differential relay slope setting.
hello engineers, from the differential relay manual, they recommended the setting for 1st bias slope setting is 1x tap change range. my transformer got 5 tap and range is 2.5% per tap. so total range is 5% from center.so can i set 0.05 setting for 1st bias slope.
RE: differential relay slope setting.
Who is the differential relay manufacturer?
You should also include an allowance for CT errors.
These sound like fixed taps. Do you change taps often? If yes and no, I would use the fixed tap ratio in your tap setting calcs to keep the slope down. If they change frequently, go for a higher slope to avoid frequent protection setting changes. Slope also accommodates CT error as stated above.
