DFLUX Subroutine in Abaqus
Hi All,
I have used abaqus to carry out simple stress tests using loads and thermal loads before however, I am now moving onto more complex cases. After struggling to get the fortran compilers to link on my machine I have now got to the point were I can start to test stuff out.
My aim is to produce a model to simulate a cutting tool move along a surface. I have broken this down into into initially trying to move a point heat source along a plate - just once. From what I have read I need to use the DFLUX subroutine to carry this out.
So far I have constructed the plate as a 3D deformable part with dimensions 120x120x5mm, given it the material properties of steel, created two steps initial and load. I have assigned a boundary condition to the side of the plate and a surface heat flux to the main face of the plate with the distribution set as user defined. In the job I have inserted the fortran file named DFLUX.for. This file contains the following text:
SUBROUTINE DFLUX(FLUX,SOL,JSTEP,JINC,TIME,NOEL,NPT,COORDS,JLTYP,
1 TEMP,PRESS,SNAME)
C
INCLUDE 'ABA_PARAM.INC'
C
DIMENSION COORDS(3),FLUX(2),TIME(2)
CHARACTER*80 SNAME
FLUX(1)=????
FLUX(2)=???
RETURN
END
My issue is that I am struggling to fill in these flux functions so that it models a moving heat source.
I have looked high and low for any good tutorials and wouldn't have posted if I hadn't. So if anyone has any experience of how to do this or a better place to be looking for help I would be very grateful.
Thanks hopefully I will be able to help someone else out in the future.
