Break the link of PDF Underlay in AutoCAD 2013
Can any tell me how to break the link of PDF that attached as PDF Undelay in AutoCAD?
Actually I have a PDF drawing that need to be attached in AutoCAD template as image. I tried many method but not getting clear image. Finally I got this method which gives me clear image but the link is the problem. I have to always keep the PDF file along with DWG in order to protect the linkage.
Any other method would be appreciated by which I can get clear image.
Thanks in advance.
Thanks in advance.
Bambila
Mechanical Engineer
RE: Break the link of PDF Underlay in AutoCAD 2013
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com | http://bwstructuralengineer.com | http://bwcivilengineer.com
It is inserted into the drawing using 'PDFUnderlay' option.
Bambila
Mechanical Engineer
Aide PDF to DWG Converter
