Draft date autoupdate
Hi all.
Is it possible to have the date field in the properties box on a drawing update to the present date automatically? At the moment I need to use properties manager each time if I want to update it.
Also, by default the author field gets filled with my login name to windows (i.e. a short lowercase username), is it not possible to have it be populated with my full name instead?
RE: Draft date autoupdate
On another note, you might try asking questions like this at the Siemens PLM Solid Edge Community site: http://community.plm.automation.siemens.com/t5/Sol...
Ken G.
http://grundey.blogspot.com
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I'm not worried about the dates auto updating since I normally save a pdf of the drawing if I'm happy which is permanent.
