Using VPUT after a restart
Hi everyone,
I am doing a thermal transient analysis. I have to restart the analysis in do-loops. Inside this loop I also have an inner do-loop in which I change the loading condition ans solve in a trial-and-error fashion until I find the correct loading condition for that load step.
For solving the problem at each inner do-loop I need to apply temperatures from the previous finalized load step as the initial condition. I use LDREAD,TEMP,last,,,2,'file','rth',' ' for this purpose.
However, it appears that within the inner loop this command reads the data from the last trial-and-error run, as opposed to the end of the previous load step. So I tried to save the results from the last finalized load step in an array and apply it during the trial and error via *VPUT, before I issue the LDREAD command. However, I get the following error message:
"data record does not exist for the vput of some node entities requested"
Any help or suggestion is really appreciated.
Thank you in advance for your time and help.
Ashton
Ashton
