Show/Erase Dimensions for Top-Down design
I'm having this problem while creating a drawing for a part that has been modelled using Top-down design (copy/published geometries).
The problem I have is that while using show/erase none of the dimensions of the upper level sketches become visible. Is there a way to show the dimensions of sketches created in upper lvl assemblies? We only started to incorporate Top-Down design so this is the first time an actual DRW has to be made. We use PRO-E WF 3.0 here.
Greetings,
Raf
