Helical worm gear without ventilation
Who can help me answering the following question?
Gearboxes have so called breather valves to keep the pressure inside the box at atmospheric level during operation. Would it be possible to get rid of breather valves if we put an expansion system in the box, similar to an expansion tank in a central heating system? Our customer would like a smooth and fully closed (small) gearbox in food machinery.
Here is what I think is going on, please correct me if I am wrong: The free space inside the box is filled with oil and air. During operation the oil gets heated by the worm gear inefficiencies and will expand a little (volumetric expansion). Thus the air volume will get less in the same amount. Since the air is heated also the pressure rises. (following the gaslaw). This pressure acts in the air and on the oil. To avoid shaft seals being blown out or starting to sweat and leak, breather valves come into the picture. These valves can be chosen to open at for instance 1.2 bar.
Here is my example calculation: Free box volume 1 liter. At ambient pressure p1 and temperature T1=20 degr C, the oil volume is 0.8 liter. Thus the air volume V1 is 0.2 liter. In full operation max oil temperature is 100 degr C and the air temperature T2=80 degr C. Volumetric expansion coëfficiënt oil: 0.7*10^-3 /K. The volume of the heated oil is thus 1*(1+(80-20)*0.7*10^-3) = 1.042 liter. So the heated air volume V2 is 0.157 liter. Using the gaslaw the pressure p2 would be p1*V1*T2/(T1*V2) = 1*0.2*80/(20*0.157) = 5.1 bar(!) To get this pressure down to 1.2 bar (a value my customer expects the seals can handle) the heated air volume would need to be 5.1/1.2 = 4.25 times 0.157 = 0.667 liter. So some kind of expansion system should have a volume of 0.51 liter. In relation to the small box itself that is huge and not acceptable.
But…if the box was completely filled with oil (no air at all) an expansion system of at least 0.042 liter would be sufficiënt to pick up the oil expansion. Am I right here? Is this feasible? Any input is very much appreciated.
RE: Helical worm gear without ventilation
I'm wondering it should be 0.8*(1+(80-20)*0.7*10^-3) = .....
Dgallup: why do you think that frictional losses greatly increase? The worm and wormgear are already 80% under oil level. Do you mean losses due to friction between the oil and the rotating elements?
The ideal gas law works with Kelvin degrees, not C degrees.
Obviously need to redo my calcs here:
Volume of the heated oil = 0.8*(1+(80-20)*0.7*10^-3) = 0.8336 liters.
So the volume V2 of the heated air is 1-0.8336=0.1664 liters instead of 0.157 liters.
Then using the gaslaw the pressure p2 would be p1*V1*T2/(T1*V2) = 1*0.2*(80+273)/((20+273)*0.1664) = 1.45 bar.
That sounds a lot better. Do you think an expansion system is feasible? With so many gearbox producers around the world, I can hardly believe it is not already used somewhere.
Why not something akin to an accumulator on a hydraulic pressure system? You calc. and adjust the size, back pressure, gas type, etc., for proper operation. This might be fairly small and tucked in a corner someplace, along side the gear box.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
For your application, does a "fine" filter work?
Due to thermal expansion, as noted.
If you're patient, you can download their G1000 manual, and look in the 'key features' section. I think it's 84MB catalog.
Alternatively could food quality libricant be used? I worked in a company where pneumatic lubricant was extensively used on food production lines as long as it was considered food safe.
Piping breather to non-critical area.
Also there are filters available for oil breathers. Dont knnow of a food safe one off hand.
