What is this please?
Could anyone tell me what this arrangement is? 2 pumps? The person I was going to ask is away for 2 days. A pump at the top and 2 vertical pumps lower down? I am pretty stuck. Thanks.
RE: What is this please?
Poor, very poor quality interpretive "3D image" of three "somethings" with cylinders running between them
I disagree that the lower two are pumps (filters maybe) with that vertical cylinder-looking thing comping up eccentrically through what would be a vertical-axis motor above a pump. But, if so, the pump would be sucking and discharging horizontally though the "support" below.
But, like you point the lower items might be pumps, but their vertical cylinders going through them don't actually "connect" to the horizontal cylinder that runs into the upper pump-looking thing.
Whatever it is supposed to be, it will leak if built like the "CAD model" you have. *<)
This is probably not what you wanted to hear.
Except that there are no valves, sources, or end uses shown, it looks a lot like a swimming pool circulation pump sitting on top of two sand filters.
Give us a hint, maybe? Is this connected to a project of some sort? Hotel or nuclear submarine? LNG plant or medical DI water system?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
I see a roots blower on top of two dry SIHI screw vacuum pumps.
But that is just what I see, it is definitely an ink blot test for us.
StoneCold
Hydraulic Warp Drive?
Mike McCann
MMC Engineering
Do a search for a rough and regen pump. This type of pump can be used for cryogenic application. How do I know this? I just read the bottom border of your image.
Beam me up Scotty
LOL
Warped Hydraulic Drive? 8<)
I think its a UFO lifting two buildings in downtown LA.
