Globle plus incline grid systems in one model
Hi everyone,
I have a complex building which has a few grid systems, to make the question simple we say one globle grid system and one 45 degree grid system (system 2), I know I can switch between the two systems and the coordinate of points shown are consistent with each grid system. But when I try to model members under grid system 2, for example trying to replicate one beam along X or Y along grid system 2, when I input the X, Y coordinate it still goes with globle system, same idea with creating reference line or drawing point base on grid intersection, it really dries me crazy, is it the way it is?
How do you usually do when you have such situation?
Thank you.
RE: Globle plus incline grid systems in one model
You can use the "Convert to general grid" command from the coordinate system window.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
