Coatings for Severe Applications
Does anybody have any first hand experience using different Valve coatings for severe application? Hobbs Valve use TiN as standard in their Triple Offset Valves.
Process Industry Forum
RE: Coatings for Severe Applications
Do you mean coating on the trim or on the body? What "severe applications" are you referring to and
Corrosion resistant, exotic alloy valves from The Alloy Valve Stockist in Barcelona, Spain http://alloy-valves.com
