448492
   2959,  -4.80000019,           5.,   1.26497471
   2960,  -4.80000019,           5.,   1.17611253
   2961,  -4.80000019,           5.,    1.0878247
   2962,   -4.9000001,           5.,   1.90666962
   2963,   -4.9000001,           5.,   1.81331825
   2964,   -4.9000001,           5.,   1.72020614
   2965,   -4.9000001,           5.,   1.62761402
   2966,   -4.9000001,           5.,   1.53575552
   2967,   -4.9000001,           5.,   1.44471991
   2968,   -4.9000001,           5.,   1.35448492
   2969,   -4.9000001,           5.,   1.26497471
   2970,   -4.9000001,           5.,   1.17611253
   2971,   -4.9000001,           5.,    1.0878247
   2972,   -4.0999999,   4.02227402,           2.
   2973,   -4.0999999,   4.04477119,           2.
   2974,   -4.0999999,   4.06816053,           2.
   2975,   -4.0999999,      4.09375,           2.
   2976,   -4.0999999,   4.16161203,           2.
   2977,   -4.0999999,   4.22976112,           2.
   2978,   -4.0999999,   4.30356359,           2.
   2979,   -4.0999999,   4.38937283,           2.
   2980,   -4.0999999,   4.48416996,           2.
   2981,   -4.0999999,   4.58394909,           2.
   2982,   -4.0999999,   4.68604708,           2.
   2983,   -4.0999999,     4.789258,           2.
   2984,   -4.0999999,    4.8944397,           2.
   2985,  -4.19999981,   4.02227402,           2.
   2986,  -4.19999981,   4.04477119,           2.
   2987,  -4.19999981,   4.06816053,           2.
   2988,  -4.19999981,      4.09375,           2.
   2989,  -4.19999981,   4.16161203,           2.
   2990,  -4.19999981,   4.22976112,           2.
   2991,  -4.19999981,   4.30356359,           2.
   2992,  -4.19999981,   4.38937283,           2.
   2993,  -4.19999981,   4.48416996,           2.
   2994,  -4.19999981,   4.58394909,           2.
   2995,  -4.19999981,   4.68604708,           2.
   2996,  -4.19999981,     4.789258,           2.
   2997,  -4.19999981,    4.8944397,           2.
   2998,  -4.30000019,   4.02227402,           2.
   2999,  -4.30000019,   4.04477119,           2.
   3000,  -4.30000019,   4.06816053,           2.
   3001,  -4.30000019,      4.09375,           2.
   3002,  -4.30000019,   4.16161203,           2.
   3003,  -4.30000019,   4.22976112,           2.
   3004,  -4.30000019,   4.30356359,           2.
   3005,  -4.30000019,   4.38937283,           2.
   3006,  -4.30000019,   4.48416996,           2.
   3007,  -4.30000019,   4.58394909,           2.
   3008,  -4.30000019,   4.68604708,           2.
   3009,  -4.30000019,     4.789258,           2.
   3010,  -4.30000019,    4.8944397,           2.
   3011,   -4.4000001,   4.02227402,           2.
   3012,   -4.4000001,   4.04477119,           2.
   3013,   -4.4000001,   4.06816053,           2.
   3014,   -4.4000001,      4.09375,           2.
   3015,   -4.4000001,   4.16161203,           2.
   3016,   -4.4000001,   4.22976112,           2.
   3017,   -4.4000001,   4.30356359,           2.
   3018,   -4.4000001,   4.38937283,           2.
   3019,   -4.4000001,   4.48416996,           2.
   3020,   -4.4000001,   4.58394909,           2.
   3021,   -4.4000001,   4.68604708,           2.
   3022,   -4.4000001,     4.789258,           2.
   3023,   -4.4000001,    4.8944397,           2.
   3024,         -4.5,   4.02227402,           2.
   3025,         -4.5,   4.04477119,           2.
   3026,         -4.5,   4.06816053,           2.
   3027,         -4.5,      4.09375,           2.
   3028,         -4.5,   4.16161203,           2.
   3029,         -4.5,   4.22976112,           2.
   3030,         -4.5,   4.30356359,           2.
   3031,         -4.5,   4.38937283,           2.
   3032,         -4.5,   4.48416996,           2.
   3033,         -4.5,   4.58394909,           2.
   3034,         -4.5,   4.68604708,           2.
   3035,         -4.5,     4.789258,           2.
   3036,         -4.5,    4.8944397,           2.
   3037,   -4.5999999,   4.02227402,           2.
   3038,   -4.5999999,   4.04477119,           2.
   3039,   -4.5999999,   4.06816053,           2.
   3040,   -4.5999999,      4.09375,           2.
   3041,   -4.5999999,   4.16161203,           2.
   3042,   -4.5999999,   4.22976112,           2.
   3043,   -4.5999999,   4.30356359,           2.
   3044,   -4.5999999,   4.38937283,           2.
   3045,   -4.5999999,   4.48416996,           2.
   3046,   -4.5999999,   4.58394909,           2.
   3047,   -4.5999999,   4.68604708,           2.
   3048,   -4.5999999,     4.789258,           2.
   3049,   -4.5999999,    4.8944397,           2.
   3050,  -4.69999981,   4.02227402,           2.
   3051,  -4.69999981,   4.04477119,           2.
   3052,  -4.69999981,   4.06816053,           2.
   3053,  -4.69999981,      4.09375,           2.
   3054,  -4.69999981,   4.16161203,           2.
   3055,  -4.69999981,   4.22976112,           2.
   3056,  -4.69999981,   4.30356359,           2.
   3057,  -4.69999981,   4.38937283,           2.
   3058,  -4.69999981,   4.48416996,           2.
   3059,  -4.69999981,   4.58394909,           2.
   3060,  -4.69999981,   4.68604708,           2.
   3061,  -4.69999981,     4.789258,           2.
   3062,  -4.69999981,    4.8944397,           2.
   3063,  -4.80000019,   4.02227402,           2.
   3064,  -4.80000019,   4.04477119,           2.
   3065,  -4.80000019,   4.06816053,           2.
   3066,  -4.80000019,      4.09375,           2.
   3067,  -4.80000019,   4.16161203,           2.
   3068,  -4.80000019,   4.22976112,           2.
   3069,  -4.80000019,   4.30356359,           2.
   3070,  -4.80000019,   4.38937283,           2.
   3071,  -4.80000019,   4.48416996,           2.
   3072,  -4.80000019,   4.58394909,           2.
   3073,  -4.80000019,   4.68604708,           2.
   3074,  -4.80000019,     4.789258,           2.
   3075,  -4.80000019,    4.8944397,           2.
   3076,   -4.9000001,   4.02227402,           2.
   3077,   -4.9000001,   4.04477119,           2.
   3078,   -4.9000001,   4.06816053,           2.
   3079,   -4.9000001,      4.09375,           2.
   3080,   -4.9000001,   4.16161203,           2.
   3081,   -4.9000001,   4.22976112,           2.
   3082,   -4.9000001,   4.30356359,           2.
   3083,   -4.9000001,   4.38937283,           2.
   3084,   -4.9000001,   4.48416996,           2.
   3085,   -4.9000001,   4.58394909,           2.
   3086,   -4.9000001,   4.68604708,           2.
   3087,   -4.9000001,     4.789258,           2.
   3088,   -4.9000001,    4.8944397,           2.
   3089,   -4.0999999,   4.02224541,           1.
   3090,   -4.0999999,   4.04476166,           1.
   3091,   -4.0999999,   4.06817436,           1.
   3092,   -4.0999999,      4.09375,           1.
   3093,   -4.0999999,   4.16601658,           1.
   3094,   -4.0999999,   4.23990154,           1.
   3095,   -4.0999999,   4.32177258,           1.
   3096,   -4.0999999,   4.40878439,           1.
   3097,   -4.0999999,   4.49960423,           1.
   3098,   -4.0999999,   4.59433365,           1.
   3099,   -4.0999999,   4.69114208,           1.
   3100,   -4.0999999,   4.79059315,           1.
   3101,   -4.0999999,   4.89500809,           1.
   3102,  -4.19999981,   4.02224541,           1.
   3103,  -4.19999981,   4.04476166,           1.
   3104,  -4.19999981,   4.06817436,           1.
   3105,  -4.19999981,      4.09375,           1.
   3106,  -4.19999981,   4.16601658,           1.
   3107,  -4.19999981,   4.23990154,           1.
   3108,  -4.19999981,   4.32177258,           1.
   3109,  -4.19999981,   4.40878439,           1.
   3110,  -4.19999981,   4.49960423,           1.
   3111,  -4.19999981,   4.59433365,           1.
   3112,  -4.19999981,   4.69114208,           1.
   3113,  -4.19999981,   4.79059315,           1.
   3114,  -4.19999981,   4.89500809,           1.
   3115,  -4.30000019,   4.02224541,           1.
   3116,  -4.30000019,   4.04476166,           1.
   3117,  -4.30000019,   4.06817436,           1.
   3118,  -4.30000019,      4.09375,           1.
   3119,  -4.30000019,   4.16601658,           1.
   3120,  -4.30000019,   4.23990154,           1.
   3121,  -4.30000019,   4.32177258,           1.
   3122,  -4.30000019,   4.40878439,           1.
   3123,  -4.30000019,   4.49960423,           1.
   3124,  -4.30000019,   4.59433365,           1.
   3125,  -4.30000019,   4.69114208,           1.
   3126,  -4.30000019,   4.79059315,           1.
   3127,  -4.30000019,   4.89500809,           1.
   3128,   -4.4000001,   4.02224541,           1.
   3129,   -4.4000001,   4.04476166,           1.
   3130,   -4.4000001,   4.06817436,           1.
   3131,   -4.4000001,      4.09375,           1.
   3132,   -4.4000001,   4.16601658,           1.
   3133,   -4.4000001,   4.23990154,           1.
   3134,   -4.4000001,   4.32177258,           1.
   3135,   -4.4000001,   4.40878439,           1.
   3136,   -4.4000001,   4.49960423,           1.
   3137,   -4.4000001,   4.59433365,           1.
   3138,   -4.4000001,   4.69114208,           1.
   3139,   -4.4000001,   4.79059315,           1.
   3140,   -4.4000001,   4.89500809,           1.
   3141,         -4.5,   4.02224541,           1.
   3142,         -4.5,   4.04476166,           1.
   3143,         -4.5,   4.06817436,           1.
   3144,         -4.5,      4.09375,           1.
   3145,         -4.5,   4.16601658,           1.
   3146,         -4.5,   4.23990154,           1.
   3147,         -4.5,   4.32177258,           1.
   3148,         -4.5,   4.40878439,           1.
   3149,         -4.5,   4.49960423,           1.
   3150,         -4.5,   4.59433365,           1.
   3151,         -4.5,   4.69114208,           1.
   3152,         -4.5,   4.79059315,           1.
   3153,         -4.5,   4.89500809,           1.
   3154,   -4.5999999,   4.02224541,           1.
   3155,   -4.5999999,   4.04476166,           1.
   3156,   -4.5999999,   4.06817436,           1.
   3157,   -4.5999999,      4.09375,           1.
   3158,   -4.5999999,   4.16601658,           1.
   3159,   -4.5999999,   4.23990154,           1.
   3160,   -4.5999999,   4.32177258,           1.
   3161,   -4.5999999,   4.40878439,           1.
   3162,   -4.5999999,   4.49960423,           1.
   3163,   -4.5999999,   4.59433365,           1.
   3164,   -4.5999999,   4.69114208,           1.
   3165,   -4.5999999,   4.79059315,           1.
   3166,   -4.5999999,   4.89500809,           1.
   3167,  -4.69999981,   4.02224541,           1.
   3168,  -4.69999981,   4.04476166,           1.
   3169,  -4.69999981,   4.06817436,           1.
   3170,  -4.69999981,      4.09375,           1.
   3171,  -4.69999981,   4.16601658,           1.
   3172,  -4.69999981,   4.23990154,           1.
   3173,  -4.69999981,   4.32177258,           1.
   3174,  -4.69999981,   4.40878439,           1.
   3175,  -4.69999981,   4.49960423,           1.
   3176,  -4.69999981,   4.59433365,           1.
   3177,  -4.69999981,   4.69114208,           1.
   3178,  -4.69999981,   4.79059315,           1.
   3179,  -4.69999981,   4.89500809,           1.
   3180,  -4.80000019,   4.02224541,           1.
   3181,  -4.80000019,   4.04476166,           1.
   3182,  -4.80000019,   4.06817436,           1.
   3183,  -4.80000019,      4.09375,           1.
   3184,  -4.80000019,   4.16601658,           1.
   3185,  -4.80000019,   4.23990154,           1.
   3186,  -4.80000019,   4.32177258,           1.
   3187,  -4.80000019,   4.40878439,           1.
   3188,  -4.80000019,   4.49960423,           1.
   3189,  -4.80000019,   4.59433365,           1.
   3190,  -4.80000019,   4.69114208,           1.
   3191,  -4.80000019,   4.79059315,           1.
   3192,  -4.80000019,   4.89500809,           1.
   3193,   -4.9000001,   4.02224541,           1.
   3194,   -4.9000001,   4.04476166,           1.
   3195,   -4.9000001,   4.06817436,           1.
   3196,   -4.9000001,      4.09375,           1.
   3197,   -4.9000001,   4.16601658,           1.
   3198,   -4.9000001,   4.23990154,           1.
   3199,   -4.9000001,   4.32177258,           1.
   3200,   -4.9000001,   4.40878439,           1.
   3201,   -4.9000001,   4.49960423,           1.
   3202,   -4.9000001,   4.59433365,           1.
   3203,   -4.9000001,   4.69114208,           1.
   3204,   -4.9000001,   4.79059315,           1.
   3205,   -4.9000001,   4.89500809,           1.
   3206,   -4.0999999,           4.,   1.02293539
   3207,   -4.0999999,           4.,   1.04572082
   3208,   -4.0999999,           4.,   1.06880665
   3209,   -4.0999999,           4.,      1.09375
   3210,   -4.0999999,           4.,    1.1959933
   3211,   -4.0999999,           4.,   1.28467679
   3212,   -4.0999999,           4.,    1.3807888
   3213,   -4.0999999,           4.,   1.47567558
   3214,   -4.0999999,           4.,    1.5677737
   3215,   -4.0999999,           4.,   1.65489125
   3216,   -4.0999999,           4.,   1.73922157
   3217,   -4.0999999,           4.,   1.81893182
   3218,   -4.0999999,           4.,      1.90625
   3219,   -4.0999999,           4.,   1.93175268
   3220,   -4.0999999,           4.,   1.95512819
   3221,   -4.0999999,           4.,   1.97766066
   3222,  -4.19999981,           4.,   1.02293539
   3223,  -4.19999981,           4.,   1.04572082
   3224,  -4.19999981,           4.,   1.06880665
   3225,  -4.19999981,           4.,      1.09375
   3226,  -4.19999981,           4.,    1.1959933
   3227,  -4.19999981,           4.,   1.28467679
   3228,  -4.19999981,           4.,    1.3807888
   3229,  -4.19999981,           4.,   1.47567558
   3230,  -4.19999981,           4.,    1.5677737
   3231,  -4.19999981,           4.,   1.65489125
   3232,  -4.19999981,           4.,   1.73922157
   3233,  -4.19999981,           4.,   1.81893182
   3234,  -4.19999981,           4.,      1.90625
   3235,  -4.19999981,           4.,   1.93175268
   3236,  -4.19999981,           4.,   1.95512819
   3237,  -4.19999981,           4.,   1.97766066
   3238,  -4.30000019,           4.,   1.02293539
   3239,  -4.30000019,           4.,   1.04572082
   3240,  -4.30000019,           4.,   1.06880665
   3241,  -4.30000019,           4.,      1.09375
   3242,  -4.30000019,           4.,    1.1959933
   3243,  -4.30000019,           4.,   1.28467679
   3244,  -4.30000019,           4.,    1.3807888
   3245,  -4.30000019,           4.,   1.47567558
   3246,  -4.30000019,           4.,    1.5677737
   3247,  -4.30000019,           4.,   1.65489125
   3248,  -4.30000019,           4.,   1.73922157
   3249,  -4.30000019,           4.,   1.81893182
   3250,  -4.30000019,           4.,      1.90625
   3251,  -4.30000019,           4.,   1.93175268
   3252,  -4.30000019,           4.,   1.95512819
   3253,  -4.30000019,           4.,   1.97766066
   3254,   -4.4000001,           4.,   1.02293539
   3255,   -4.4000001,           4.,   1.04572082
   3256,   -4.4000001,           4.,   1.06880665
   3257,   -4.4000001,           4.,      1.09375
   3258,   -4.4000001,           4.,    1.1959933
   3259,   -4.4000001,           4.,   1.28467679
   3260,   -4.4000001,           4.,    1.3807888
   3261,   -4.4000001,           4.,   1.47567558
   3262,   -4.4000001,           4.,    1.5677737
   3263,   -4.4000001,           4.,   1.65489125
   3264,   -4.4000001,           4.,   1.73922157
   3265,   -4.4000001,           4.,   1.81893182
   3266,   -4.4000001,           4.,      1.90625
   3267,   -4.4000001,           4.,   1.93175268
   3268,   -4.4000001,           4.,   1.95512819
   3269,   -4.4000001,           4.,   1.97766066
   3270,         -4.5,           4.,   1.02293539
   3271,         -4.5,           4.,   1.04572082
   3272,         -4.5,           4.,   1.06880665
   3273,         -4.5,           4.,      1.09375
   3274,         -4.5,           4.,    1.1959933
   3275,         -4.5,           4.,   1.28467679
   3276,         -4.5,           4.,    1.3807888
   3277,         -4.5,           4.,   1.47567558
   3278,         -4.5,           4.,    1.5677737
   3279,         -4.5,           4.,   1.65489125
   3280,         -4.5,           4.,   1.73922157
   3281,         -4.5,           4.,   1.81893182
   3282,         -4.5,           4.,      1.90625
   3283,         -4.5,           4.,   1.93175268
   3284,         -4.5,           4.,   1.95512819
   3285,         -4.5,           4.,   1.97766066
   3286,   -4.5999999,           4.,   1.02293539
   3287,   -4.5999999,           4.,   1.04572082
   3288,   -4.5999999,           4.,   1.06880665
   3289,   -4.5999999,           4.,      1.09375
   3290,   -4.5999999,           4.,    1.1959933
   3291,   -4.5999999,           4.,   1.28467679
   3292,   -4.5999999,           4.,    1.3807888
   3293,   -4.5999999,           4.,   1.47567558
   3294,   -4.5999999,           4.,    1.5677737
   3295,   -4.5999999,           4.,   1.65489125
   3296,   -4.5999999,           4.,   1.73922157
   3297,   -4.5999999,           4.,   1.81893182
   3298,   -4.5999999,           4.,      1.90625
   3299,   -4.5999999,           4.,   1.93175268
   3300,   -4.5999999,           4.,   1.95512819
   3301,   -4.5999999,           4.,   1.97766066
   3302,  -4.69999981,           4.,   1.02293539
   3303,  -4.69999981,           4.,   1.04572082
   3304,  -4.69999981,           4.,   1.06880665
   3305,  -4.69999981,           4.,      1.09375
   3306,  -4.69999981,           4.,    1.1959933
   3307,  -4.69999981,           4.,   1.28467679
   3308,  -4.69999981,           4.,    1.3807888
   3309,  -4.69999981,           4.,   1.47567558
   3310,  -4.69999981,           4.,    1.5677737
   3311,  -4.69999981,           4.,   1.65489125
   3312,  -4.69999981,           4.,   1.73922157
   3313,  -4.69999981,           4.,   1.81893182
   3314,  -4.69999981,           4.,      1.90625
   3315,  -4.69999981,           4.,   1.93175268
   3316,  -4.69999981,           4.,   1.95512819
   3317,  -4.69999981,           4.,   1.97766066
   3318,  -4.80000019,           4.,   1.02293539
   3319,  -4.80000019,           4.,   1.04572082
   3320,  -4.80000019,           4.,   1.06880665
   3321,  -4.80000019,           4.,      1.09375
   3322,  -4.80000019,           4.,    1.1959933
   3323,  -4.80000019,           4.,   1.28467679
   3324,  -4.80000019,           4.,    1.3807888
   3325,  -4.80000019,           4.,   1.47567558
   3326,  -4.80000019,           4.,    1.5677737
   3327,  -4.80000019,           4.,   1.65489125
   3328,  -4.80000019,           4.,   1.73922157
   3329,  -4.80000019,           4.,   1.81893182
   3330,  -4.80000019,           4.,      1.90625
   3331,  -4.80000019,           4.,   1.93175268
   3332,  -4.80000019,           4.,   1.95512819
   3333,  -4.80000019,           4.,   1.97766066
   3334,   -4.9000001,           4.,   1.02293539
   3335,   -4.9000001,           4.,   1.04572082
   3336,   -4.9000001,           4.,   1.06880665
   3337,   -4.9000001,           4.,      1.09375
   3338,   -4.9000001,           4.,    1.1959933
   3339,   -4.9000001,           4.,   1.28467679
   3340,   -4.9000001,           4.,    1.3807888
   3341,   -4.9000001,           4.,   1.47567558
   3342,   -4.9000001,           4.,    1.5677737
   3343,   -4.9000001,           4.,   1.65489125
   3344,   -4.9000001,           4.,   1.73922157
   3345,   -4.9000001,           4.,   1.81893182
   3346,   -4.9000001,           4.,      1.90625
   3347,   -4.9000001,           4.,   1.93175268
   3348,   -4.9000001,           4.,   1.95512819
   3349,   -4.9000001,           4.,   1.97766066
   3350,          -4.,   4.05696917,   2.05725336
   3351,          -4.,   4.06132078,   2.04288101
   3352,          -4.,   4.06582069,   2.02273941
   3353,          -4.,   4.02265787,   2.06594467
   3354,          -4.,   4.04263735,   2.06150818
   3355,          -4.,   4.02179289,   2.04385376
   3356,          -4.,   4.02198124,   2.02199936
   3357,          -4.,   4.04239273,   2.04252243
   3358,          -4.,   4.04374313,    2.0218153
   3359,          -4.,   4.47165537,   2.57332063
   3360,          -4.,    4.4699049,   2.47325778
   3361,          -4.,   4.12059879,   2.59157157
   3362,          -4.,   4.24234009,   2.58109069
   3363,          -4.,   4.35902214,   2.57461452
   3364,          -4.,   4.47152424,   2.37197471
   3365,          -4.,   4.47777462,   2.27426863
   3366,          -4.,    4.4830308,   2.18039322
   3367,          -4.,   4.48947906,   2.08884406
   3368,          -4.,   4.48877907,   2.92229843
   3369,          -4.,   4.48531961,   2.84281254
   3370,          -4.,   4.48097992,   2.75976872
   3371,          -4.,   4.47531033,   2.66880107
   3372,          -4.,   4.89689636,   2.48534966
   3373,          -4.,   4.79277802,   2.48387337
   3374,          -4.,   4.68711948,   2.48100615
   3375,          -4.,   4.57967615,    2.4772613
   3376,          -4.,   4.22279787,   2.32906365
   3377,          -4.,   4.23472691,    2.4638381
   3378,          -4.,   4.10339022,   2.35830474
   3379,          -4.,   4.35759878,   2.35962343
   3380,          -4.,   4.30648184,   2.07193089
   3381,          -4.,   4.29467058,   2.14641428
   3382,          -4.,   4.27028179,    2.2278564
   3383,          -4.,   4.09724236,   2.16441178
   3384,          -4.,   4.14670753,   2.23338413
   3385,          -4.,   4.11476231,   2.47270179
   3386,          -4.,    4.3553133,   2.46783352
   3387,          -4.,   4.37287807,    2.2570889
   3388,          -4.,   4.38618851,   2.16645551
   3389,          -4.,   4.39503574,   2.08181572
   3390,          -4.,   4.23059559,   2.05887985
   3391,          -4.,   4.16499233,   2.04516912
   3392,          -4.,   4.21727085,   2.11816263
   3393,          -4.,   4.15286636,   2.08927441
   3394,          -4.,   4.19129848,   2.17760563
   3395,          -4.,   4.13105345,   2.13080049
   3396,          -4.,   4.05199623,   2.18414021
   3397,          -4.,   4.07552338,   2.26184011
   3398,          -4.,   4.12450981,   2.72131944
   3399,          -4.,   4.25296879,   2.69128823
   3400,          -4.,   4.36630249,   2.67540812
   3401,          -4.,   4.06730938,   2.80899024
   3402,          -4.,   4.22462797,   2.94010878
   3403,          -4.,   4.20986462,   2.87743759
   3404,          -4.,   4.18140507,   2.80744505
   3405,          -4.,   4.11517715,   2.84825635
   3406,          -4.,    4.1435957,    2.9004848
   3407,          -4.,   4.15939045,    2.9507072
   3408,          -4.,   4.30345154,   2.93199277
   3409,          -4.,   4.39367962,   2.92598486
   3410,          -4.,   4.29381657,   2.86073208
   3411,          -4.,   4.38757849,   2.84914756
   3412,          -4.,   4.27650452,   2.78203773
   3413,          -4.,   4.37790871,   2.76692867
   3414,          -4.,   4.89753008,     2.578866
   3415,          -4.,   4.79292727,   2.57642245
   3416,          -4.,   4.68720627,   2.57436514
   3417,          -4.,   4.58016109,   2.57282829
   3418,          -4.,   4.89718628,   2.66698456
   3419,          -4.,    4.7935338,   2.66743469
   3420,          -4.,   4.68791723,   2.66600084
   3421,          -4.,   4.58182907,   2.66588831
   3422,          -4.,   4.89600182,     2.751688
   3423,          -4.,   4.79181576,   2.75249624
   3424,          -4.,   4.68765545,   2.75380969
   3425,          -4.,   4.58392668,   2.75592279
   3426,          -4.,    4.8951025,   2.83510351
   3427,          -4.,     4.790555,   2.83591461
   3428,          -4.,   4.68685436,   2.83729005
   3429,          -4.,   4.58473778,   2.83950424
   3430,          -4.,   4.89480209,   2.91773939
   3431,          -4.,   4.79022598,    2.9182291
   3432,          -4.,   4.68690014,   2.91906118
   3433,          -4.,   4.58715343,   2.92021585
   3434,          -4.,    4.5803237,   2.37956858
   3435,          -4.,   4.68721008,   2.38561368
   3436,          -4.,    4.7929554,   2.39054513
   3437,          -4.,   4.89675331,   2.39225769
   3438,          -4.,   4.58264399,   2.28261518
   3439,          -4.,   4.68741322,   2.28909826
   3440,          -4.,   4.79219532,   2.29406857
   3441,          -4.,   4.89622688,   2.29541111
   3442,          -4.,   4.58506393,   2.18752527
   3443,          -4.,   4.68736458,   2.19328547
   3444,          -4.,   4.79127693,   2.19578457
   3445,          -4.,   4.89559221,   2.19691181
   3446,          -4.,   4.58783531,   2.09315872
   3447,          -4.,   4.68750286,   2.09626603
   3448,          -4.,   4.79084015,   2.09769726
   3449,          -4.,   4.89521837,   2.09835672
   3450,          -4.,   4.04392195,   2.93594408
   3451,          -4.,   4.02500439,   2.93295193
   3452,          -4.,   4.05667543,   2.97430801
   3453,          -4.,   4.05026102,   2.95178795
   3454,          -4.,   4.02793884,   2.97613049
   3455,          -4.,   4.02580118,   2.95364666
   3456,          -5.,   4.09000587,    2.0262301
   3457,          -5.,   4.07996845,   2.04892993
   3458,          -5.,   4.06602955,   2.06655216
   3459,          -5.,    4.0484581,   2.08025503
   3460,          -5.,   4.02609444,   2.09004521
   3461,          -5.,   4.03029633,   2.91128016
   3462,          -5.,   4.05504417,   2.92411041
   3463,          -5.,   4.07464647,   2.94328141
   3464,          -5.,   4.08860159,   2.96936035
   3465,          -5.,   4.05696917,   2.05725336
   3466,          -5.,   4.06132078,   2.04288101
   3467,          -5.,   4.06582069,   2.02273941
   3468,          -5.,   4.02265787,   2.06594467
   3469,          -5.,   4.04263735,   2.06150818
   3470,          -5.,   4.02179289,   2.04385376
   3471,          -5.,   4.02198124,   2.02199936
   3472,          -5.,   4.04239273,   2.04252243
   3473,          -5.,   4.04374313,    2.0218153
   3474,          -5.,   4.47165871,   2.57331133
   3475,          -5.,   4.46990871,   2.47325325
   3476,          -5.,    4.1205945,   2.59153652
   3477,          -5.,   4.24233913,   2.58106613
   3478,          -5.,   4.35902739,   2.57459641
   3479,          -5.,   4.47152901,   2.37197399
   3480,          -5.,   4.47777987,   2.27427101
   3481,          -5.,   4.48303318,   2.18039513
   3482,          -5.,   4.48948002,   2.08884668
   3483,          -5.,   4.48902512,   2.92225266
   3484,          -5.,   4.48542166,   2.84278679
   3485,          -5.,   4.48099995,    2.7597537
   3486,          -5.,   4.47532034,   2.66878605
   3487,          -5.,   4.89689684,   2.48534966
   3488,          -5.,   4.79277802,   2.48387337
   3489,          -5.,   4.68711996,   2.48100567
   3490,          -5.,   4.57967806,   2.47725916
   3491,          -5.,   4.22282648,   2.32906437
   3492,          -5.,   4.23473597,   2.46382999
   3493,          -5.,   4.10340977,   2.35828018
   3494,          -5.,   4.35760689,   2.35962343
   3495,          -5.,   4.30647278,   2.07194424
   3496,          -5.,   4.29468441,   2.14643955
   3497,          -5.,   4.27031851,   2.22788239
   3498,          -5.,     4.097404,   2.16449642
   3499,          -5.,   4.14678955,    2.2334094
   3500,          -5.,   4.11476898,   2.47268391
   3501,          -5.,   4.35531998,   2.46782589
   3502,          -5.,   4.37289238,    2.2570982
   3503,          -5.,   4.38619566,   2.16646624
   3504,          -5.,   4.39503574,    2.0818224
   3505,          -5.,   4.23054552,   2.05892277
   3506,          -5.,   4.16478825,   2.04528236
   3507,          -5.,   4.21729612,   2.11824226
   3508,          -5.,   4.15288925,   2.08948135
   3509,          -5.,   4.19138908,   2.17769527
   3510,          -5.,    4.1312542,   2.13105726
   3511,          -5.,   4.05206347,   2.18399811
   3512,          -5.,   4.07556581,   2.26179218
   3513,          -5.,   4.12448835,    2.7212286
   3514,          -5.,   4.25295877,   2.69124126
   3515,          -5.,   4.36631775,   2.67537689
   3516,          -5.,    4.0672226,   2.80875921
   3517,          -5.,   4.22453165,   2.94000053
   3518,          -5.,   4.20982122,   2.87728214
   3519,          -5.,   4.18137074,   2.80726337
   3520,          -5.,   4.11508942,   2.84781647
   3521,          -5.,    4.1433754,   2.90004826
   3522,          -5.,   4.15899372,    2.9504323
   3523,          -5.,   4.30361795,   2.93198109
   3524,          -5.,   4.39435148,   2.92582703
   3525,          -5.,   4.29391813,   2.86066008
   3526,          -5.,   4.38780594,   2.84907484
   3527,          -5.,   4.27651691,   2.78195572
   3528,          -5.,   4.37796497,   2.76688385
   3529,          -5.,   4.89753008,     2.578866
   3530,          -5.,   4.79292727,   2.57642221
   3531,          -5.,   4.68720675,   2.57436371
   3532,          -5.,     4.580163,   2.57282352
   3533,          -5.,   4.89718628,   2.66698456
   3534,          -5.,    4.7935338,   2.66743469
   3535,          -5.,   4.68791723,   2.66599941
   3536,          -5.,   4.58183146,   2.66588211
   3537,          -5.,   4.89600182,     2.751688
   3538,          -5.,   4.79181576,   2.75249624
   3539,          -5.,   4.68765545,   2.75380898
   3540,          -5.,    4.5839262,   2.75591898
   3541,          -5.,    4.8951025,   2.83510351
   3542,          -5.,     4.790555,   2.83591461
   3543,          -5.,   4.68685389,   2.83728933
   3544,          -5.,   4.58473873,   2.83950043
   3545,          -5.,   4.89480305,   2.91773939
   3546,          -5.,   4.79022789,    2.9182291
   3547,          -5.,   4.68690586,   2.91906071
   3548,          -5.,   4.58723831,   2.92020321
   3549,          -5.,   4.58032608,    2.3795681
   3550,          -5.,   4.68721104,   2.38561368
   3551,          -5.,    4.7929554,   2.39054537
   3552,          -5.,   4.89675331,   2.39225769
   3553,          -5.,   4.58264637,   2.28261614
   3554,          -5.,   4.68741417,   2.28909874
   3555,          -5.,    4.7921958,   2.29406881
   3556,          -5.,   4.89622688,   2.29541111
   3557,          -5.,   4.58506536,   2.18752623
   3558,          -5.,   4.68736506,   2.19328594
   3559,          -5.,   4.79127741,   2.19578457
   3560,          -5.,   4.89559221,   2.19691181
   3561,          -5.,   4.58783627,   2.09315968
   3562,          -5.,   4.68750286,   2.09626627
   3563,          -5.,   4.79084015,   2.09769726
   3564,          -5.,   4.89521837,   2.09835672
   3565,          -5.,   4.04392195,   2.93594408
   3566,          -5.,   4.02500439,   2.93295193
   3567,          -5.,   4.05667543,   2.97430801
   3568,          -5.,   4.05026102,   2.95178795
   3569,          -5.,   4.02793884,   2.97613049
   3570,          -5.,   4.02580118,   2.95364666
   3571,   -4.0999999,           5.,    2.9175415
   3572,   -4.0999999,           5.,   2.83483577
   3573,   -4.0999999,           5.,   2.75144887
   3574,   -4.0999999,           5.,   2.66646767
   3575,   -4.0999999,           5.,   2.57763124
   3576,   -4.0999999,           5.,   2.48536658
   3577,   -4.0999999,           5.,   2.39205194
   3578,   -4.0999999,           5.,   2.29633784
   3579,   -4.0999999,           5.,   2.19771409
   3580,   -4.0999999,           5.,   2.09881759
   3581,  -4.19999981,           5.,    2.9175415
   3582,  -4.19999981,           5.,   2.83483577
   3583,  -4.19999981,           5.,   2.75144887
   3584,  -4.19999981,           5.,   2.66646767
   3585,  -4.19999981,           5.,   2.57763124
   3586,  -4.19999981,           5.,   2.48536658
   3587,  -4.19999981,           5.,   2.39205194
   3588,  -4.19999981,           5.,   2.29633784
   3589,  -4.19999981,           5.,   2.19771409
   3590,  -4.19999981,           5.,   2.09881759
   3591,  -4.30000019,           5.,    2.9175415
   3592,  -4.30000019,           5.,   2.83483577
   3593,  -4.30000019,           5.,   2.75144887
   3594,  -4.30000019,           5.,   2.66646767
   3595,  -4.30000019,           5.,   2.57763124
   3596,  -4.30000019,           5.,   2.48536658
   3597,  -4.30000019,           5.,   2.39205194
   3598,  -4.30000019,           5.,   2.29633784
   3599,  -4.30000019,           5.,   2.19771409
   3600,  -4.30000019,           5.,   2.09881759
   3601,   -4.4000001,           5.,    2.9175415
   3602,   -4.4000001,           5.,   2.83483577
   3603,   -4.4000001,           5.,   2.75144887
   3604,   -4.4000001,           5.,   2.66646767
   3605,   -4.4000001,           5.,   2.57763124
   3606,   -4.4000001,           5.,   2.48536658
   3607,   -4.4000001,           5.,   2.39205194
   3608,   -4.4000001,           5.,   2.29633784
   3609,   -4.4000001,           5.,   2.19771409
   3610,   -4.4000001,           5.,   2.09881759
   3611,         -4.5,           5.,    2.9175415
   3612,         -4.5,           5.,   2.83483577
   3613,         -4.5,           5.,   2.75144887
   3614,         -4.5,           5.,   2.66646767
   3615,         -4.5,           5.,   2.57763124
   3616,         -4.5,           5.,   2.48536658
   3617,         -4.5,           5.,   2.39205194
   3618,         -4.5,           5.,   2.29633784
   3619,         -4.5,           5.,   2.19771409
   3620,         -4.5,           5.,   2.09881759
   3621,   -4.5999999,           5.,    2.9175415
   3622,   -4.5999999,           5.,   2.83483577
   3623,   -4.5999999,           5.,   2.75144887
   3624,   -4.5999999,           5.,   2.66646767
   3625,   -4.5999999,           5.,   2.57763124
   3626,   -4.5999999,           5.,   2.48536658
   3627,   -4.5999999,           5.,   2.39205194
   3628,   -4.5999999,           5.,   2.29633784
   3629,   -4.5999999,           5.,   2.19771409
   3630,   -4.5999999,           5.,   2.09881759
   3631,  -4.69999981,           5.,    2.9175415
   3632,  -4.69999981,           5.,   2.83483577
   3633,  -4.69999981,           5.,   2.75144887
   3634,  -4.69999981,           5.,   2.66646767
   3635,  -4.69999981,           5.,   2.57763124
   3636,  -4.69999981,           5.,   2.48536658
   3637,  -4.69999981,           5.,   2.39205194
   3638,  -4.69999981,           5.,   2.29633784
   3639,  -4.69999981,           5.,   2.19771409
   3640,  -4.69999981,           5.,   2.09881759
   3641,  -4.80000019,           5.,    2.9175415
   3642,  -4.80000019,           5.,   2.83483577
   3643,  -4.80000019,           5.,   2.75144887
   3644,  -4.80000019,           5.,   2.66646767
   3645,  -4.80000019,           5.,   2.57763124
   3646,  -4.80000019,           5.,   2.48536658
   3647,  -4.80000019,           5.,   2.39205194
   3648,  -4.80000019,           5.,   2.29633784
   3649,  -4.80000019,           5.,   2.19771409
   3650,  -4.80000019,           5.,   2.09881759
   3651,   -4.9000001,           5.,    2.9175415
   3652,   -4.9000001,           5.,   2.83483577
   3653,   -4.9000001,           5.,   2.75144887
   3654,   -4.9000001,           5.,   2.66646767
   3655,   -4.9000001,           5.,   2.57763124
   3656,   -4.9000001,           5.,   2.48536658
   3657,   -4.9000001,           5.,   2.39205194
   3658,   -4.9000001,           5.,   2.29633784
   3659,   -4.9000001,           5.,   2.19771409
   3660,   -4.9000001,           5.,   2.09881759
   3661,   -4.0999999,           4.,   2.02237296
   3662,   -4.0999999,           4.,   2.04493904
   3663,   -4.0999999,           4.,   2.06831408
   3664,   -4.0999999,           4.,      2.09375
   3665,   -4.0999999,           4.,   2.18219471
   3666,   -4.0999999,           4.,   2.26937294
   3667,   -4.0999999,           4.,   2.36404705
   3668,   -4.0999999,           4.,    2.4673667
   3669,   -4.0999999,           4.,    2.5773921
   3670,   -4.0999999,           4.,   2.69318724
   3671,   -4.0999999,           4.,   2.79750061
   3672,   -4.0999999,           4.,      2.90625
   3673,   -4.0999999,           4.,   2.93154669
   3674,   -4.0999999,           4.,   2.95459414
   3675,   -4.0999999,           4.,   2.97727394
   3676,  -4.19999981,           4.,   2.02237296
   3677,  -4.19999981,           4.,   2.04493904
   3678,  -4.19999981,           4.,   2.06831408
   3679,  -4.19999981,           4.,      2.09375
   3680,  -4.19999981,           4.,   2.18219471
   3681,  -4.19999981,           4.,   2.26937294
   3682,  -4.19999981,           4.,   2.36404705
   3683,  -4.19999981,           4.,    2.4673667
   3684,  -4.19999981,           4.,    2.5773921
   3685,  -4.19999981,           4.,   2.69318724
   3686,  -4.19999981,           4.,   2.79750061
   3687,  -4.19999981,           4.,      2.90625
   3688,  -4.19999981,           4.,   2.93154669
   3689,  -4.19999981,           4.,   2.95459414
   3690,  -4.19999981,           4.,   2.97727394
   3691,  -4.30000019,           4.,   2.02237296
   3692,  -4.30000019,           4.,   2.04493904
   3693,  -4.30000019,           4.,   2.06831408
   3694,  -4.30000019,           4.,      2.09375
   3695,  -4.30000019,           4.,   2.18219471
   3696,  -4.30000019,           4.,   2.26937294
   3697,  -4.30000019,           4.,   2.36404705
   3698,  -4.30000019,           4.,    2.4673667
   3699,  -4.30000019,           4.,    2.5773921
   3700,  -4.30000019,           4.,   2.69318724
   3701,  -4.30000019,           4.,   2.79750061
   3702,  -4.30000019,           4.,      2.90625
   3703,  -4.30000019,           4.,   2.93154669
   3704,  -4.30000019,           4.,   2.95459414
   3705,  -4.30000019,           4.,   2.97727394
   3706,   -4.4000001,           4.,   2.02237296
   3707,   -4.4000001,           4.,   2.04493904
   3708,   -4.4000001,           4.,   2.06831408
   3709,   -4.4000001,           4.,      2.09375
   3710,   -4.4000001,           4.,   2.18219471
   3711,   -4.4000001,           4.,   2.26937294
   3712,   -4.4000001,           4.,   2.36404705
   3713,   -4.4000001,           4.,    2.4673667
   3714,   -4.4000001,           4.,    2.5773921
   3715,   -4.4000001,           4.,   2.69318724
   3716,   -4.4000001,           4.,   2.79750061
   3717,   -4.4000001,           4.,      2.90625
   3718,   -4.4000001,           4.,   2.93154669
   3719,   -4.4000001,           4.,   2.95459414
   3720,   -4.4000001,           4.,   2.97727394
   3721,         -4.5,           4.,   2.02237296
   3722,         -4.5,           4.,   2.04493904
   3723,         -4.5,           4.,   2.06831408
   3724,         -4.5,           4.,      2.09375
   3725,         -4.5,           4.,   2.18219471
   3726,         -4.5,           4.,   2.26937294
   3727,         -4.5,           4.,   2.36404705
   3728,         -4.5,           4.,    2.4673667
   3729,         -4.5,           4.,    2.5773921
   3730,         -4.5,           4.,   2.69318724
   3731,         -4.5,           4.,   2.79750061
   3732,         -4.5,           4.,      2.90625
   3733,         -4.5,           4.,   2.93154669
   3734,         -4.5,           4.,   2.95459414
   3735,         -4.5,           4.,   2.97727394
   3736,   -4.5999999,           4.,   2.02237296
   3737,   -4.5999999,           4.,   2.04493904
   3738,   -4.5999999,           4.,   2.06831408
   3739,   -4.5999999,           4.,      2.09375
   3740,   -4.5999999,           4.,   2.18219471
   3741,   -4.5999999,           4.,   2.26937294
   3742,   -4.5999999,           4.,   2.36404705
   3743,   -4.5999999,           4.,    2.4673667
   3744,   -4.5999999,           4.,    2.5773921
   3745,   -4.5999999,           4.,   2.69318724
   3746,   -4.5999999,           4.,   2.79750061
   3747,   -4.5999999,           4.,      2.90625
   3748,   -4.5999999,           4.,   2.93154669
   3749,   -4.5999999,           4.,   2.95459414
   3750,   -4.5999999,           4.,   2.97727394
   3751,  -4.69999981,           4.,   2.02237296
   3752,  -4.69999981,           4.,   2.04493904
   3753,  -4.69999981,           4.,   2.06831408
   3754,  -4.69999981,           4.,      2.09375
   3755,  -4.69999981,           4.,   2.18219471
   3756,  -4.69999981,           4.,   2.26937294
   3757,  -4.69999981,           4.,   2.36404705
   3758,  -4.69999981,           4.,    2.4673667
   3759,  -4.69999981,           4.,    2.5773921
   3760,  -4.69999981,           4.,   2.69318724
   3761,  -4.69999981,           4.,   2.79750061
   3762,  -4.69999981,           4.,      2.90625
   3763,  -4.69999981,           4.,   2.93154669
   3764,  -4.69999981,           4.,   2.95459414
   3765,  -4.69999981,           4.,   2.97727394
   3766,  -4.80000019,           4.,   2.02237296
   3767,  -4.80000019,           4.,   2.04493904
   3768,  -4.80000019,           4.,   2.06831408
   3769,  -4.80000019,           4.,      2.09375
   3770,  -4.80000019,           4.,   2.18219471
   3771,  -4.80000019,           4.,   2.26937294
   3772,  -4.80000019,           4.,   2.36404705
   3773,  -4.80000019,           4.,    2.4673667
   3774,  -4.80000019,           4.,    2.5773921
   3775,  -4.80000019,           4.,   2.69318724
   3776,  -4.80000019,           4.,   2.79750061
   3777,  -4.80000019,           4.,      2.90625
   3778,  -4.80000019,           4.,   2.93154669
   3779,  -4.80000019,           4.,   2.95459414
   3780,  -4.80000019,           4.,   2.97727394
   3781,   -4.9000001,           4.,   2.02237296
   3782,   -4.9000001,           4.,   2.04493904
   3783,   -4.9000001,           4.,   2.06831408
   3784,   -4.9000001,           4.,      2.09375
   3785,   -4.9000001,           4.,   2.18219471
   3786,   -4.9000001,           4.,   2.26937294
   3787,   -4.9000001,           4.,   2.36404705
   3788,   -4.9000001,           4.,    2.4673667
   3789,   -4.9000001,           4.,    2.5773921
   3790,   -4.9000001,           4.,   2.69318724
   3791,   -4.9000001,           4.,   2.79750061
   3792,   -4.9000001,           4.,      2.90625
   3793,   -4.9000001,           4.,   2.93154669
   3794,   -4.9000001,           4.,   2.95459414
   3795,   -4.9000001,           4.,   2.97727394
   3796,   -4.0999999,   4.02930593,           3.
   3797,   -4.0999999,   4.05993605,           3.
   3798,   -4.0999999,      4.09375,           3.
   3799,   -4.0999999,   4.16023064,           3.
   3800,   -4.0999999,   4.22873497,           3.
   3801,   -4.0999999,   4.30843306,           3.
   3802,   -4.0999999,   4.39756155,           3.
   3803,   -4.0999999,   4.49048328,           3.
   3804,   -4.0999999,   4.58795023,           3.
   3805,   -4.0999999,   4.68706512,           3.
   3806,   -4.0999999,   4.78976345,           3.
   3807,   -4.0999999,   4.89458084,           3.
   3808,  -4.19999981,   4.02930593,           3.
   3809,  -4.19999981,   4.05993605,           3.
   3810,  -4.19999981,      4.09375,           3.
   3811,  -4.19999981,   4.16023064,           3.
   3812,  -4.19999981,   4.22873497,           3.
   3813,  -4.19999981,   4.30843306,           3.
   3814,  -4.19999981,   4.39756155,           3.
   3815,  -4.19999981,   4.49048328,           3.
   3816,  -4.19999981,   4.58795023,           3.
   3817,  -4.19999981,   4.68706512,           3.
   3818,  -4.19999981,   4.78976345,           3.
   3819,  -4.19999981,   4.89458084,           3.
   3820,  -4.30000019,   4.02930593,           3.
   3821,  -4.30000019,   4.05993605,           3.
   3822,  -4.30000019,      4.09375,           3.
   3823,  -4.30000019,   4.16023064,           3.
   3824,  -4.30000019,   4.22873497,           3.
   3825,  -4.30000019,   4.30843306,           3.
   3826,  -4.30000019,   4.39756155,           3.
   3827,  -4.30000019,   4.49048328,           3.
   3828,  -4.30000019,   4.58795023,           3.
   3829,  -4.30000019,   4.68706512,           3.
   3830,  -4.30000019,   4.78976345,           3.
   3831,  -4.30000019,   4.89458084,           3.
   3832,   -4.4000001,   4.02930593,           3.
   3833,   -4.4000001,   4.05993605,           3.
   3834,   -4.4000001,      4.09375,           3.
   3835,   -4.4000001,   4.16023064,           3.
   3836,   -4.4000001,   4.22873497,           3.
   3837,   -4.4000001,   4.30843306,           3.
   3838,   -4.4000001,   4.39756155,           3.
   3839,   -4.4000001,   4.49048328,           3.
   3840,   -4.4000001,   4.58795023,           3.
   3841,   -4.4000001,   4.68706512,           3.
   3842,   -4.4000001,   4.78976345,           3.
   3843,   -4.4000001,   4.89458084,           3.
   3844,         -4.5,   4.02930593,           3.
   3845,         -4.5,   4.05993605,           3.
   3846,         -4.5,      4.09375,           3.
   3847,         -4.5,   4.16023064,           3.
   3848,         -4.5,   4.22873497,           3.
   3849,         -4.5,   4.30843306,           3.
   3850,         -4.5,   4.39756155,           3.
   3851,         -4.5,   4.49048328,           3.
   3852,         -4.5,   4.58795023,           3.
   3853,         -4.5,   4.68706512,           3.
   3854,         -4.5,   4.78976345,           3.
   3855,         -4.5,   4.89458084,           3.
   3856,   -4.5999999,   4.02930593,           3.
   3857,   -4.5999999,   4.05993605,           3.
   3858,   -4.5999999,      4.09375,           3.
   3859,   -4.5999999,   4.16023064,           3.
   3860,   -4.5999999,   4.22873497,           3.
   3861,   -4.5999999,   4.30843306,           3.
   3862,   -4.5999999,   4.39756155,           3.
   3863,   -4.5999999,   4.49048328,           3.
   3864,   -4.5999999,   4.58795023,           3.
   3865,   -4.5999999,   4.68706512,           3.
   3866,   -4.5999999,   4.78976345,           3.
   3867,   -4.5999999,   4.89458084,           3.
   3868,  -4.69999981,   4.02930593,           3.
   3869,  -4.69999981,   4.05993605,           3.
   3870,  -4.69999981,      4.09375,           3.
   3871,  -4.69999981,   4.16023064,           3.
   3872,  -4.69999981,   4.22873497,           3.
   3873,  -4.69999981,   4.30843306,           3.
   3874,  -4.69999981,   4.39756155,           3.
   3875,  -4.69999981,   4.49048328,           3.
   3876,  -4.69999981,   4.58795023,           3.
   3877,  -4.69999981,   4.68706512,           3.
   3878,  -4.69999981,   4.78976345,           3.
   3879,  -4.69999981,   4.89458084,           3.
   3880,  -4.80000019,   4.02930593,           3.
   3881,  -4.80000019,   4.05993605,           3.
   3882,  -4.80000019,      4.09375,           3.
   3883,  -4.80000019,   4.16023064,           3.
   3884,  -4.80000019,   4.22873497,           3.
   3885,  -4.80000019,   4.30843306,           3.
   3886,  -4.80000019,   4.39756155,           3.
   3887,  -4.80000019,   4.49048328,           3.
   3888,  -4.80000019,   4.58795023,           3.
   3889,  -4.80000019,   4.68706512,           3.
   3890,  -4.80000019,   4.78976345,           3.
   3891,  -4.80000019,   4.89458084,           3.
   3892,   -4.9000001,   4.02930593,           3.
   3893,   -4.9000001,   4.05993605,           3.
   3894,   -4.9000001,      4.09375,           3.
   3895,   -4.9000001,   4.16023064,           3.
   3896,   -4.9000001,   4.22873497,           3.
   3897,   -4.9000001,   4.30843306,           3.
   3898,   -4.9000001,   4.39756155,           3.
   3899,   -4.9000001,   4.49048328,           3.
   3900,   -4.9000001,   4.58795023,           3.
   3901,   -4.9000001,   4.68706512,           3.
   3902,   -4.9000001,   4.78976345,           3.
   3903,   -4.9000001,   4.89458084,           3.
   3904,          -4.,   4.52072525,   0.50289011
   3905,          -4.,   4.51321983,  0.605609179
   3906,          -4.,   4.50754738,   0.70740366
   3907,          -4.,   4.50492573,  0.806995392
   3908,          -4.,   4.50426197,  0.904206514
   3909,          -4.,   4.55126524, 0.0998263359
   3910,          -4.,   4.54866123,  0.199585676
   3911,          -4.,   4.54081631,  0.299471855
   3912,          -4.,   4.53028774,  0.400753021
   3913,          -4.,   4.42664766,  0.505268097
   3914,          -4.,   4.33584976,  0.508795738
   3915,          -4.,   4.24601078,  0.510038376
   3916,          -4.,    4.1604023,  0.505381942
   3917,          -4.,   4.07925987,  0.503749132
   3918,          -4.,   4.59904051,  0.902012348
   3919,          -4.,   4.69373846,   0.90063858
   3920,          -4.,   4.79379034,  0.900028229
   3921,          -4.,   4.89683056,  0.899857521
   3922,          -4.,   4.60066748,  0.803325415
   3923,          -4.,   4.69600868,  0.801038742
   3924,          -4.,   4.79560375,  0.800011873
   3925,          -4.,   4.89777946,  0.799719334
   3926,          -4.,   4.60348606,  0.703379393
   3927,          -4.,   4.69802761,  0.700642109
   3928,          -4.,   4.79840231,  0.699840307
   3929,          -4.,   4.89922142,  0.699540138
   3930,          -4.,   4.60770273,  0.602146626
   3931,          -4.,   4.70347309,  0.600103855
   3932,          -4.,   4.80219555,  0.599524498
   3933,          -4.,   4.90114498,   0.59932375
   3934,          -4.,   4.61392403,  0.500231743
   3935,          -4.,   4.71026468,  0.499489784
   3936,          -4.,   4.80682516,  0.499200821
   3937,          -4.,    4.9034605,  0.499132156
   3938,          -4.,   4.62390995,  0.399787426
   3939,          -4.,   4.71781826,  0.399107933
   3940,          -4.,   4.81191015,  0.399017811
   3941,          -4.,   4.90598297,  0.399044037
   3942,          -4.,   4.63290787,  0.299342155
   3943,          -4.,   4.72538471,   0.29897213
   3944,          -4.,   4.81695843,   0.29902029
   3945,          -4.,   4.90847015,  0.299099922
   3946,          -4.,   4.63948631,  0.199427754
   3947,          -4.,   4.73162651,  0.199156284
   3948,          -4.,    4.8212266,  0.199232101
   3949,          -4.,   4.91060448,  0.199310303
   3950,          -4.,   4.64272785, 0.0997014046
   3951,          -4.,   4.73573494, 0.0995512009
   3952,          -4.,   4.82417583, 0.0995936394
   3953,          -4.,   4.91214752, 0.0996351242
   3954,          -4.,    4.2049427,  0.748678446
   3955,          -4.,   4.23060799,  0.622123718
   3956,          -4.,   4.31227875,   0.72551775
   3957,          -4.,   4.41215897,  0.714109421
   3958,          -4.,     4.061203,  0.706954718
   3959,          -4.,   4.12690973,  0.718960285
   3960,          -4.,    4.1351757,  0.834001064
   3961,          -4.,   4.23863459,  0.925147772
   3962,          -4.,   4.22813797,  0.845024824
   3963,          -4.,   4.41884613,  0.610364914
   3964,          -4.,   4.32415581,  0.616624832
   3965,          -4.,   4.14732265,  0.613152027
   3966,          -4.,   4.07189941,  0.606547117
   3967,          -4.,    4.0468936,  0.798389196
   3968,          -4.,   4.09528255,  0.807989597
   3969,          -4.,   4.15869141,  0.881956816
   3970,          -4.,   4.16854668,  0.941291809
   3971,          -4.,   4.32249737,  0.914364815
   3972,          -4.,   4.41231346,  0.907959461
   3973,          -4.,   4.31646681,  0.824416637
   3974,          -4.,   4.41146612,  0.813370228
   3975,          -4.,    4.0847373,  0.400811672
   3976,          -4.,   4.17018127,  0.402638197
   3977,          -4.,   4.25771236,  0.404257298
   3978,          -4.,   4.34738541,  0.404048204
   3979,          -4.,   4.43820286,  0.402210236
   3980,          -4.,   4.08876801,  0.299844742
   3981,          -4.,   4.17781925,  0.300663233
   3982,          -4.,   4.26763153,  0.301387787
   3983,          -4.,   4.35819292,   0.30135417
   3984,          -4.,   4.44915867,  0.300720453
   3985,          -4.,    4.0915761,  0.199545383
   3986,          -4.,   4.18312168,  0.200053453
   3987,          -4.,   4.27479887,  0.200416565
   3988,          -4.,   4.36645794,   0.20040369
   3989,          -4.,   4.45690346,  0.200158119
   3990,          -4.,   4.09309435, 0.0996911526
   3991,          -4.,   4.18605137, 0.0999364853
   3992,          -4.,   4.27888012,   0.10008812
   3993,          -4.,   4.36935902,  0.100122258
   3994,          -4.,   4.45970154,  0.100026608
   3995,          -4.,   4.05381393,   0.93972826
   3996,          -4.,    4.0398922,  0.936430931
   3997,          -4.,   4.02093029,   0.93302536
   3998,          -4.,   4.06514168,  0.975488663
   3999,          -4.,    4.0590167,  0.954113007
   4000,          -4.,   4.04302073,  0.977189064
   4001,          -4.,   4.02147913,  0.977454185
   4002,          -4.,   4.04070044,  0.955744743
   4003,          -4.,    4.0207777,  0.955220222
   4004,          -5.,   4.02295685,  0.909104168
   4005,          -5.,   4.04388142,  0.917153835
   4006,          -5.,   4.06160116,  0.929329336
   4007,          -5.,   4.07624245,  0.945445716
   4008,          -5.,   4.08884096,  0.970060945
   4009,          -5.,    4.5209322,  0.502946854
   4010,          -5.,   4.51361609,  0.605696201
   4011,          -5.,   4.50820541,   0.70750618
   4012,          -5.,   4.50572443,  0.807074547
   4013,          -5.,   4.50516891,  0.904250145
   4014,          -5.,   4.55097151, 0.0998277664
   4015,          -5.,   4.54866123,  0.199585915
   4016,          -5.,   4.54081678,  0.299471855
   4017,          -5.,   4.53028917,  0.400753021
   4018,          -5.,   4.42665768,  0.505270958
   4019,          -5.,   4.33587694,  0.508806229
   4020,          -5.,   4.24604797,  0.510056496
   4021,          -5.,   4.16042089,  0.505397975
   4022,          -5.,   4.07927752,  0.503786087
   4023,          -5.,   4.59962463,  0.902042389
   4024,          -5.,   4.69374275,  0.900639057
   4025,          -5.,   4.79379129,  0.900028229
   4026,          -5.,   4.89683104,  0.899857521
   4027,          -5.,    4.6011467,  0.803375721
   4028,          -5.,    4.6960125,  0.801039696
   4029,          -5.,   4.79560471,  0.800012112
   4030,          -5.,   4.89777946,  0.799719334
   4031,          -5.,   4.60377264,  0.703418255
   4032,          -5.,   4.69802999,  0.700642586
   4033,          -5.,   4.79840326,  0.699840546
   4034,          -5.,    4.8992219,  0.699540138
   4035,          -5.,   4.60770893,  0.602148056
   4036,          -5.,   4.70347404,  0.600103855
   4037,          -5.,    4.8021965,  0.599524498
   4038,          -5.,   4.90114498,   0.59932375
   4039,          -5.,   4.61392498,  0.500231743
   4040,          -5.,   4.71026516,  0.499489784
   4041,          -5.,   4.80682564,  0.499200821
   4042,          -5.,   4.90346098,  0.499132156
   4043,          -5.,    4.6239109,  0.399787426
   4044,          -5.,   4.71781826,  0.399107933
   4045,          -5.,   4.81191015,  0.399017811
   4046,          -5.,   4.90598297,  0.399044037
   4047,          -5.,   4.63290834,  0.299342155
   4048,          -5.,   4.72538471,   0.29897213
   4049,          -5.,   4.81695843,   0.29902029
   4050,          -5.,   4.90847015,  0.299099922
   4051,          -5.,   4.63939667,  0.199431345
   4052,          -5.,   4.73162651,  0.199156284
   4053,          -5.,    4.8212266,  0.199232101
   4054,          -5.,   4.91060448,  0.199310303
   4055,          -5.,     4.642519, 0.0997028351
   4056,          -5.,   4.73573494, 0.0995512009
   4057,          -5.,   4.82417583, 0.0995936394
   4058,          -5.,   4.91214752, 0.0996351242
   4059,          -5.,   4.20514107,  0.748736382
   4060,          -5.,   4.23070431,  0.622167587
   4061,          -5.,   4.31237507,   0.72554493
   4062,          -5.,   4.41263056,   0.71419239
   4063,          -5.,   4.06131363,  0.707167149
   4064,          -5.,   4.12709951,  0.719120979
   4065,          -5.,   4.13566732,  0.834037781
   4066,          -5.,   4.23874378,  0.925182819
   4067,          -5.,   4.22833729,  0.845075607
   4068,          -5.,   4.41888189,  0.610375881
   4069,          -5.,   4.32421875,   0.61664772
   4070,          -5.,   4.14740992,  0.613229752
   4071,          -5.,   4.07194948,  0.606642246
   4072,          -5.,   4.04711819,  0.798839569
   4073,          -5.,    4.0956645,  0.808294773
   4074,          -5.,   4.15909958,  0.882039547
   4075,          -5.,   4.16865253,  0.941366196
   4076,          -5.,   4.32292604,  0.914391518
   4077,          -5.,   4.41304731,  0.907996178
   4078,          -5.,   4.31657076,  0.824442863
   4079,          -5.,   4.41199303,  0.813426018
   4080,          -5.,   4.08473969,  0.400816917
   4081,          -5.,    4.1701889,  0.402645111
   4082,          -5.,   4.25772381,  0.404263496
   4083,          -5.,   4.34739542,  0.404052258
   4084,          -5.,   4.43820572,  0.402211189
   4085,          -5.,   4.08876896,  0.299846649
   4086,          -5.,   4.17782068,  0.300664902
   4087,          -5.,   4.26763391,  0.301389217
   4088,          -5.,    4.3581953,  0.301354885
   4089,          -5.,    4.4491601,  0.300720692
   4090,          -5.,   4.09157658,   0.19954586
   4091,          -5.,   4.18312263,  0.200054169
   4092,          -5.,   4.27479982,  0.200417519
   4093,          -5.,   4.36645889,  0.200404167
   4094,          -5.,   4.45690393,  0.200158119
   4095,          -5.,   4.09309435,  0.099691391
   4096,          -5.,   4.18605185, 0.0999364853
   4097,          -5.,   4.27888012,   0.10008812
   4098,          -5.,   4.36935949,  0.100122422
   4099,          -5.,   4.45952415,  0.100027084
   4100,          -5.,   4.05381393,   0.93972826
   4101,          -5.,    4.0398922,  0.936430931
   4102,          -5.,   4.02093029,   0.93302536
   4103,          -5.,   4.06514168,  0.975488663
   4104,          -5.,    4.0590167,  0.954113007
   4105,          -5.,   4.04302073,  0.977189064
   4106,          -5.,   4.02147913,  0.977454185
   4107,          -5.,   4.04070044,  0.955744743
   4108,          -5.,    4.0207777,  0.955220222
   4109,   -4.0999999,   4.91381073,           0.
   4110,   -4.0999999,   4.82578707,           0.
   4111,   -4.0999999,   4.73546553,           0.
   4112,   -4.0999999,   4.64397287,           0.
   4113,   -4.0999999,   4.55240965,           0.
   4114,   -4.0999999,   4.46086073,           0.
   4115,   -4.0999999,   4.36996222,           0.
   4116,   -4.0999999,   4.27966499,           0.
   4117,   -4.0999999,   4.18753386,           0.
   4118,   -4.0999999,   4.09371185,           0.
   4119,  -4.19999981,   4.91381073,           0.
   4120,  -4.19999981,   4.82578707,           0.
   4121,  -4.19999981,   4.73546553,           0.
   4122,  -4.19999981,   4.64397287,           0.
   4123,  -4.19999981,   4.55240965,           0.
   4124,  -4.19999981,   4.46086073,           0.
   4125,  -4.19999981,   4.36996222,           0.
   4126,  -4.19999981,   4.27966499,           0.
   4127,  -4.19999981,   4.18753386,           0.
   4128,  -4.19999981,   4.09371185,           0.
   4129,  -4.30000019,   4.91381073,           0.
   4130,  -4.30000019,   4.82578707,           0.
   4131,  -4.30000019,   4.73546553,           0.
   4132,  -4.30000019,   4.64397287,           0.
   4133,  -4.30000019,   4.55240965,           0.
   4134,  -4.30000019,   4.46086073,           0.
   4135,  -4.30000019,   4.36996222,           0.
   4136,  -4.30000019,   4.27966499,           0.
   4137,  -4.30000019,   4.18753386,           0.
   4138,  -4.30000019,   4.09371185,           0.
   4139,   -4.4000001,   4.91381073,           0.
   4140,   -4.4000001,   4.82578707,           0.
   4141,   -4.4000001,   4.73546553,           0.
   4142,   -4.4000001,   4.64397287,           0.
   4143,   -4.4000001,   4.55240965,           0.
   4144,   -4.4000001,   4.46086073,           0.
   4145,   -4.4000001,   4.36996222,           0.
   4146,   -4.4000001,   4.27966499,           0.
   4147,   -4.4000001,   4.18753386,           0.
   4148,   -4.4000001,   4.09371185,           0.
   4149,         -4.5,   4.91381073,           0.
   4150,         -4.5,   4.82578707,           0.
   4151,         -4.5,   4.73546553,           0.
   4152,         -4.5,   4.64397287,           0.
   4153,         -4.5,   4.55240965,           0.
   4154,         -4.5,   4.46086073,           0.
   4155,         -4.5,   4.36996222,           0.
   4156,         -4.5,   4.27966499,           0.
   4157,         -4.5,   4.18753386,           0.
   4158,         -4.5,   4.09371185,           0.
   4159,   -4.5999999,   4.91381073,           0.
   4160,   -4.5999999,   4.82578707,           0.
   4161,   -4.5999999,   4.73546553,           0.
   4162,   -4.5999999,   4.64397287,           0.
   4163,   -4.5999999,   4.55240965,           0.
   4164,   -4.5999999,   4.46086073,           0.
   4165,   -4.5999999,   4.36996222,           0.
   4166,   -4.5999999,   4.27966499,           0.
   4167,   -4.5999999,   4.18753386,           0.
   4168,   -4.5999999,   4.09371185,           0.
   4169,  -4.69999981,   4.91381073,           0.
   4170,  -4.69999981,   4.82578707,           0.
   4171,  -4.69999981,   4.73546553,           0.
   4172,  -4.69999981,   4.64397287,           0.
   4173,  -4.69999981,   4.55240965,           0.
   4174,  -4.69999981,   4.46086073,           0.
   4175,  -4.69999981,   4.36996222,           0.
   4176,  -4.69999981,   4.27966499,           0.
   4177,  -4.69999981,   4.18753386,           0.
   4178,  -4.69999981,   4.09371185,           0.
   4179,  -4.80000019,   4.91381073,           0.
   4180,  -4.80000019,   4.82578707,           0.
   4181,  -4.80000019,   4.73546553,           0.
   4182,  -4.80000019,   4.64397287,           0.
   4183,  -4.80000019,   4.55240965,           0.
   4184,  -4.80000019,   4.46086073,           0.
   4185,  -4.80000019,   4.36996222,           0.
   4186,  -4.80000019,   4.27966499,           0.
   4187,  -4.80000019,   4.18753386,           0.
   4188,  -4.80000019,   4.09371185,           0.
   4189,   -4.9000001,   4.91381073,           0.
   4190,   -4.9000001,   4.82578707,           0.
   4191,   -4.9000001,   4.73546553,           0.
   4192,   -4.9000001,   4.64397287,           0.
   4193,   -4.9000001,   4.55240965,           0.
   4194,   -4.9000001,   4.46086073,           0.
   4195,   -4.9000001,   4.36996222,           0.
   4196,   -4.9000001,   4.27966499,           0.
   4197,   -4.9000001,   4.18753386,           0.
   4198,   -4.9000001,   4.09371185,           0.
   4199,   -4.0999999,           5.,  0.899779499
   4200,   -4.0999999,           5.,  0.799583256
   4201,   -4.0999999,           5.,  0.699396074
   4202,   -4.0999999,           5.,  0.599217594
   4203,   -4.0999999,           5.,  0.499076724
   4204,   -4.0999999,           5.,  0.399024606
   4205,   -4.0999999,           5.,  0.299102724
   4206,   -4.0999999,           5.,  0.199316502
   4207,   -4.0999999,           5., 0.0996359214
   4208,  -4.19999981,           5.,  0.899779499
   4209,  -4.19999981,           5.,  0.799583256
   4210,  -4.19999981,           5.,  0.699396074
   4211,  -4.19999981,           5.,  0.599217594
   4212,  -4.19999981,           5.,  0.499076724
   4213,  -4.19999981,           5.,  0.399024606
   4214,  -4.19999981,           5.,  0.299102724
   4215,  -4.19999981,           5.,  0.199316502
   4216,  -4.19999981,           5., 0.0996359214
   4217,  -4.30000019,           5.,  0.899779499
   4218,  -4.30000019,           5.,  0.799583256
   4219,  -4.30000019,           5.,  0.699396074
   4220,  -4.30000019,           5.,  0.599217594
   4221,  -4.30000019,           5.,  0.499076724
   4222,  -4.30000019,           5.,  0.399024606
   4223,  -4.30000019,           5.,  0.299102724
   4224,  -4.30000019,           5.,  0.199316502
   4225,  -4.30000019,           5., 0.0996359214
   4226,   -4.4000001,           5.,  0.899779499
   4227,   -4.4000001,           5.,  0.799583256
   4228,   -4.4000001,           5.,  0.699396074
   4229,   -4.4000001,           5.,  0.599217594
   4230,   -4.4000001,           5.,  0.499076724
   4231,   -4.4000001,           5.,  0.399024606
   4232,   -4.4000001,           5.,  0.299102724
   4233,   -4.4000001,           5.,  0.199316502
   4234,   -4.4000001,           5., 0.0996359214
   4235,         -4.5,           5.,  0.899779499
   4236,         -4.5,           5.,  0.799583256
   4237,         -4.5,           5.,  0.699396074
   4238,         -4.5,           5.,  0.599217594
   4239,         -4.5,           5.,  0.499076724
   4240,         -4.5,           5.,  0.399024606
   4241,         -4.5,           5.,  0.299102724
   4242,         -4.5,           5.,  0.199316502
   4243,         -4.5,           5., 0.0996359214
   4244,   -4.5999999,           5.,  0.899779499
   4245,   -4.5999999,           5.,  0.799583256
   4246,   -4.5999999,           5.,  0.699396074
   4247,   -4.5999999,           5.,  0.599217594
   4248,   -4.5999999,           5.,  0.499076724
   4249,   -4.5999999,           5.,  0.399024606
   4250,   -4.5999999,           5.,  0.299102724
   4251,   -4.5999999,           5.,  0.199316502
   4252,   -4.5999999,           5., 0.0996359214
   4253,  -4.69999981,           5.,  0.899779499
   4254,  -4.69999981,           5.,  0.799583256
   4255,  -4.69999981,           5.,  0.699396074
   4256,  -4.69999981,           5.,  0.599217594
   4257,  -4.69999981,           5.,  0.499076724
   4258,  -4.69999981,           5.,  0.399024606
   4259,  -4.69999981,           5.,  0.299102724
   4260,  -4.69999981,           5.,  0.199316502
   4261,  -4.69999981,           5., 0.0996359214
   4262,  -4.80000019,           5.,  0.899779499
   4263,  -4.80000019,           5.,  0.799583256
   4264,  -4.80000019,           5.,  0.699396074
   4265,  -4.80000019,           5.,  0.599217594
   4266,  -4.80000019,           5.,  0.499076724
   4267,  -4.80000019,           5.,  0.399024606
   4268,  -4.80000019,           5.,  0.299102724
   4269,  -4.80000019,           5.,  0.199316502
   4270,  -4.80000019,           5., 0.0996359214
   4271,   -4.9000001,           5.,  0.899779499
   4272,   -4.9000001,           5.,  0.799583256
   4273,   -4.9000001,           5.,  0.699396074
   4274,   -4.9000001,           5.,  0.599217594
   4275,   -4.9000001,           5.,  0.499076724
   4276,   -4.9000001,           5.,  0.399024606
   4277,   -4.9000001,           5.,  0.299102724
   4278,   -4.9000001,           5.,  0.199316502
   4279,   -4.9000001,           5., 0.0996359214
   4280,   -4.0999999,           4., 0.0994525626
   4281,   -4.0999999,           4.,  0.199098632
   4282,   -4.0999999,           4.,  0.299182981
   4283,   -4.0999999,           4.,  0.399915397
   4284,   -4.0999999,           4.,  0.501552284
   4285,   -4.0999999,           4.,  0.603811979
   4286,   -4.0999999,           4.,  0.705083013
   4287,   -4.0999999,           4.,  0.804041386
   4288,   -4.0999999,           4.,      0.90625
   4289,   -4.0999999,           4.,  0.931131601
   4290,   -4.0999999,           4.,  0.954231679
   4291,   -4.0999999,           4.,  0.977053523
   4292,  -4.19999981,           4., 0.0994525626
   4293,  -4.19999981,           4.,  0.199098632
   4294,  -4.19999981,           4.,  0.299182981
   4295,  -4.19999981,           4.,  0.399915397
   4296,  -4.19999981,           4.,  0.501552284
   4297,  -4.19999981,           4.,  0.603811979
   4298,  -4.19999981,           4.,  0.705083013
   4299,  -4.19999981,           4.,  0.804041386
   4300,  -4.19999981,           4.,      0.90625
   4301,  -4.19999981,           4.,  0.931131601
   4302,  -4.19999981,           4.,  0.954231679
   4303,  -4.19999981,           4.,  0.977053523
   4304,  -4.30000019,           4., 0.0994525626
   4305,  -4.30000019,           4.,  0.199098632
   4306,  -4.30000019,           4.,  0.299182981
   4307,  -4.30000019,           4.,  0.399915397
   4308,  -4.30000019,           4.,  0.501552284
   4309,  -4.30000019,           4.,  0.603811979
   4310,  -4.30000019,           4.,  0.705083013
   4311,  -4.30000019,           4.,  0.804041386
   4312,  -4.30000019,           4.,      0.90625
   4313,  -4.30000019,           4.,  0.931131601
   4314,  -4.30000019,           4.,  0.954231679
   4315,  -4.30000019,           4.,  0.977053523
   4316,   -4.4000001,           4., 0.0994525626
   4317,   -4.4000001,           4.,  0.199098632
   4318,   -4.4000001,           4.,  0.299182981
   4319,   -4.4000001,           4.,  0.399915397
   4320,   -4.4000001,           4.,  0.501552284
   4321,   -4.4000001,           4.,  0.603811979
   4322,   -4.4000001,           4.,  0.705083013
   4323,   -4.4000001,           4.,  0.804041386
   4324,   -4.4000001,           4.,      0.90625
   4325,   -4.4000001,           4.,  0.931131601
   4326,   -4.4000001,           4.,  0.954231679
   4327,   -4.4000001,           4.,  0.977053523
   4328,         -4.5,           4., 0.0994525626
   4329,         -4.5,           4.,  0.199098632
   4330,         -4.5,           4.,  0.299182981
   4331,         -4.5,           4.,  0.399915397
   4332,         -4.5,           4.,  0.501552284
   4333,         -4.5,           4.,  0.603811979
   4334,         -4.5,           4.,  0.705083013
   4335,         -4.5,           4.,  0.804041386
   4336,         -4.5,           4.,      0.90625
   4337,         -4.5,           4.,  0.931131601
   4338,         -4.5,           4.,  0.954231679
   4339,         -4.5,           4.,  0.977053523
   4340,   -4.5999999,           4., 0.0994525626
   4341,   -4.5999999,           4.,  0.199098632
   4342,   -4.5999999,           4.,  0.299182981
   4343,   -4.5999999,           4.,  0.399915397
   4344,   -4.5999999,           4.,  0.501552284
   4345,   -4.5999999,           4.,  0.603811979
   4346,   -4.5999999,           4.,  0.705083013
   4347,   -4.5999999,           4.,  0.804041386
   4348,   -4.5999999,           4.,      0.90625
   4349,   -4.5999999,           4.,  0.931131601
   4350,   -4.5999999,           4.,  0.954231679
   4351,   -4.5999999,           4.,  0.977053523
   4352,  -4.69999981,           4., 0.0994525626
   4353,  -4.69999981,           4.,  0.199098632
   4354,  -4.69999981,           4.,  0.299182981
   4355,  -4.69999981,           4.,  0.399915397
   4356,  -4.69999981,           4.,  0.501552284
   4357,  -4.69999981,           4.,  0.603811979
   4358,  -4.69999981,           4.,  0.705083013
   4359,  -4.69999981,           4.,  0.804041386
   4360,  -4.69999981,           4.,      0.90625
   4361,  -4.69999981,           4.,  0.931131601
   4362,  -4.69999981,           4.,  0.954231679
   4363,  -4.69999981,           4.,  0.977053523
   4364,  -4.80000019,           4., 0.0994525626
   4365,  -4.80000019,           4.,  0.199098632
   4366,  -4.80000019,           4.,  0.299182981
   4367,  -4.80000019,           4.,  0.399915397
   4368,  -4.80000019,           4.,  0.501552284
   4369,  -4.80000019,           4.,  0.603811979
   4370,  -4.80000019,           4.,  0.705083013
   4371,  -4.80000019,           4.,  0.804041386
   4372,  -4.80000019,           4.,      0.90625
   4373,  -4.80000019,           4.,  0.931131601
   4374,  -4.80000019,           4.,  0.954231679
   4375,  -4.80000019,           4.,  0.977053523
   4376,   -4.9000001,           4., 0.0994525626
   4377,   -4.9000001,           4.,  0.199098632
   4378,   -4.9000001,           4.,  0.299182981
   4379,   -4.9000001,           4.,  0.399915397
   4380,   -4.9000001,           4.,  0.501552284
   4381,   -4.9000001,           4.,  0.603811979
   4382,   -4.9000001,           4.,  0.705083013
   4383,   -4.9000001,           4.,  0.804041386
   4384,   -4.9000001,           4.,      0.90625
   4385,   -4.9000001,           4.,  0.931131601
   4386,   -4.9000001,           4.,  0.954231679
   4387,   -4.9000001,           4.,  0.977053523
   4388,          -3.,   4.52051783,  0.502833366
   4389,          -3.,   4.51282406,  0.605522156
   4390,          -3.,   4.50688982,   0.70730114
   4391,          -3.,   4.50412703,  0.806916237
   4392,          -3.,   4.50335503,  0.904162884
   4393,          -3.,   4.55155897, 0.0998249054
   4394,          -3.,   4.54866076,  0.199585438
   4395,          -3.,   4.54081631,  0.299471855
   4396,          -3.,   4.53028631,  0.400753021
   4397,          -3.,   4.42663765,  0.505265236
   4398,          -3.,   4.33582211,  0.508785248
   4399,          -3.,   4.24597406,  0.510020256
   4400,          -3.,    4.1603837,  0.505365849
   4401,          -3.,   4.07924223,  0.503712177
   4402,          -3.,   4.59845638,  0.901982307
   4403,          -3.,   4.69373417,  0.900638103
   4404,          -3.,   4.79378939,  0.900028229
   4405,          -3.,   4.89683008,  0.899857521
   4406,          -3.,   4.60018826,  0.803275108
   4407,          -3.,   4.69600439,  0.801037788
   4408,          -3.,    4.7956028,  0.800011635
   4409,          -3.,   4.89777899,  0.799719334
   4410,          -3.,   4.60319996,   0.70334053
   4411,          -3.,    4.6980257,  0.700641632
   4412,          -3.,   4.79840136,  0.699840069
   4413,          -3.,   4.89922142,  0.699540138
   4414,          -3.,   4.60769653,  0.602145195
   4415,          -3.,   4.70347166,  0.600103855
   4416,          -3.,   4.80219507,  0.599524498
   4417,          -3.,    4.9011445,   0.59932375
   4418,          -3.,    4.6139226,  0.500231743
   4419,          -3.,   4.71026421,  0.499489784
   4420,          -3.,   4.80682468,  0.499200821
   4421,          -3.,    4.9034605,  0.499132156
   4422,          -3.,   4.62390947,  0.399787426
   4423,          -3.,   4.71781778,  0.399107933
   4424,          -3.,   4.81191015,  0.399017811
   4425,          -3.,   4.90598297,  0.399044037
   4426,          -3.,   4.63290787,  0.299342155
   4427,          -3.,   4.72538471,   0.29897213
   4428,          -3.,   4.81695843,   0.29902029
   4429,          -3.,   4.90847015,  0.299099922
   4430,          -3.,   4.63957548,  0.199424163
   4431,          -3.,   4.73162651,  0.199156284
   4432,          -3.,    4.8212266,  0.199232101
   4433,          -3.,   4.91060448,  0.199310303
   4434,          -3.,   4.64293623, 0.0996999741
   4435,          -3.,   4.73573494, 0.0995512009
   4436,          -3.,   4.82417583, 0.0995936394
   4437,          -3.,   4.91214752, 0.0996351242
   4438,          -3.,   4.20474386,   0.74862051
   4439,          -3.,   4.23051167,  0.622079849
   4440,          -3.,    4.3121829,   0.72549057
   4441,          -3.,   4.41168785,  0.714026451
   4442,          -3.,   4.06109285,  0.706742287
   4443,          -3.,   4.12671995,  0.718799591
   4444,          -3.,   4.13468456,  0.833964348
   4445,          -3.,   4.23852539,  0.925112724
   4446,          -3.,   4.22793913,  0.844974041
   4447,          -3.,   4.41881037,  0.610353947
   4448,          -3.,   4.32409286,  0.616601944
   4449,          -3.,   4.14723587,  0.613074303
   4450,          -3.,   4.07184935,  0.606451988
   4451,          -3.,   4.04666901,  0.797938824
   4452,          -3.,   4.09490108,  0.807684422
   4453,          -3.,   4.15828323,  0.881874084
   4454,          -3.,   4.16844082,  0.941217422
   4455,          -3.,   4.32206917,  0.914338112
   4456,          -3.,   4.41157961,  0.907922745
   4457,          -3.,   4.31636286,  0.824390411
   4458,          -3.,   4.41093922,  0.813314438
   4459,          -3.,   4.08473492,  0.400806427
   4460,          -3.,   4.17017365,  0.402631283
   4461,          -3.,   4.25770044,  0.404251099
   4462,          -3.,   4.34737587,  0.404044151
   4463,          -3.,   4.43819952,  0.402209282
   4464,          -3.,   4.08876705,  0.299842834
   4465,          -3.,   4.17781782,  0.300661564
   4466,          -3.,   4.26762867,  0.301386356
   4467,          -3.,   4.35819054,  0.301353455
   4468,          -3.,   4.44915724,  0.300720215
   4469,          -3.,   4.09157562,  0.199544907
   4470,          -3.,    4.1831212,  0.200052738
   4471,          -3.,   4.27479792,  0.200415611
   4472,          -3.,   4.36645699,  0.200403214
   4473,          -3.,    4.4569025,  0.200158119
   4474,          -3.,   4.09309435, 0.0996909142
   4475,          -3.,   4.18605137, 0.0999364853
   4476,          -3.,   4.27887964,   0.10008812
   4477,          -3.,   4.36935854,  0.100122102
   4478,          -3.,   4.45987892,  0.100026131
   4479,   -3.9000001,           4.,  0.804035902
   4480,   -3.9000001,           4.,  0.704977512
   4481,   -3.9000001,           4.,  0.603762865
   4482,   -3.9000001,           4.,  0.501531661
   4483,   -3.9000001,           4.,  0.399918109
   4484,   -3.9000001,           4.,  0.299184978
   4485,   -3.9000001,           4.,   0.19909966
   4486,   -3.9000001,           4., 0.0994530693
   4487,  -3.79999995,           4.,  0.804035902
   4488,  -3.79999995,           4.,  0.704977512
   4489,  -3.79999995,           4.,  0.603762865
   4490,  -3.79999995,           4.,  0.501531661
   4491,  -3.79999995,           4.,  0.399918109
   4492,  -3.79999995,           4.,  0.299184978
   4493,  -3.79999995,           4.,   0.19909966
   4494,  -3.79999995,           4., 0.0994530693
   4495,  -3.70000005,           4.,  0.804035902
   4496,  -3.70000005,           4.,  0.704977512
   4497,  -3.70000005,           4.,  0.603762865
   4498,  -3.70000005,           4.,  0.501531661
   4499,  -3.70000005,           4.,  0.399918109
   4500,  -3.70000005,           4.,  0.299184978
   4501,  -3.70000005,           4.,   0.19909966
   4502,  -3.70000005,           4., 0.0994530693
   4503,   -3.5999999,           4.,  0.804035902
   4504,   -3.5999999,           4.,  0.704977512
   4505,   -3.5999999,           4.,  0.603762865
   4506,   -3.5999999,           4.,  0.501531661
   4507,   -3.5999999,           4.,  0.399918109
   4508,   -3.5999999,           4.,  0.299184978
   4509,   -3.5999999,           4.,   0.19909966
   4510,   -3.5999999,           4., 0.0994530693
   4511,         -3.5,           4.,  0.804035902
   4512,         -3.5,           4.,  0.704977512
   4513,         -3.5,           4.,  0.603762865
   4514,         -3.5,           4.,  0.501531661
   4515,         -3.5,           4.,  0.399918109
   4516,         -3.5,           4.,  0.299184978
   4517,         -3.5,           4.,   0.19909966
   4518,         -3.5,           4., 0.0994530693
   4519,   -3.4000001,           4.,  0.804035902
   4520,   -3.4000001,           4.,  0.704977512
   4521,   -3.4000001,           4.,  0.603762865
   4522,   -3.4000001,           4.,  0.501531661
   4523,   -3.4000001,           4.,  0.399918109
   4524,   -3.4000001,           4.,  0.299184978
   4525,   -3.4000001,           4.,   0.19909966
   4526,   -3.4000001,           4., 0.0994530693
   4527,  -3.29999995,           4.,  0.804035902
   4528,  -3.29999995,           4.,  0.704977512
   4529,  -3.29999995,           4.,  0.603762865
   4530,  -3.29999995,           4.,  0.501531661
   4531,  -3.29999995,           4.,  0.399918109
   4532,  -3.29999995,           4.,  0.299184978
   4533,  -3.29999995,           4.,   0.19909966
   4534,  -3.29999995,           4., 0.0994530693
   4535,  -3.20000005,           4.,  0.804035902
   4536,  -3.20000005,           4.,  0.704977512
   4537,  -3.20000005,           4.,  0.603762865
   4538,  -3.20000005,           4.,  0.501531661
   4539,  -3.20000005,           4.,  0.399918109
   4540,  -3.20000005,           4.,  0.299184978
   4541,  -3.20000005,           4.,   0.19909966
   4542,  -3.20000005,           4., 0.0994530693
   4543,   -3.0999999,           4.,  0.804035902
   4544,   -3.0999999,           4.,  0.704977512
   4545,   -3.0999999,           4.,  0.603762865
   4546,   -3.0999999,           4.,  0.501531661
   4547,   -3.0999999,           4.,  0.399918109
   4548,   -3.0999999,           4.,  0.299184978
   4549,   -3.0999999,           4.,   0.19909966
   4550,   -3.0999999,           4., 0.0994530693
   4551,   -3.9000001,   4.08885431,  0.970100522
   4552,   -3.9000001,   4.07607841,  0.945217609
   4553,   -3.9000001,     4.059659,  0.927682281
   4554,   -3.9000001,   4.04139137,   0.91588223
   4555,   -3.9000001,   4.02111483,  0.908658803
   4556,  -3.79999995,   4.08885431,  0.970100522
   4557,  -3.79999995,   4.07607841,  0.945217609
   4558,  -3.79999995,     4.059659,  0.927682281
   4559,  -3.79999995,   4.04139137,   0.91588223
   4560,  -3.79999995,   4.02111483,  0.908658803
   4561,  -3.70000005,   4.08885431,  0.970100522
   4562,  -3.70000005,   4.07607841,  0.945217609
   4563,  -3.70000005,     4.059659,  0.927682281
   4564,  -3.70000005,   4.04139137,   0.91588223
   4565,  -3.70000005,   4.02111483,  0.908658803
   4566,   -3.5999999,   4.08885431,  0.970100522
   4567,   -3.5999999,   4.07607841,  0.945217609
   4568,   -3.5999999,     4.059659,  0.927682281
   4569,   -3.5999999,   4.04139137,   0.91588223
   4570,   -3.5999999,   4.02111483,  0.908658803
   4571,         -3.5,   4.08885431,  0.970100522
   4572,         -3.5,   4.07607841,  0.945217609
   4573,         -3.5,     4.059659,  0.927682281
   4574,         -3.5,   4.04139137,   0.91588223
   4575,         -3.5,   4.02111483,  0.908658803
   4576,   -3.4000001,   4.08885431,  0.970100522
   4577,   -3.4000001,   4.07607841,  0.945217609
   4578,   -3.4000001,     4.059659,  0.927682281
   4579,   -3.4000001,   4.04139137,   0.91588223
   4580,   -3.4000001,   4.02111483,  0.908658803
   4581,  -3.29999995,   4.08885431,  0.970100522
   4582,  -3.29999995,   4.07607841,  0.945217609
   4583,  -3.29999995,     4.059659,  0.927682281
   4584,  -3.29999995,   4.04139137,   0.91588223
   4585,  -3.29999995,   4.02111483,  0.908658803
   4586,  -3.20000005,   4.08885431,  0.970100522
   4587,  -3.20000005,   4.07607841,  0.945217609
   4588,  -3.20000005,     4.059659,  0.927682281
   4589,  -3.20000005,   4.04139137,   0.91588223
   4590,  -3.20000005,   4.02111483,  0.908658803
   4591,   -3.0999999,   4.08885431,  0.970100522
   4592,   -3.0999999,   4.07607841,  0.945217609
   4593,   -3.0999999,     4.059659,  0.927682281
   4594,   -3.0999999,   4.04139137,   0.91588223
   4595,   -3.0999999,   4.02111483,  0.908658803
   4596,   -3.9000001,   4.09371185,           0.
   4597,   -3.9000001,   4.18753386,           0.
   4598,   -3.9000001,   4.27966499,           0.
   4599,   -3.9000001,   4.37029219,           0.
   4600,   -3.9000001,   4.46169519,           0.
   4601,   -3.9000001,   4.55351686,           0.
   4602,   -3.9000001,   4.64487505,           0.
   4603,   -3.9000001,   4.73587942,           0.
   4604,   -3.9000001,   4.82578707,           0.
   4605,   -3.9000001,   4.91381073,           0.
   4606,  -3.79999995,   4.09371185,           0.
   4607,  -3.79999995,   4.18753386,           0.
   4608,  -3.79999995,   4.27966499,           0.
   4609,  -3.79999995,   4.37029219,           0.
   4610,  -3.79999995,   4.46169519,           0.
   4611,  -3.79999995,   4.55351686,           0.
   4612,  -3.79999995,   4.64487505,           0.
   4613,  -3.79999995,   4.73587942,           0.
   4614,  -3.79999995,   4.82578707,           0.
   4615,  -3.79999995,   4.91381073,           0.
   4616,  -3.70000005,   4.09371185,           0.
   4617,  -3.70000005,   4.18753386,           0.
   4618,  -3.70000005,   4.27966499,           0.
   4619,  -3.70000005,   4.37029219,           0.
   4620,  -3.70000005,   4.46169519,           0.
   4621,  -3.70000005,   4.55351686,           0.
   4622,  -3.70000005,   4.64487505,           0.
   4623,  -3.70000005,   4.73587942,           0.
   4624,  -3.70000005,   4.82578707,           0.
   4625,  -3.70000005,   4.91381073,           0.
   4626,   -3.5999999,   4.09371185,           0.
   4627,   -3.5999999,   4.18753386,           0.
   4628,   -3.5999999,   4.27966499,           0.
   4629,   -3.5999999,   4.37029219,           0.
   4630,   -3.5999999,   4.46169519,           0.
   4631,   -3.5999999,   4.55351686,           0.
   4632,   -3.5999999,   4.64487505,           0.
   4633,   -3.5999999,   4.73587942,           0.
   4634,   -3.5999999,   4.82578707,           0.
   4635,   -3.5999999,   4.91381073,           0.
   4636,         -3.5,   4.09371185,           0.
   4637,         -3.5,   4.18753386,           0.
   4638,         -3.5,   4.27966499,           0.
   4639,         -3.5,   4.37029219,           0.
   4640,         -3.5,   4.46169519,           0.
   4641,         -3.5,   4.55351686,           0.
   4642,         -3.5,   4.64487505,           0.
   4643,         -3.5,   4.73587942,           0.
   4644,         -3.5,   4.82578707,           0.
   4645,         -3.5,   4.91381073,           0.
   4646,   -3.4000001,   4.09371185,           0.
   4647,   -3.4000001,   4.18753386,           0.
   4648,   -3.4000001,   4.27966499,           0.
   4649,   -3.4000001,   4.37029219,           0.
   4650,   -3.4000001,   4.46169519,           0.
   4651,   -3.4000001,   4.55351686,           0.
   4652,   -3.4000001,   4.64487505,           0.
   4653,   -3.4000001,   4.73587942,           0.
   4654,   -3.4000001,   4.82578707,           0.
   4655,   -3.4000001,   4.91381073,           0.
   4656,  -3.29999995,   4.09371185,           0.
   4657,  -3.29999995,   4.18753386,           0.
   4658,  -3.29999995,   4.27966499,           0.
   4659,  -3.29999995,   4.37029219,           0.
   4660,  -3.29999995,   4.46169519,           0.
   4661,  -3.29999995,   4.55351686,           0.
   4662,  -3.29999995,   4.64487505,           0.
   4663,  -3.29999995,   4.73587942,           0.
   4664,  -3.29999995,   4.82578707,           0.
   4665,  -3.29999995,   4.91381073,           0.
   4666,  -3.20000005,   4.09371185,           0.
   4667,  -3.20000005,   4.18753386,           0.
   4668,  -3.20000005,   4.27966499,           0.
   4669,  -3.20000005,   4.37029219,           0.
   4670,  -3.20000005,   4.46169519,           0.
   4671,  -3.20000005,   4.55351686,           0.
   4672,  -3.20000005,   4.64487505,           0.
   4673,  -3.20000005,   4.73587942,           0.
   4674,  -3.20000005,   4.82578707,           0.
   4675,  -3.20000005,   4.91381073,           0.
   4676,   -3.0999999,   4.09371185,           0.
   4677,   -3.0999999,   4.18753386,           0.
   4678,   -3.0999999,   4.27966499,           0.
   4679,   -3.0999999,   4.37029219,           0.
   4680,   -3.0999999,   4.46169519,           0.
   4681,   -3.0999999,   4.55351686,           0.
   4682,   -3.0999999,   4.64487505,           0.
   4683,   -3.0999999,   4.73587942,           0.
   4684,   -3.0999999,   4.82578707,           0.
   4685,   -3.0999999,   4.91381073,           0.
   4686,   -3.9000001,   4.89500761,           1.
   4687,   -3.9000001,   4.79059219,           1.
   4688,   -3.9000001,   4.69113541,           1.
   4689,   -3.9000001,   4.59359217,           1.
   4690,   -3.9000001,   4.49858522,           1.
   4691,   -3.9000001,    4.4078455,           1.
   4692,   -3.9000001,    4.3212862,           1.
   4693,   -3.9000001,   4.23900032,           1.
   4694,   -3.9000001,   4.16604328,           1.
   4695,  -3.79999995,   4.89500761,           1.
   4696,  -3.79999995,   4.79059219,           1.
   4697,  -3.79999995,   4.69113541,           1.
   4698,  -3.79999995,   4.59359217,           1.
   4699,  -3.79999995,   4.49858522,           1.
   4700,  -3.79999995,    4.4078455,           1.
   4701,  -3.79999995,    4.3212862,           1.
   4702,  -3.79999995,   4.23900032,           1.
   4703,  -3.79999995,   4.16604328,           1.
   4704,  -3.70000005,   4.89500761,           1.
   4705,  -3.70000005,   4.79059219,           1.
   4706,  -3.70000005,   4.69113541,           1.
   4707,  -3.70000005,   4.59359217,           1.
   4708,  -3.70000005,   4.49858522,           1.
   4709,  -3.70000005,    4.4078455,           1.
   4710,  -3.70000005,    4.3212862,           1.
   4711,  -3.70000005,   4.23900032,           1.
   4712,  -3.70000005,   4.16604328,           1.
   4713,   -3.5999999,   4.89500761,           1.
   4714,   -3.5999999,   4.79059219,           1.
   4715,   -3.5999999,   4.69113541,           1.
   4716,   -3.5999999,   4.59359217,           1.
   4717,   -3.5999999,   4.49858522,           1.
   4718,   -3.5999999,    4.4078455,           1.
   4719,   -3.5999999,    4.3212862,           1.
   4720,   -3.5999999,   4.23900032,           1.
   4721,   -3.5999999,   4.16604328,           1.
   4722,         -3.5,   4.89500761,           1.
   4723,         -3.5,   4.79059219,           1.
   4724,         -3.5,   4.69113541,           1.
   4725,         -3.5,   4.59359217,           1.
   4726,         -3.5,   4.49858522,           1.
   4727,         -3.5,    4.4078455,           1.
   4728,         -3.5,    4.3212862,           1.
   4729,         -3.5,   4.23900032,           1.
   4730,         -3.5,   4.16604328,           1.
   4731,   -3.4000001,   4.89500761,           1.
   4732,   -3.4000001,   4.79059219,           1.
   4733,   -3.4000001,   4.69113541,           1.
   4734,   -3.4000001,   4.59359217,           1.
   4735,   -3.4000001,   4.49858522,           1.
   4736,   -3.4000001,    4.4078455,           1.
   4737,   -3.4000001,    4.3212862,           1.
   4738,   -3.4000001,   4.23900032,           1.
   4739,   -3.4000001,   4.16604328,           1.
   4740,  -3.29999995,   4.89500761,           1.
   4741,  -3.29999995,   4.79059219,           1.
   4742,  -3.29999995,   4.69113541,           1.
   4743,  -3.29999995,   4.59359217,           1.
   4744,  -3.29999995,   4.49858522,           1.
   4745,  -3.29999995,    4.4078455,           1.
   4746,  -3.29999995,    4.3212862,           1.
   4747,  -3.29999995,   4.23900032,           1.
   4748,  -3.29999995,   4.16604328,           1.
   4749,  -3.20000005,   4.89500761,           1.
   4750,  -3.20000005,   4.79059219,           1.
   4751,  -3.20000005,   4.69113541,           1.
   4752,  -3.20000005,   4.59359217,           1.
   4753,  -3.20000005,   4.49858522,           1.
   4754,  -3.20000005,    4.4078455,           1.
   4755,  -3.20000005,    4.3212862,           1.
   4756,  -3.20000005,   4.23900032,           1.
   4757,  -3.20000005,   4.16604328,           1.
   4758,   -3.0999999,   4.89500761,           1.
   4759,   -3.0999999,   4.79059219,           1.
   4760,   -3.0999999,   4.69113541,           1.
   4761,   -3.0999999,   4.59359217,           1.
   4762,   -3.0999999,   4.49858522,           1.
   4763,   -3.0999999,    4.4078455,           1.
   4764,   -3.0999999,    4.3212862,           1.
   4765,   -3.0999999,   4.23900032,           1.
   4766,   -3.0999999,   4.16604328,           1.
   4767,   -3.9000001,           5., 0.0996359214
   4768,   -3.9000001,           5.,  0.199316502
   4769,   -3.9000001,           5.,  0.299102724
   4770,   -3.9000001,           5.,  0.399024606
   4771,   -3.9000001,           5.,  0.499076724
   4772,   -3.9000001,           5.,  0.599217594
   4773,   -3.9000001,           5.,  0.699396074
   4774,   -3.9000001,           5.,  0.799583256
   4775,   -3.9000001,           5.,  0.899779499
   4776,  -3.79999995,           5., 0.0996359214
   4777,  -3.79999995,           5.,  0.199316502
   4778,  -3.79999995,           5.,  0.299102724
   4779,  -3.79999995,           5.,  0.399024606
   4780,  -3.79999995,           5.,  0.499076724
   4781,  -3.79999995,           5.,  0.599217594
   4782,  -3.79999995,           5.,  0.699396074
   4783,  -3.79999995,           5.,  0.799583256
   4784,  -3.79999995,           5.,  0.899779499
   4785,  -3.70000005,           5., 0.0996359214
   4786,  -3.70000005,           5.,  0.199316502
   4787,  -3.70000005,           5.,  0.299102724
   4788,  -3.70000005,           5.,  0.399024606
   4789,  -3.70000005,           5.,  0.499076724
   4790,  -3.70000005,           5.,  0.599217594
   4791,  -3.70000005,           5.,  0.699396074
   4792,  -3.70000005,           5.,  0.799583256
   4793,  -3.70000005,           5.,  0.899779499
   4794,   -3.5999999,           5., 0.0996359214
   4795,   -3.5999999,           5.,  0.199316502
   4796,   -3.5999999,           5.,  0.299102724
   4797,   -3.5999999,           5.,  0.399024606
   4798,   -3.5999999,           5.,  0.499076724
   4799,   -3.5999999,           5.,  0.599217594
   4800,   -3.5999999,           5.,  0.699396074
   4801,   -3.5999999,           5.,  0.799583256
   4802,   -3.5999999,           5.,  0.899779499
   4803,         -3.5,           5., 0.0996359214
   4804,         -3.5,           5.,  0.199316502
   4805,         -3.5,           5.,  0.299102724
   4806,         -3.5,           5.,  0.399024606
   4807,         -3.5,           5.,  0.499076724
   4808,         -3.5,           5.,  0.599217594
   4809,         -3.5,           5.,  0.699396074
   4810,         -3.5,           5.,  0.799583256
   4811,         -3.5,           5.,  0.899779499
   4812,   -3.4000001,           5., 0.0996359214
   4813,   -3.4000001,           5.,  0.199316502
   4814,   -3.4000001,           5.,  0.299102724
   4815,   -3.4000001,           5.,  0.399024606
   4816,   -3.4000001,           5.,  0.499076724
   4817,   -3.4000001,           5.,  0.599217594
   4818,   -3.4000001,           5.,  0.699396074
   4819,   -3.4000001,           5.,  0.799583256
   4820,   -3.4000001,           5.,  0.899779499
   4821,  -3.29999995,           5., 0.0996359214
   4822,  -3.29999995,           5.,  0.199316502
   4823,  -3.29999995,           5.,  0.299102724
   4824,  -3.29999995,           5.,  0.399024606
   4825,  -3.29999995,           5.,  0.499076724
   4826,  -3.29999995,           5.,  0.599217594
   4827,  -3.29999995,           5.,  0.699396074
   4828,  -3.29999995,           5.,  0.799583256
   4829,  -3.29999995,           5.,  0.899779499
   4830,  -3.20000005,           5., 0.0996359214
   4831,  -3.20000005,           5.,  0.199316502
   4832,  -3.20000005,           5.,  0.299102724
   4833,  -3.20000005,           5.,  0.399024606
   4834,  -3.20000005,           5.,  0.499076724
   4835,  -3.20000005,           5.,  0.599217594
   4836,  -3.20000005,           5.,  0.699396074
   4837,  -3.20000005,           5.,  0.799583256
   4838,  -3.20000005,           5.,  0.899779499
   4839,   -3.0999999,           5., 0.0996359214
   4840,   -3.0999999,           5.,  0.199316502
   4841,   -3.0999999,           5.,  0.299102724
   4842,   -3.0999999,           5.,  0.399024606
   4843,   -3.0999999,           5.,  0.499076724
   4844,   -3.0999999,           5.,  0.599217594
   4845,   -3.0999999,           5.,  0.699396074
   4846,   -3.0999999,           5.,  0.799583256
   4847,   -3.0999999,           5.,  0.899779499
   4848,          -3.,   4.47165203,   2.57332993
   4849,          -3.,   4.46990156,   2.47326231
   4850,          -3.,   4.12060261,   2.59160662
   4851,          -3.,   4.24234152,   2.58111525
   4852,          -3.,   4.35901642,   2.57463264
   4853,          -3.,   4.47151947,   2.37197542
   4854,          -3.,   4.47776985,   2.27426624
   4855,          -3.,   4.48302841,   2.18039131
   4856,          -3.,   4.48947859,   2.08884144
   4857,          -3.,   4.48853302,   2.92234421
   4858,          -3.,   4.48521757,   2.84283829
   4859,          -3.,   4.48096037,   2.75978374
   4860,          -3.,   4.47530079,   2.66881609
   4861,          -3.,   4.89689636,   2.48534966
   4862,          -3.,   4.79277754,   2.48387337
   4863,          -3.,   4.68711853,   2.48100662
   4864,          -3.,   4.57967424,   2.47726345
   4865,          -3.,   4.22276926,   2.32906294
   4866,          -3.,   4.23471737,   2.46384621
   4867,          -3.,   4.10337067,    2.3583293
   4868,          -3.,   4.35759068,   2.35962343
   4869,          -3.,    4.3064909,   2.07191753
   4870,          -3.,   4.29465675,   2.14638901
   4871,          -3.,   4.27024508,   2.22783041
   4872,          -3.,   4.09708071,   2.16432714
   4873,          -3.,   4.14662552,   2.23335886
   4874,          -3.,   4.11475611,   2.47271967
   4875,          -3.,   4.35530663,   2.46784115
   4876,          -3.,   4.37286377,    2.2570796
   4877,          -3.,   4.38618088,   2.16644478
   4878,          -3.,   4.39503574,   2.08180904
   4879,          -3.,   4.23064518,   2.05883694
   4880,          -3.,   4.16519594,   2.04505587
   4881,          -3.,   4.21724558,     2.118083
   4882,          -3.,   4.15284348,   2.08906746
   4883,          -3.,   4.19120741,   2.17751598
   4884,          -3.,    4.1308527,   2.13054371
   4885,          -3.,     4.051929,    2.1842823
   4886,          -3.,   4.07548141,   2.26188803
   4887,          -3.,   4.12453175,   2.72141027
   4888,          -3.,   4.25297832,    2.6913352
   4889,          -3.,   4.36628675,   2.67543936
   4890,          -3.,   4.06739664,   2.80922127
   4891,          -3.,   4.22472429,   2.94021702
   4892,          -3.,   4.20990801,   2.87759304
   4893,          -3.,   4.18143988,   2.80762672
   4894,          -3.,   4.11526489,   2.84869623
   4895,          -3.,   4.14381599,   2.90092134
   4896,          -3.,   4.15978718,   2.95098209
   4897,          -3.,    4.3032856,   2.93200445
   4898,          -3.,   4.39300776,   2.92614245
   4899,          -3.,   4.29371548,   2.86080408
   4900,          -3.,   4.38735104,   2.84922028
   4901,          -3.,   4.27649164,   2.78211975
   4902,          -3.,   4.37785196,    2.7669735
   4903,          -3.,   4.89753008,     2.578866
   4904,          -3.,   4.79292727,   2.57642269
   4905,          -3.,   4.68720627,   2.57436657
   4906,          -3.,   4.58015919,   2.57283306
   4907,          -3.,   4.89718628,   2.66698456
   4908,          -3.,    4.7935338,   2.66743469
   4909,          -3.,   4.68791723,   2.66600227
   4910,          -3.,   4.58182621,   2.66589451
   4911,          -3.,   4.89600182,     2.751688
   4912,          -3.,   4.79181576,   2.75249624
   4913,          -3.,   4.68765593,   2.75381041
   4914,          -3.,   4.58392715,   2.75592661
   4915,          -3.,    4.8951025,   2.83510351
   4916,          -3.,   4.79055548,   2.83591461
   4917,          -3.,   4.68685532,   2.83729076
   4918,          -3.,   4.58473682,   2.83950806
   4919,          -3.,   4.89480162,   2.91773939
   4920,          -3.,   4.79022408,    2.9182291
   4921,          -3.,   4.68689489,   2.91906166
   4922,          -3.,   4.58706903,   2.92022848
   4923,          -3.,   4.58032131,   2.37956905
   4924,          -3.,   4.68720961,   2.38561368
   4925,          -3.,   4.79295492,   2.39054489
   4926,          -3.,   4.89675283,   2.39225769
   4927,          -3.,    4.5826416,   2.28261423
   4928,          -3.,   4.68741226,   2.28909779
   4929,          -3.,   4.79219532,   2.29406834
   4930,          -3.,   4.89622641,   2.29541111
   4931,          -3.,    4.5850625,   2.18752432
   4932,          -3.,   4.68736458,   2.19328499
   4933,          -3.,   4.79127693,   2.19578457
   4934,          -3.,   4.89559221,   2.19691181
   4935,          -3.,   4.58783436,   2.09315777
   4936,          -3.,   4.68750238,   2.09626579
   4937,          -3.,   4.79084015,   2.09769726
   4938,          -3.,   4.89521837,   2.09835672
   4939,   -3.9000001,           4.,   2.79761291
   4940,   -3.9000001,           4.,   2.69323206
   4941,   -3.9000001,           4.,   2.57743239
   4942,   -3.9000001,           4.,   2.46754074
   4943,   -3.9000001,           4.,   2.36422968
   4944,   -3.9000001,           4.,   2.26954365
   4945,   -3.9000001,           4.,   2.18240023
   4946,  -3.79999995,           4.,   2.79761291
   4947,  -3.79999995,           4.,   2.69323206
   4948,  -3.79999995,           4.,   2.57743239
   4949,  -3.79999995,           4.,   2.46754074
   4950,  -3.79999995,           4.,   2.36422968
   4951,  -3.79999995,           4.,   2.26954365
   4952,  -3.79999995,           4.,   2.18240023
   4953,  -3.70000005,           4.,   2.79761291
   4954,  -3.70000005,           4.,   2.69323206
   4955,  -3.70000005,           4.,   2.57743239
   4956,  -3.70000005,           4.,   2.46754074
   4957,  -3.70000005,           4.,   2.36422968
   4958,  -3.70000005,           4.,   2.26954365
   4959,  -3.70000005,           4.,   2.18240023
   4960,   -3.5999999,           4.,   2.79761291
   4961,   -3.5999999,           4.,   2.69323206
   4962,   -3.5999999,           4.,   2.57743239
   4963,   -3.5999999,           4.,   2.46754074
   4964,   -3.5999999,           4.,   2.36422968
   4965,   -3.5999999,           4.,   2.26954365
   4966,   -3.5999999,           4.,   2.18240023
   4967,         -3.5,           4.,   2.79761291
   4968,         -3.5,           4.,   2.69323206
   4969,         -3.5,           4.,   2.57743239
   4970,         -3.5,           4.,   2.46754074
   4971,         -3.5,           4.,   2.36422968
   4972,         -3.5,           4.,   2.26954365
   4973,         -3.5,           4.,   2.18240023
   4974,   -3.4000001,           4.,   2.79761291
   4975,   -3.4000001,           4.,   2.69323206
   4976,   -3.4000001,           4.,   2.57743239
   4977,   -3.4000001,           4.,   2.46754074
   4978,   -3.4000001,           4.,   2.36422968
   4979,   -3.4000001,           4.,   2.26954365
   4980,   -3.4000001,           4.,   2.18240023
   4981,  -3.29999995,           4.,   2.79761291
   4982,  -3.29999995,           4.,   2.69323206
   4983,  -3.29999995,           4.,   2.57743239
   4984,  -3.29999995,           4.,   2.46754074
   4985,  -3.29999995,           4.,   2.36422968
   4986,  -3.29999995,           4.,   2.26954365
   4987,  -3.29999995,           4.,   2.18240023
   4988,  -3.20000005,           4.,   2.79761291
   4989,  -3.20000005,           4.,   2.69323206
   4990,  -3.20000005,           4.,   2.57743239
   4991,  -3.20000005,           4.,   2.46754074
   4992,  -3.20000005,           4.,   2.36422968
   4993,  -3.20000005,           4.,   2.26954365
   4994,  -3.20000005,           4.,   2.18240023
   4995,   -3.0999999,           4.,   2.79761291
   4996,   -3.0999999,           4.,   2.69323206
   4997,   -3.0999999,           4.,   2.57743239
   4998,   -3.0999999,           4.,   2.46754074
   4999,   -3.0999999,           4.,   2.36422968
   5000,   -3.0999999,           4.,   2.26954365
   5001,   -3.0999999,           4.,   2.18240023
   5002,   -3.9000001,    4.0249877,    2.0903585
   5003,   -3.9000001,   4.04739189,   2.08088923
   5004,   -3.9000001,   4.06628942,     2.066293
   5005,   -3.9000001,   4.08098507,    2.0472281
   5006,   -3.9000001,   4.09045172,   2.02464867
   5007,  -3.79999995,    4.0249877,    2.0903585
   5008,  -3.79999995,   4.04739189,   2.08088923
   5009,  -3.79999995,   4.06628942,     2.066293
   5010,  -3.79999995,   4.08098507,    2.0472281
   5011,  -3.79999995,   4.09045172,   2.02464867
   5012,  -3.70000005,    4.0249877,    2.0903585
   5013,  -3.70000005,   4.04739189,   2.08088923
   5014,  -3.70000005,   4.06628942,     2.066293
   5015,  -3.70000005,   4.08098507,    2.0472281
   5016,  -3.70000005,   4.09045172,   2.02464867
   5017,   -3.5999999,    4.0249877,    2.0903585
   5018,   -3.5999999,   4.04739189,   2.08088923
   5019,   -3.5999999,   4.06628942,     2.066293
   5020,   -3.5999999,   4.08098507,    2.0472281
   5021,   -3.5999999,   4.09045172,   2.02464867
   5022,         -3.5,    4.0249877,    2.0903585
   5023,         -3.5,   4.04739189,   2.08088923
   5024,         -3.5,   4.06628942,     2.066293
   5025,         -3.5,   4.08098507,    2.0472281
   5026,         -3.5,   4.09045172,   2.02464867
   5027,   -3.4000001,    4.0249877,    2.0903585
   5028,   -3.4000001,   4.04739189,   2.08088923
   5029,   -3.4000001,   4.06628942,     2.066293
   5030,   -3.4000001,   4.08098507,    2.0472281
   5031,   -3.4000001,   4.09045172,   2.02464867
   5032,  -3.29999995,    4.0249877,    2.0903585
   5033,  -3.29999995,   4.04739189,   2.08088923
   5034,  -3.29999995,   4.06628942,     2.066293
   5035,  -3.29999995,   4.08098507,    2.0472281
   5036,  -3.29999995,   4.09045172,   2.02464867
   5037,  -3.20000005,    4.0249877,    2.0903585
   5038,  -3.20000005,   4.04739189,   2.08088923
   5039,  -3.20000005,   4.06628942,     2.066293
   5040,  -3.20000005,   4.08098507,    2.0472281
   5041,  -3.20000005,   4.09045172,   2.02464867
   5042,   -3.0999999,    4.0249877,    2.0903585
   5043,   -3.0999999,   4.04739189,   2.08088923
   5044,   -3.0999999,   4.06628942,     2.066293
   5045,   -3.0999999,   4.08098507,    2.0472281
   5046,   -3.0999999,   4.09045172,   2.02464867
   5047,   -3.9000001,    4.0895133,   2.97213531
   5048,   -3.9000001,   4.07688046,   2.94634891
   5049,   -3.9000001,    4.0565629,   2.92523599
   5050,   -3.9000001,   4.03046989,   2.91133976
   5051,  -3.79999995,    4.0895133,   2.97213531
   5052,  -3.79999995,   4.07688046,   2.94634891
   5053,  -3.79999995,    4.0565629,   2.92523599
   5054,  -3.79999995,   4.03046989,   2.91133976
   5055,  -3.70000005,    4.0895133,   2.97213531
   5056,  -3.70000005,   4.07688046,   2.94634891
   5057,  -3.70000005,    4.0565629,   2.92523599
   5058,  -3.70000005,   4.03046989,   2.91133976
   5059,   -3.5999999,    4.0895133,   2.97213531
   5060,   -3.5999999,   4.07688046,   2.94634891
   5061,   -3.5999999,    4.0565629,   2.92523599
   5062,   -3.5999999,   4.03046989,   2.91133976
   5063,         -3.5,    4.0895133,   2.97213531
   5064,         -3.5,   4.07688046,   2.94634891
   5065,         -3.5,    4.0565629,   2.92523599
   5066,         -3.5,   4.03046989,   2.91133976
   5067,   -3.4000001,    4.0895133,   2.97213531
   5068,   -3.4000001,   4.07688046,   2.94634891
   5069,   -3.4000001,    4.0565629,   2.92523599
   5070,   -3.4000001,   4.03046989,   2.91133976
   5071,  -3.29999995,    4.0895133,   2.97213531
   5072,  -3.29999995,   4.07688046,   2.94634891
   5073,  -3.29999995,    4.0565629,   2.92523599
   5074,  -3.29999995,   4.03046989,   2.91133976
   5075,  -3.20000005,    4.0895133,   2.97213531
   5076,  -3.20000005,   4.07688046,   2.94634891
   5077,  -3.20000005,    4.0565629,   2.92523599
   5078,  -3.20000005,   4.03046989,   2.91133976
   5079,   -3.0999999,    4.0895133,   2.97213531
   5080,   -3.0999999,   4.07688046,   2.94634891
   5081,   -3.0999999,    4.0565629,   2.92523599
   5082,   -3.0999999,   4.03046989,   2.91133976
   5083,   -3.9000001,    4.8944397,           2.
   5084,   -3.9000001,     4.789258,           2.
   5085,   -3.9000001,   4.68604755,           2.
   5086,   -3.9000001,   4.58394909,           2.
   5087,   -3.9000001,   4.48417091,           2.
   5088,   -3.9000001,   4.38937569,           2.
   5089,   -3.9000001,    4.3035841,           2.
   5090,   -3.9000001,   4.22984076,           2.
   5091,   -3.9000001,    4.1617527,           2.
   5092,  -3.79999995,    4.8944397,           2.
   5093,  -3.79999995,     4.789258,           2.
   5094,  -3.79999995,   4.68604755,           2.
   5095,  -3.79999995,   4.58394909,           2.
   5096,  -3.79999995,   4.48417091,           2.
   5097,  -3.79999995,   4.38937569,           2.
   5098,  -3.79999995,    4.3035841,           2.
   5099,  -3.79999995,   4.22984076,           2.
   5100,  -3.79999995,    4.1617527,           2.
   5101,  -3.70000005,    4.8944397,           2.
   5102,  -3.70000005,     4.789258,           2.
   5103,  -3.70000005,   4.68604755,           2.
   5104,  -3.70000005,   4.58394909,           2.
   5105,  -3.70000005,   4.48417091,           2.
   5106,  -3.70000005,   4.38937569,           2.
   5107,  -3.70000005,    4.3035841,           2.
   5108,  -3.70000005,   4.22984076,           2.
   5109,  -3.70000005,    4.1617527,           2.
   5110,   -3.5999999,    4.8944397,           2.
   5111,   -3.5999999,
RE: Problem During Compilation
I get constantly this message:
Abaqus is unable to execute the command: Abaqus/Standard Analysis Please check the validity of the command on this computer.
If you have any idea it is coming from, please input!
Thank you very much for letting me know that it runs on your machine!
I don't have any specific reason for the 750 (it was based on a previous model that was running two years ago).
The conclusion I guess is that something is not OK with the intel fortran compiler and ABAQUS on my machine (University Computer lab).
I'll give the tutorial about connecting ABAQUS with Fortran to our lab technician to check (Although both programs seem to be connected).
If you have any other idea about what is going on please let me know!
