Need help in scripting for selection of Points in specific Geo Set
How to selects the Elements (points) which is in Particular Geometric Set
selection1.Search "Name=Point'.'*,all"
'selection1.Search "type=CATGmoSearch.Point,all"
The above 2 option i tried but it gives selection of all points available in the active sheet. I jus want point selected from a specific geometric set
Does anyone have solution for this
Barath :)
RE: Need help in scripting for selection of Points in specific Geo Set
Hi
I tried that; but tht is not working.Any other solution can u provide
Barath
What Nick wanted to say is that you need first to do a selection (the GS) and then search inside that selection....
CODE --> CATScript
Sub CATMain()
Dim oPartDoc As Part
On Error Resume Next
Set oPartDoc = CATIA.ActiveDocument.Part
If Err.Number <> 0 Then
Message = MsgBox("Sorry, This script works with a CATPart as Active document", vbCritical, "Error")
Exit Sub
End If
    ' What do you want to select - in this case a Geometrical Set
    Dim EnableSelectionFor(0)
    EnableSelectionFor(0) = "HybridBody"
    ' Reset the Selection
    Set sSEL = CATIA.ActiveDocument.Selection
    sSEL.Clear
 ' Define Selection
	MsgBox "Please Select the Geometrical Set where you have the POINTS"
    UserSelection = sSEL.SelectElement2(EnableSelectionFor, "Please select another Geometrical Set", False)
    ' Evaluation if the selection is correct or not
    If UserSelection <> "Normal" Then
        MsgBox "Error with the selection"
        Exit Sub
Else
Set ohybridbody = sSEL.Item(1).Value
    End If
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATPrtSearch.Point,sel"
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thanks Fernando and Ntweison.
I didn notice that "*.Sel' in that code
This code worked :D.. Actually i dont wanna select the geometric set manually and do it. Rather i know the name of the geometric set. I want both the selection to be done automatically.. Any suggestions
Barath :)
Use
If you know the GS name and sure about the presence of it(only once) (If more then the this method will return first accessed one i think... try it out)
CATIA.ActiveDocument.Part.FindObjectByName(GSName)
Selection.Add Part.FindObjectByName(GSName)
Selection.Search "Name=Point'.'*,sel"
Loop through all the points selected.
Maddy
The willingness to share knowledge does not make one charitable; it makes one self-reliant to know more.
Modified - Courtesy of Robert Brault
Hi Maddy
I tried tht; it doesnt work. Actually i have some points int the geometric set named " Geometric Set_Points". i want to extract the coordinates of these points and save it in text or excel. so i wanna select the GS automatically and its points.. so after that some loop to get coordinate for each point in the set
thanks
Barath
Then try this..
Set oGS = Part.FindObjectByName("Geometric Set_Points")
' MsgBox oGS.Name & " Total Items : " & oGS.HybridShapes.Count ' For confirmation that you got it right.
For Each oPoint in oGS.HybridShapes
If TypeName(oPoint) = "HybridPointTangent" Then
' get the coordinates here using measure option
End If
Next
use the following filter option to get only 3D points out of all the contents of GS.
' HybridPointTangent = Point on curve option
HybridShapePointExplicit = isolated point
HybridShapePointCoord
HybridShapePointOnPlane
HybridShapePointOnSurface
HybridShapePointCenter
HybridShapePointTangent or ' HybridPointTangent i suppose
HybridShapePointBetween
Try with hybridshape and hybridpoint and see the result.. i cant recall completely.
Maddy
HI
i have extracted the poit coordinate by selectiong the Geometric set and the poitns in it automatically..but now the problem is. i want to extract the coordiante of the point with respect to local axis system.. Any suggestion to define local axis system, so tht i can get the coordinate of the point wrt that..
This is the code for which i need to add local axis system...Any suggestions
Sub CATMain()
Set part1 = partDocument1.Part
Set hybridShapeFactory1 = part1.HybridShapeFactory
Set objNetwork = CreateObject("Wscript.Network")
Set hb1=CATIA.ActiveDocument.Part.InWorkObject
Set hsf=CATIA.ActiveDocument.Part.HybridShapeFactory
Set prt=CATIA.ActiveDocument.Part
Set sel=CATIA.ActiveDocument.Selection
Set SPAWorkBench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Set planeZX = CATIA.ActiveDocument.Part.OriginElements.PlaneZX
Exit Sub
End If
sSEL.Clear
set FileSys = CATIA.FileSystem
Dim FileObj
Set FileObj = FileSys.CreateFile("D:\pointsout.txt", True)
set TextStr = FileObj.OpenAsTextStream("ForWriting")
Dim selection1
Selection1.Add Part1.FindObjectByName("Geometric_Set_Points")
Selection1.Search "CATPrtSearch.Point,sel"
Dim Coord(2)
For i = 1 To Selection1.Count
Dim CurrWorkbench
Set CurrWorkbench = partDocument1.GetWorkbench("SPAWorkbench")
Dim Measure
Set Measure = CurrWorkbench.GetMeasurable(Selection1.Item(i).reference)
Msgbox Measure.Name
Measure. GetPoint Coord
Msgbox Coord(0) & ", " & Coord(1) & ", " & Coord(2)
TextStr.Write(Coord(0) & ", " & Coord(1) & ", " & Coord(2) & vbCrLf)
Next
part1.Update
End Sub
Use
Get the coordinates of Axis system using GetOrigin iAxisSystemXYZ
Get the vectors of the Axis system using GetVectors you will get X,Y (like 1,0,0 & 0,1,0)
and do a crossproduct to get normal vector i.e Z (0,0,1)
Multiply Sign of X with iAxisSystemXYZ(0) Coord of Axis system
Multiply Sign of Y with iAxisSystemXYZ(1) Coord of Axis system
Multiply Sign of Z with iAxisSystemXYZ(2) Coord of Axis system
Add This resultant values of X,Y,Z to Point coordinates to get the coordinate w.r.t axis system.
Pt(0) + iAxisSystemXYZ(0)*Sgn(x)
Pt(1) + iAxisSystemXYZ(1)*Sgn(y)
Pt(2) + iAxisSystemXYZ(2)*Sgn(z)
Maddy
Maddy
