Repair servo motor with Stegmann Hiperface
Dear Srs, I'm repairing a 1326AB servo motor with a Stegmann Hiperface feedback, model SRM50.
How do I synchronize it with the motor?
RE: Repair servo motor with Stegmann Hiperface
If you have the capability to apply a voltage across any two phases now, this will force the motor to a known shaft angle (like a stepper motor). Read the absolute encoder position. When you re-assemble the motor/encoder system after repair, turn the encoder so it reads this same position. Apply voltage across these same two phases when you re-attach the encoder.
Curt Wilson
Delta Tau Data Systems
