Can i use
Can i use
Can i use
Hi fellow pipers,
I have a doubt with using ASME B31.3 Chapter ix-High Pressure Piping to calculate the minimum wall thickness.
The material which i have to use is A672 C65 CL22 which is plate material which is then formed into a pipe with a seam weld along the length of the pipe.
Now this material is listed in table A and not in table K. Table K is the applicable table for to obtain allowable stress values in order to calculate minimum wall thickness as per Chapter ix:High Pressure Piping for ASME B31.3.
Can i use the allowable stress values in table A for the formular to calculate wall thickness as per chapter ix:High Pressure Piping?
Yudi
RE: Can i use
No, you cant use table A-1 for Ch IX work. See K302.3.
RE: Can i use
Thank you very much XL83NL. I am new to using Eng-Tips and how to get around.
RE: Can i use
You're welcome. There are a lot of good contributors to the site (I'm pretty new myself too), which can be of great benefit.
Make sure to understand the forum policy and rules and I'm sure you'll enjoy your stay here.
