How to mount multiple sensor/switches on one sch 80 pvc connection
We have a municipal waste project (in progress) that has 6" sch 80 pvc with a 1/2" tapped hole. Threaded into the hole is a nipple going to a manifold which then has a ashcroft type 100 diaphragm seal on each leg. Leg 1 goes to a pressure gage, leg 2 to an Endress pressure sensor/transmitter, and leg 3 to a SOR pressure switch. This goes before and after each pump and there are 10 pumps. I wonder if there is one instrument that can do the job of all 3 of these? Also if we must mount all 3 does anyone have a picture or description of a good way to mount these securely so we dont break the pipe in the future? They are all about 3-4' AFF. We can make any changes we want as we are the end user.
Thanks for any ideas.
RE: How to mount multiple sensor/switches on one sch 80 pvc connection
Dwyer / Mod-tronic Indicating Pressure Transmitter and Switch
For more, put this in Google:
indicating pressure transmitter switch
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
