Gate Valve trim Material
If anybody could clarify F-WDC , This is what I got on a 10" CL 1500 gate valves description .
thanks
ALponder
RE: Gate Valve trim Material
Are you certain that F-WDC is a reference to a gate valve trim? At first glance, this looks more like valve trim selector of a particular brand.
API 600 valve trims are numeric, e.g., "API Trim 12" or "API Trim 9". You can refer to this valve trim material overview for details.
Corrosion resistant, exotic alloy valves from The Alloy Valve Stockist in Barcelona, Spain http://alloy-valves.com
