Proe 2001 under winXP Pro
Does anyone know what is wrong when Proe 2001 does not run under WIndows XP Pro. It is completely installed. I really need to use the program. So if anyone van help me run the program that would be great.
RE: Proe 2001 under winXP Pro
it can happen if your version of proe is too old. To be sure look in the original cd. It must say what platform is suported
If you will run Pro Engineer under XP, you MUST make sure that your harddisk is NTFS-formattet, otherwise the program will not run. Have you made a license from your netcard? this is also essencial.
Hope this can help
Michael
