Gfortran link with abaqus on win7
Does anyone know how to modify abaqus_v6.env to link gfortran with abaqus(6.10) on win 7 (32)?
RE: Gfortran link with abaqus on win7
1. installing gfortran and gcc / g++ (duh)
2. change all mentions of ifort and icpc to gfortran and gcc and change the compiler flags
Other than that I can't help (on linux)
I installed gcc from http://www.equation.com/servlet/equation.cmd?fa=fo....
The abaqus_v6.env looks a little different, can you take a look of it?
and also,do you know how to test if gfortran works on windows with a simple way?
Thanks.
# System-Wide Abaqus Environment File
scratch="d:/temp"
standard_parallel = ALL
mp_mode = MPI
split_dat = ON
mp_file_system = (DETECT,DETECT)
mp_environment_export = ('MPI_PROPAGATE_TSTP',
'ABA_CM_BUFFERING',
'ABA_CM_BUFFERING_LIMIT',
'ABA_ITERATIVE_SOLVER_VERBOSE',
'ABA_DMPSOLVER_BWDPARALLELOFF',
'ABA_ELP_SURFACE_SPLIT',
'ABA_ELP_SUSPEND',
'ABA_HOME',
'ABA_MEMORY_MODE',
'ABA_MPI_MESSAGE_TRACKING',
'ABA_MPI_VERBOSE_LEVEL',
'ABA_PATH',
'ABA_RESOURCE_MONITOR',
'ABA_RESOURCE_USEMALLINFO',
'ABAQUS_LANG',
'ABAQUSLM_LICENSE_FILE',
'ABQ_CRTMALLOC',
'ABQ_DATACHECK',
'ABQ_RECOVER',
'ABQ_RESTART',
'ABQ_SPLITFILE',
'ABQ_XPL_WINDOWDUMP',
'ABQ_XPL_PARTITIONSIZE',
'ABQLMHANGLIMIT',
'ABQLMQUEUE',
'ABQLMUSER',
'CCI_RENDEZVOUS',
'DOMAIN',
'DOMAIN_CPUS',
'DOUBLE_PRECISION',
'FLEXLM_DIAGNOSTICS',
'FOR0006',
'FOR0064',
'LD_PRELOAD',
'MP_NUMBER_OF_THREADS',
'MPC_GANG',
'MPI_RDMA_NENVELOPE',
'MPI_SOCKBUFSIZE',
'MPI_WORKDIR',
'MPCCI_SERVER',
'MPCCI_INITIAL_EXCHANGE',
'_MPCCI_CCM_CODE_IDS',
'_MPCCI_CODE_IDSTRING',
'ABAQUS_CCI_DEBUG',
'NCPUS',
'OMP_DYNAMIC',
'OMP_NUM_THREADS',
'OUTDIR',
'PAIDUP',
'PARALLEL_METHOD',
'RAIDEV_NDREG_LAZYMEM',
'ABA_SYMBOLIC_GENERALCOLLAPSE',
'ABA_SYMBOLIC_GENERAL_MAXCLIQUERANK',
'ABA_ADM_MINIMUMINCREASE',
'ABA_ADM_MINIMUMDECREASE',
'IPATH_NO_CPUAFFINITY',
'MALLOC_MMAP_THRESHOLD_',)
memory='50%'
compile_cpp=['CL', '/c', '/nologo', '/W0', '/MD', '/DABQ_NTI_NET', '/DABQ_WIN86_32',
'/TP', '/EHs', '/GS', '/DNDEBUG', '/DWIN32', '/DTP_IP', '/D_CONSOLE',
'/DNTI', '/DFLT_LIC', '/DOL_DOC', '/D__LIB__', '/DHKS_NT',
'/DFAR=', '/D_WINDOWS', '/O1', '/Gs', '/I%I']
compile_fortran=['gfortran', '/c', '/Gm', '/recursive', '/nologo', '/heap-arrays:1', '/include:%I']
link_sl='cmd /c "LINK /nologo /INCREMENTAL:NO /subsystem:console /machine:X86 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /DEFAULTLIB:LIBIFCOREMD.LIB /DEFAULTLIB:LIBIFPORTMD.LIB /DEFAULTLIB:LIBMMD.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /dll /def:%E /out:%U %F %A %B &&mt /manifest %U.manifest /outputresource:%U;2 && del %U.manifest"'
link_exe='cmd /c "LINK /nologo /INCREMENTAL:NO /subsystem:console /machine:X86 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /DEFAULTLIB:LIBIFCOREMD.LIB /DEFAULTLIB:LIBIFPORTMD.LIB /DEFAULTLIB:LIBMMD.LIB /DEFAULTLIB:SVML_DISPMT.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /LARGEADDRESSAWARE /STACK:20000000 /out:%J %F %M %L %B %O && mt /manifest %J.manifest /outputresource:%J;1 && del %J.manifest"'
# If you are attempting to compile C++ programs using Abaqus make utility without a
# Fortran compiler installed on your machine, uncommenting the following
# link_exe command may help resolve any link errors.
# link_exe='cmd /c "LINK /nologo /INCREMENTAL:NO /subsystem:console /machine:X86 /STACK:20000000 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /NODEFAULTLIB:LIBIFCOREMD.LIB /NODEFAULTLIB:LIBIFPORTMD.LIB /NODEFAULTLIB:LIBMMD.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /LARGEADDRESSAWARE /out:%J %F %M %L %B %O && mt /manifest %J.manifest /outputresource:%J;1 && del %J.manifest"'
mp_mode = THREADS
mp_mpi_implementation = HP
mp_rsh_command = 'dummy %H -l %U -n %C'
mp_mpirun_path = {HP:'C:\\Program Files\\Hewlett-Packard\\HP-MPI\\bin\\mpirun.exe'}
import driverUtils, os
graphicsEnv = driverUtils.locateFile(os.environ['ABA_PATH'],'site','graphicsConfig','env')
if graphicsEnv:
execfile(graphicsEnv)
else:
raise 'Cannot find the graphics configuration environment file (graphicsConfig.env)'
del driverUtils, os, graphicsEnv
abaquslm_license_file="@130.149.89.49"
academic=RESEARCH
program hello
print *, "Hello World!"
end program hello
(watch the spacing)
and do (in command line)
gfortran hello.f
and run the file
./a.out
for the .env file, I have no idea
