ISO 2768 Postion Tolerance Question
Simple question, does the "Ranges in nominal lengths in mm" for position refer the feature size, for instance, hole diameter, or does it refer to the distance between features?
RE: ISO 2768 Postion Tolerance Question
My understanding is that the tolerances apply to any linear dimension not otherwise specified per 4.1 of my 1981 version of the std (part 1).
So depending on tolerance scheme they potentially apply to both the locating dimensions and the feature size dimensions.
Obviously depending on the value for the size and location dimensions the actual tolerance may be different.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"This part of ISO 2768 only applies for the following dimensions which do not have an individual tolerance indication:
a) linear dimensions (e.g. external sizes, internal sizes, step sizes, diameters, radii, distances, external radii and chamfer heights for broken edges);[...]"
However the standard has no power over theoretically exact dimensions (in ASME Y14.5 they are called basic).
"General geometrical tolerances apply to all geometrical tolerance characteristics, excluding cylindricity, profile of any line, profile of any surface, angularity, coaxiality, positional tolerances and total run-out."
So, no position. (you were asking about ISO 2768 position, right?
1. The drawing statement should be: "TOLERANCES ARE PER: DIN ISO 2678-fK".
2. K refers to general geometric tolerances, but position is not amongst them, as CheckerHater noted.
3. For the 7mm holes general linear tolerance class "f" applies. According to the Table 1 in ISO 2786-1 this will be +/-0.1. For 1300mm distance between them the same general linear tolerance class "f" applies. According to the Table 1 in ISO 2786-1 this will be +/-0.5.
The hole size tolerance comes from the tol on 7mm.
